highschoolopelproject
High School Opel Project
Normal problem with the brake drums hanging up on the axle, use some rust preventative/penetrating oil liberally. After a while rap the drum on the outer edge with a hammer, hopefully it will vibrate the drum loose. I have had to lever it off with a pry bar at times. Before you get to the brake fluid, change the three brake hoses, one at each front wheel and the one on the differential, they have been known to become one-way check valves if they are fairly old. Brake lites could be either the fuse #6, which is next to the outboard in the gang of four fuses, or a wire not connected to the switch on top of the brake pedal. For the blower switch, I would check the wires at the blower for voltage, it could be the blower motor could have trash in it causing it not to turn. HTH.
1971 GT
Not that you shouldn't repair the car properly, but why do you need to get it inspected? Did it come in from out of Province? Do you require AirCare in Westbank? If that is the case, they will only visually inspect the engine (which they won't recognize) and test the emissions.
As for your issues, try to find a real manual or a Destec diagram if your wiring is that messed up.
Since this was imported from Germany, does it have driving lights where the front turn signals(US versions) are or do you have the large round turn signals? Do you have rear side marker lights? Does it have an electric windsheid washer pump which is activated by a button on the turn signal lever? Just wondering if this was an original US car which went to Germany that was shipped back or if it is a Euro spec GT.
It appears to be a US spec car with the turnsignals and side marker lights with reflectors. To determine if the 4 slot wheels are for the GT, it will be stamped GT near one of the slots. They are Opel wheels, but if they didn't say GT on them, then they are from a Manta or Ascona(1900). The GT wheel did have a different offset, but I don't know if the Manta/Ascona rims will cause any problems. The one wheel with many square holes around the rim is from a Chevrolet Vega. They will bolt up, but I don't believe they are a perfect match. I'v seen this on Opels before.
ya I have them on there until I get new tires on the original rims, which do say GT I finally got the drum off the axle, it took a little hammering but i got it
No luck with the break lights or opening the door started brazing the floor in and tig welding the holes where the seat attaches. I really need to get the door open, sould I take the door panel off?
Don't forget to check the head light wiring. The original insulation goes bad leaving bare wires and a potential fire situation. If the PO replaced the wiring it will be OK but confirm this. Check all the wiring from the distributor forward.
Other things that are frequently bad are the rubber in the torque tube donut and front suspension. Repalcement parts are available for Opel GT source. |
5 Car garage
I've got a car I recently imported from the US into BC. My understanding is the inspection will cover all items that will make the car safe. Brakes....steering....lights.....windshield wipers etc. Bacically fix everything that has any connection with safe operation of the vehicle and she should pass the test.
I'm still trying to get my car sorted for tyhe test so I can't comment on specifics. Sorry.
1971 Opel GT (a sad little car in need of a total restoration) |
#11 (permalink) | |
HTH, Harold |
The brake light work
but I can't get the door open how can I open in manualy I had it open by wiggling the lock mecanism and pushing the door button at the same time, but i had to close it at the end of class and now it wont open again.
For the new matal where the seats bolt on. Instead of drilling a hole then welding a nut to the bottom in the exact place it needs to be to line up, I just welded a small quarter inch plate the the bottom of the new sheat metal roughley in the area it needed to be. Then I used the seats to mark out the holes once it was all welded in, grinded down ect. and drilled it with a hand drill then ran some a taps. Beats all that measureing and it fits prefect
light bulb problems
I have these fog lights on the front of my car and there is a light bulb, one of them is burnt out so I went on the search for one at the local Lordco but it came up unsuccessful. There is no part # or writing on it so I am out of luck. Any guess on the type of fog lights or the type of bulb?
#17 (permalink) | |
HI,
I wonder if I know your shop teacher, ask if he/she knows James at BCIT. What grade are you in? hopefully you have more than just the rest of this school year to work on it! Anyways, the BC inspection is fairly straightforwards, as mentioned they check for safety items - lights and signals, brakes, steering, suspension, tire wear, and so on. There is a provincial inspection and also a federal. Canadian Tire, believe it or not, is the standard for Federal testing, and they do provincial inspections too. I'm not recommending them, but they will be able to answer any specific questions you have regarding inspection. BTW, euro-spec cars as old as ours are no problem. We have different regulations than the U.S. To my knowledge, there is no emissions inspection in Westbank, it's a lower mainland thing only. Your door problem does sound like the lock mechanism. If you can get the panel off, you will be able to reach into the door and unlock/lock it. When you get it open, check to make sure the striker plate is not loose, that can cause things to jam up. Good luck with your project! jtb |
Into inspection and on the road soon
I find my neighbor owns a shop and can do inspection. which came in handy when it didnt pass inspection, it needed a rack and pinion bushing, but I got the from opel gt source and all is good. because I know him I didnt need to pay for two inspections, which helps the hole in my wallet. It will pass and once I get it registered it will be another opel on the roads. Not to soon after I get it on the road it is going to be taken appart and preped for paint.
#20 (permalink) |
this might be french bulbs. thought they were not longer produced but i find out i was wrong. think i can get you those bulbs. you can send me an email if you want. what i would need would be a good pic. maybe you can messure it or at least lay a ruler next to so that i can imagine the size.
