Opel Forums
Go Back   Opel Forums > Opel Forums > Classic Opels > GT > Opel GT Restoration Project
Opel GT Restoration Project Article and comments on the restoration of an Opel GT. Post comments to the Comments thread only.
Old 06-09-2008   #26 (permalink)
opelspyder's Avatar
Coming up
It will be coming up real soon, I still have to do some metal repair down low from damage??? Not sure what happend there, but a few little things and I will be pounding the filler...ha. Kind of like Talledaga Nights but I call it "Cave and Pave"
Well I don't really have any caves to pave, but will probably skim the whole car to make sure it is as straight as I can make it. I apply 100% filler, then sand off about 98%-fun dusty job too
Keith
opelspyder is offline   Reply With Quote Top home
Old 10-06-2008   #27 (permalink)
Can't help but notice the 'spray booth' you're using...the EPA and CT's own DEP (Department of Environmental Protection) would crucify me if I ever did such a thing at home!
C.R.L. 9/22/69 - 12/8/99
J.M.L. 3/3/43 - 6/15/04
Old 10-06-2008   #28 (permalink)
We can do things like that, here in the South. Keith can have his "paint booth" as long as he don't say nuthin about the "still" down the road...
BQS4 is online now   Reply With Quote Top home
Old 10-06-2008   #29 (permalink)
opelspyder's Avatar
paint booth
Yes, the booth is a little iffy, you are still seeing it in the works. I just got the larger fan and what I will be doing is building a large wooden suction chamber that will sit outside. I will put filters in it, so it will be a little more professional. It will be where it can be disassembled for storage. I don't like just the fan at the door either, but for primer, it works. I will run three fans to suck enough air through hopefully. Basiccally it will look from the outside like a vacuum cleaner sucking up the underside of the door. Also notice the Manta in the background of the pics-Thats Daves that will be next to get painted, so I have to upgrade the ole' southern paint booth.
Keith
Old 10-06-2008   #30 (permalink)
Just another glory rider
Phoenix's Avatar
Classified Rating: 100% (1)
Once again, your doing what I'm doing, at the time that I'm doing it.
If you don't think that your project threads help, they do! You were building the front suspension when I was building mine. Here your doing bodywork while I'm doing mine.
Phoenix is offline   Reply With Quote Top home
6-speed transmission??? That's 2 more gears than I need!
Old 4 Weeks Ago   #31 (permalink)
2 Fast 4 U's Avatar
In your thread "Cut in paint" I saw that you mask taped the outside panel parts of the doors and hood before you spray painted the insides of the doors and hood, I was asking my self for what reason did you do that??
2 Fast 4 U is offline   Reply With Quote Top home
Groetjes, Greetings, Grüße:
Opel Ascona, driving one is like living on the edge.
Only built from 1970 until 1975
Daily driver:
'72 Ascona 2.0 Luxus Automatic
Old 4 Weeks Ago   #32 (permalink)
opelspyder's Avatar
Good question
Cutting in paint, or jambing as they call it is when I want to paint the insides of the doors and hood and such. I tape off the other side because when spraying into crevises and such, sometimes dust particles fly out and spray patterns are altered and can cause overspray on other adjacent surfaces. I want the entire outside of the car to be the same shade of yellow. So when I paint the body surface, I will paint the hood and door surfaces the same time with the same amount of coats. Unless I hang the hood, I can only spray one side at a time. In a nutshell it eliminated one thing more to screw up a paint job by a spray blemish or debris blown out of a crevis. Not to say you cannot paint the entire car, doors and hood inside and out in one whack, you can do that as well.
Old 4 Weeks Ago   #33 (permalink)
2 Fast 4 U's Avatar
Thumbs up Awesome
This is awesome, very nice paint job eventhou yellow isn't my color it looks great
I've heard that metalic colors are hard to spraypaint, do you have any experience and/or tips??
Daily driver:
Old 4 Weeks Ago   #34 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
Great job Keith as usual! The car looks great. As you may recall, Yellow was one of my top three color choices when I was trying to decide what color to paint my car. It looks great and the owner has to be impressed! You look like an astronaut in that paint suit!
Matt
newman27 is offline   Reply With Quote Top home
'72 Opel GT (Fireglow Orange)
Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, XM Radio / CD, ADDCO Front / Rear Anti-Sway-Bars
Other Cars:
Old 4 Weeks Ago   #35 (permalink)
opelspyder's Avatar
Thanks, and now metallics
I tend to stick to solids and honestly have only painted a metallic paint in acrylic enamel, which was a single stage. I have not had much experience with a base clear, except for at work we do it all the time, I always used single stage, as it is easier, and a lot less time consuming. But in answer to your question, your gun setup is critical, and air mixture needs to be a constant, metallic runs together easily, and you should use a wider spray pattern when shooting them. Also on a single stage, you have to watch that you do not wetsand the metallic out of it. I shot a TR7 in a dark metallic pewter color. I didn't mix my paint well (should have reduced it down more) It came out of the gun and dried as soon as it hit the surface, so it was textured, and way too much to sand out...needless to say I learned what I did wrong, and painted it the next weekend. Not a perfect job, but good enough to sell as finished 3 days later. So practice on a panel, I know it isn't very cost effective to practice with expensive chemicals and paints, but sometimes if you know a shop, they may sell you leftovers cheap to experiment with. I would do smaller test pieces myself before I painted a whole car not knowing.
Keith
Old 4 Weeks Ago   #36 (permalink)
2 Fast 4 U's Avatar
Originally Posted by opelspyder View Post
I tend to stick to solids and honestly have only painted a metallic paint in acrylic enamel, which was a single stage. I have not had much experience......... .......... but sometimes if you know a shop, they may sell you leftovers cheap to experiment with. I would do smaller test pieces myself before I painted a whole car not knowing.
Keith
Thanks for the info!!
Daily driver:
Old 1 Week Ago   #37 (permalink)
Phoenix's Avatar
As this project get into the real interesting stuff, you might want to put a link to the comments thread in you signature.
I'd like to see what you do with the door panels. There aren't too many people who show indepth interior work on the site. Also, nice to see a non-black interior.
Old 1 Week Ago   #38 (permalink)
opelspyder's Avatar
I will try to add the link for the ccomments section. Your right about the interior, most are not suppling info on that, so we will see. I have some ideas on the door panels for incorporated speakers, but nothing final yet
Keith
Old 1 Week Ago   #39 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
Keith - if you have the time, please post detailed pics and text on the install of the "Oil Temp. / Volt Gauge" from OGTS. I assume you are putting it in place of the clock...
Thanks!
Matt
Other Cars:
Old 1 Week Ago   #40 (permalink)
Project: Restoration of GT...
Very nice work indeed, I may have to try my hand at painting next time. I do believe I could get the use of my friends paint booth which would be very sweet. The process you are going through now is the most tedious part of the rebuild but is also the difference between a car that looks just pretty nice vs. one that looks awesome. Be careful with that dash cap, others have said that it warps in the sun.
markandson is offline   Reply With Quote Top home
'73 GT,5spd,Recaro,EDIS4 2.2 EFI by MegaSquirt,15" Wheels,Lecarra,F&R Sway Bars,Custom Exhaust,1" Sport Spring,Koni Reds,Big Brakes,3 Core Ali Radiator,Hse of Colors Kandy Pagan Gold.
Old 2 Days Ago   #41 (permalink)
Keith;
Where did you get that tool to measure wheel backspacing? Is it plastic or metal?
Old 2 Days Ago   #42 (permalink)
Keith ought to be an old hand with dashcaps as this will be his second install of one.
hrcollinsjr is online now   Reply With Quote Top home
Old 2 Days Ago   #43 (permalink)
Keith;
It looks very much like http://http://store.summitracing.com...5&autoview=sku.
Old 2 Days Ago   #44 (permalink)
opelspyder's Avatar
Or Jegs
Jegs carries them as well, it is plastic-what isn't anymore?
Keith
Old 2 Days Ago   #45 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
My dashcap is still in like new condition a year later. Granted my car is garaged or in covered parking 90% of the time. However, I've had my car parked in the direct sunlight all day in very high temperatures for car shows and, while the plastic did begin to "lift" a little, it went right back to its original shape after cooling down.
Matt
Other Cars:
Old 2 Days Ago   #46 (permalink)
