Go Back   The Classic Opel Forums > Technical Forums > Tech Links and Data > Opel Tech Articles
Opel Tech Articles Post article submissions , Tech Specs., FAQ's, Thread Links, etc here. They will be moved to the appropriate section.
Old 04-12-2009   #1 (permalink)
Uber Genius
First opel 1981's Avatar
Fuel vent line rethink.
I have been debating on whether or not to leave this issue within the thread on fuel vent lines but think it deserves its own thread.
I was running the fuel vent lines on my 73 GT and noticed something that I, personally, think is a major issue.
I was using the diagram from http://clubs.hemmings.com/clubsites/...h/TankVent.pdf and realized that when the fuel tank is full, or close to full, there would be a tendency for liquid fuel to enter the vent lines, only to be expelled to the charcoal canister. I don't think this is what was intended.
I have made a small modification to the vent line routing and, again personally, feel this is how the fuel vent lines should be run.
Here is the original
Attachment 21476
And here is the proposed revision
Attachment 21477
I believe this small change will prevent any liquid fuel from venting from the fuel tank.
Anyone who has noticed a fuel smell from the front of their GT, that they can't trace, might benefit from this.
Discussions are most welcome.
First opel 1981 is offline
Old 04-12-2009   #2 (permalink)
There is another thread here (and probably more) on this subject. There are a couple of really important points concerning the venting of the tank. First is the "T" that goes at the top of the whole system. This is not just a regular tee it has a very small orifice in the leg that goes up to the canister making difficult for any excessive amount of liquid to go forward. Secondly it also limits the amount of vacuum that the tank can see. The two vent lines from the tank are supposed to be attached at the top of the body just below the rear window.
If you get in where the tank goes and look up you will see bend tabs that are designed to hold the hoses. With the hoses that high above the tank the car would have to be upside down before any liquid could flow forward to the canister. HTH
Old 04-12-2009   #3 (permalink)
Uber Genius
I used to be able to fit in there. These GTs shrink over the years.
I understand what you are saying though. There is a big IF in there. The IF is if the fuel lines are run up to the body first and I see your point. The way I have them would essentially do that even if the lines are closer to the tank.
I never did like seeing the vent lines hanging from the base of the back deck. It looked a little clumsy to me.
Quick question, if you don't mind. Which way should the small hole be oriented. Towards the tank or towards the charcoal canister?
A side note: The way you describe the routing is the way I propose the diagram should be changed. This thread is dedicated to the change in the diagram and not solely about the routing of the vent lines.
Old 04-12-2009   #4 (permalink)
The leg of the tee with the orifice in it goes to the canister.
Old 04-12-2009   #5 (permalink)
blancojp's Avatar
I have never had this type of problem since the first thing I do on any new Opel is to get rid of the canister.
I route the vent line upwards from the filler tube connection and then loop it down to a "tee" back to the vent lines in the rear of the tank. I believe the Manta and Asconas do the same route with their vent lines, at least the Ascona I have was done that way when I got it. As long as the vent line is rising to a point higher than the filler neck, fluid works its way back so nothing will go forward.
Considering the amount of cars I have built, I don't believe removing the canister is a big loss anyway.
JB
'70 Opel GT - 4 speed "Lucy"
blancojp is offline
Old 04-12-2009   #6 (permalink)
Uber Genius
The canister is only for environmental reasons. What the charcoal canister does is trap (temporarily) gasoline fumes recovered from the venting of the fuel tank. When the car is running it is supposed to draw air into the charcoal canister and pull the trapped gasoline fumes (OK, technically chemicals) into the combustion chamber where it burns.
Removing the canister shouldn't hurt perfomance but you are then dumping raw gasoline fumes into the atmosphere.
Not on a soapbox by any means, just explaining the function of the charcoal canister as I know it.
Old 04-12-2009   #7 (permalink)
blancojp's Avatar
Thanks for the info but like I said, no big loss.
JB
blancojp is offline
Old 04-12-2009   #8 (permalink)
If your worried about environmental concerns. The last car you'll want is the 68-73 Opels. These where very dirty cars to start with. CO was set at 3.0% HC 400ppm and the evap. system was terrible.
By today's standards there "gross" polluters and need to be removed from the roadway.
Old 04-13-2009   #9 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
Real Name: Matt
...By today's standards there "gross" polluters and need to be removed from the roadway.
Bite your tongue Dan!
'72 Opel GT (Fireglow Orange)
Restoration Thread
Comments Thread
Other Cars:
newman27 is offline
Old 04-13-2009   #10 (permalink)
Nathan Acree
I am actually putting the charcoal cannister back on my car for a simple reason- Its keeps the garage from smelling like a gas can. Something to think about anyway.
Nathan Acree is offline
Old 04-13-2009   #11 (permalink)
I put a new canister in my car that came from another vehicle. I don't remember the application but I do have the part number of the canister at home if anyone wants it. The diameter of the new part is slightly more than the old one. I shaved the plastic down around the end and it was a nice press fit into the original end closure/bracket. The bracket that attaches it to the body was also too small so I cut an extra one that I had and welded a piece into the one I wanted to use, you can't tell what I did if you look at the bracket now after a little grinding and painting.
Old 05-09-2009   #12 (permalink)
Uber Genius
Fuel vent rethink and overkill completed
After careful consideration and the desire to use my new tubing bender, I decided that I would re-do the gas tank vent lines so they will NEVER leak again.
Using 5/16 steel brake line tubing and a LOT of hose clamps, I ran the new vent lines in steel. The front vent can't be seen in the picture but it snakes under the package shelf support to the back of the tank where it goes up to the tee. I vented both the front and rear tank vents to a tee and then up to the neck tee. The neck tee is the highest point (as I am confident it should be) of the venting system. From there I ran a second tube down and out of the car to finally exit to the charcoal canister.
The steel lines might be overkill but I am certain I will NEVER smell gas in the car again.
Old 05-09-2009   #13 (permalink)
I hope you included the tee with the orifice in it, did you?
Old 05-09-2009   #14 (permalink)
Uber Genius
Both tees have the original orifices.
I like orifices....
