| Opel Tech Articles Post article submissions , Tech Specs., FAQ's, Thread Links, etc here. They will be moved to the appropriate section. |
LinkBack (1) | Thread Tools | Display Modes |
#1 (permalink)
English-*-Nederlands-*-Deutsch-*- 4-star (fuel grade) -*-super benzine-*- ABDC (after bottom dead center)-*-na onderste dode punt (NODP)-*- ABS braking device-*-anti blokkering remsysteem-*- absorber-*-absorptie materiaal-*- ac generator-*-wisselstroom dynamo-*- accelerator-*-gaspedaal-*- accelerator cable-*-gaskabel-*- accelerator pedal-*-gaspedaal-*- accelerator pump-*-acceleratie pomp-*- accumulator-*-accu-*- acid-*-(accu)zuur-*- acid level-*-zuurniveau (in accu)-*- acorn nut-*-kapmoer-*- adapter-*-adapter / tussenstuk-*- adhesion-*-hechten / grip-*- adjust-*-regelen / stellen-*- adjustable spanner-*-verstelbare steeksleutel (Bahco)-*- adjuster-*-verstelinrichting-*- adjuster strut-*-verstelbare steun / poot-*- adjustment bold-*-stelschroef / bout-*- adjustment ferrule -*-verstelbaar snij gereedschap-*- adjustment link-*-verstelbare verbinding-*- adjustment rod-*-stang met schroefdraad-*- advance ignition-*-ontsteking vervroegen-*- aerial aerodynamic drag (factor)-*-antenne luchtweerstand (coëfficiënt)-* air adjusting screw-*-luchtregelschroef-*- air bleed valve-*-ontluchtingsklep-*- air chamber-*-luchtkamer-*- air cleaner-*-luchtfilter-*- air compressor-*-lucht compressor-*- air conditioning-*-klimaatregeling-*- air conditioning control unit (airco)-*-klimaatregeleenheid (airco)-*- air control-*-lucht regeling-*- air cooling-*-luchtkoeling-*- air correction jet-*-luchtregelsproeier-*- air deflector-*-luchtgeleider-*- air distribution switch-*-zomer en winterstand luchtfilter-*- air filter-*-luchtfilter-*- air flap valve-*-luchtklep-*- air flow sensor-*-luchtsnelheidsmeter-*- air funnel-*-luchtkanaal-*- air leak-*-luchtlek-*- air resistance-*-luchtweerstand-*- air temperature control system-*-luchtthermostaat-*- air temperature sensor-*-lucht temperatuur voeler-*- airbag-*-airbag-*- airflow meter-*-luchthoeveelheids meter-*- airflow sensor plate-*-plaat van de luchthoeveelheids voeler-*- alcohol-*-alcohol / metanol-*- allen key-*-inbussleutel-*- allen screw-*-inbusbout-*- alloy-*-legering-*- alternating current (AC)-*-wisselstroom (AC)-*- alternator-*-wisselstroomdynamo-*- alternator pulley-*-snaarschijf van de dynamo-*- aluminium-*-aluminium-*- ampmeter-*-ampere meter-*- analogue clock-*-klok met wijzerplaat-*- anti-clockwise-*-tegen de wijzers van de klok in-*- anti-lock braking system (ABS)-*-anti blokkeer remsysteem (ABS)-*- anti-roll bar-*-stabilisator stang-*- anti-rust-*-anti-roest-*- anti-stall-*-inrichting tegen stilvallen motor-*- anti-theft system-*-alarm systeem-*- antifreeze-*-anti vries-*- armature-*-kompleet anker (ac)-*- armature spindle-*-anker as-*- armature winding-*-anker winding-*- asbestos-*-asbest-*- ATDC (after top dead center)-*-voorbij bovenste dode punt-*- authorised towing weight-*-max. aanhangwagen gewicht-*- Automatic adjustment mechanism-*-automatische regeleenheid-*- automatic advance-*-automatische verstelling (voorontsteking)-*- automatic transmission filter-*-filter van de automatische versnellingsbak-*- auxiliary shaft-*-hulp-as-*- auxiliary shaft housing-*-hulp-as behuizing-*- axle-*-as-*- axle stand-*-as steun-*- B backlash-*-stelruimte-*- backplate-*-ankerplaat-*- balance weight-*-balanceer gewicht-*- ball bearing-*-kogellager-*- ball-bearing grease-*-lagervet-*- ball plain hammer-*-bolhamer-*- ball race-*-lager (kogel)-*- ball trust bearing-*-druklager-*- ball valve-*-kogelklep-*- ball-head bolt-*-kogelbout-*- balljoint-*-kogelverbinding-*- balljoint separator-*-kogelverbinding trekker / scheider-*- barrel (of carburettor)-*-aanzuigbuis / hulp venturi-*- base-*-basis / onderkant / bodem-*- baseplate-*-grondplaat-*-grund platte-*- battery-*-batterij / accu-*- battery cable-*-accu kabel-*- bayonet joint-*-bajonet sluiting-*- bayonet socket-*-bajonet fitting-*- bdc (bottom dead centre)-*-onderste dode punt (ODP)-*- bbdc (before bdc)-*-voor ODP-*- be in close contact -*-tegen elkaar aan liggen-*- bead-*-hiel van de band-*- beam-*-balk-*- bearing-*-lager (compleet)-*- bearing cap-*-lagerkap-*- bearing journal-*-lager op niet meedraaiende as-*- bearing ladder-*-opeen volgende lagers-*- bearing plate-*-lager schild / plaat-*- bearing race-*-cirkel van lagerkogels-*- bearing shell-*-lager huis-*- bearing surface-*-lager loop / lager oppervlakte (glij)-*- bell crank-*-vlak haakse overbrenging-*- bellow-*-balg-*- belt-*-(V-)snaar / riem-*- belt deflection-*-snaar indrukbaarheid-*- belt drive-*-snaaraandrijving-*- belt tensioner-*-snaarspanner-*- bent-*-gebogen-*- bevel (gear)-*-schuine vertanding-*- bevel pinion-*-cardanas tandwiel (pinion)-*- bevel ring gear-*-druklager-*- bezel-*-koplampsierring-*- bi-metalstrip-*-bi-metaalstrip-*- big-end bearing-*-grootste drijfstanglager-*- blade terminal-*-platte stekker-*- bleed-*-ontluchten-*- bleed screw-*-ontluchting schroef-*- blow-back-*-terugslag in carburateur-*- blow-by-*-lekkage-*- blower body -*-compressor huis / carroserie-*- body pillar-*-carrosserie stijl-*- bodyshell-*-carrosserie-*- bodywork-*-plaatwerk-*- bonded brake linings-*-gelijmde remvoering-*- bonnet-*-motorkap-*- booster battery-*-hulpaccu-*- boot-*-kofferbak-*- bore-*-(binnen) diameter-*- bottom dead centre (bdc)-*-onderste dode punt (ODP)-*- box spanner-*-ringsleutel-*- brace bracket-*-band, steun beugel, steun-*- braided cable-*-gevlochten kabel-*- brake-*-rem-*-bremse-*- brake adjustment-*-rem afstelling-*- brake anchor plate -*-rem anker plaat-*- brake bleeding-*-remontluchten-*- brake calliper-*-remklauw-*- brake disc-*-remschijf-*- brake drum-*-remtrommel-*- brake fluid-*-remvloeistof-*- brake hose clamp-*-remslangklem-*- brake light-*-remlicht-*-bremslicht-*- brake light switch-*-remlichtschakelaar-*- brake lining wear indicator-*-remblok slijtage waarschuwings lampje-*- brake linings-*-remvoeringen-*- brake master cylinder-*-hoofdremcilinder-*- brake pad-*-remblok-*- brake pedal-*-rempedaal-*- brake servo-*-rembekrachtiger-*- brake shoe-*-remschoen-*- braked trailer-*-geremde aanhanger-*- braking system-*-remsysteem-*- brazing-*-(hard)solderen-*- breaker points-*-contact punten-*- breaker / contact breaker-*-contact onderbreker-*- breather-*-beluchter-*- breather hose-*-beluchter slang-*- broach-*-ruimen-*- brush-*-borstel-*- brush holder-*-borstel houder-*- btdc-*-voor bovenste dode punt (VBDP)-*- buckling-*-knikken / vervormen-*- built-in-*-ingebouwd-*- bulb-*-gloeilamp-*- bulge-*-bult / bobbel-*- bulkhead-*-schutbord-*- bulkhead grummet-*-schutbord doorvoerrubber-*- bumper-*-stoot stang / bumper / aanslag-*- burr-*-braam / gietnaad-*- burst-proof-*-explosie-proof-*- bush-*-bescherming-*- butterfly valve-*-vlinder klep-*- buzzer-*-zoemer-*- by-pass-*-omleiding-*- C c-spanner-*-steeksleutel-*- cable-*-kabel / (elektra) draad-*- cable adjuster-*-kabel spanner-*- cable casing-*-plaats waar de kabel in- of door gaat-*- cable clamp-*-kabel klem-*- cable cutter-*-kabelsnijtang-*- cable grommet-*-kabel beschermrubber-*- cable pulier-*-kabeltrekker-*- cabriolet-*-cabriolet-*- calibrated-*-geijkt-*- caliper-*-remklauw-*- cam-*-nok-*- cam follower-*-nokvolger-*- cam plate-*-onderbreker houder-*- camber-*-wielhelling-*- camshaft-*- nokkenas-*- camshaft bearing-*-nokkenaslager-*- camshaft cover-*-nokkenas beschermkap-*- camshaft endfloat-*-nokkenas eindspeling-*- camshaft gear-*-nokkenas aandrijving-*- camshaft pinion-*-nokkenas aandrijf tandwiel-*- camshaft sprocket-*-nokkenas (lager) houder-*- canister-*-jerrycan-*- cantilever-*-bedienings arm-*- cap-*-kap/dop-*- cap nut-*-dopmoer-*- capacitative discharge-*-capacitative ontlading-*- capacitor-*- condensator-*- capless bulp -*-gewoon lampje-*- car radio-*-autoradio-*- carbon brush-*-koolborstel-*- carbon deposit-*-koolaanslag-*- carbon removing (decoke)-*-koolaanslag verwijderen-*- carborundum-*-schuurmiddel-*- carburettor-*-carburateur-*- carburettor bowl-*-vlotterkamer-*- carburettor jet-*-sproeier-*- cardan joint-*-cardankoppeling-*- cardan shaft -*-cardanas-*- casing-*-lagerhuis-*- cast-*-giet(vorm)-*- cast iron-*-gietijzer-*- castellated nut-*-kroonmoer-*- casting-*-gieten castle nut-*-kroonmoer-*- castor-*-askanteling-*- catalytic converter -*-catalisator-*- catch-*-vangen-*- caustic soda-*-etsmiddel-*- caution-*-waarschuwing-*- central console-*-middenconsole-*- central locking system-*-centrale portier vergrendeling-*- centralised door locking-*-gecentraliseerde portier vergrendeling-*- centre line-*-middenlijn-*- centre of gravity-*-zwaartepunt-*- centre of rotation-*-rol-punt-*- centre punch-*-markeer punt / teken-*- chain and sprocket-*-ketting en kettingwiel-*- chain case-*-kettingkast-*- chain joint-*-ketting verbindingsschakel-*- chain sprocket-*-kettingwiel-*- chain tensioner-*-kettingspanner-*- chain whip-*-slingeren van ketting-*- chamber-*- kamer-*- chamfer-*-groef, schuine kant -*- change-over switch-*-wisselschakelaar-*- change down-*-omlaag / terugschakelen-*- change gear -*-schakelen(versnelling)-*- change up-*-omhoog / opschakelen-*- changing of oil-*-olie verversen-*- charger-*-(accu)lader-*- charging-*-opladen-*- Charging control lamp-*-laadcontrole lamp-*- Charging current-*-laadstroom-*- charging rate-*-laad snelheid-*- check -*-controleren-*- check nut-*-borgmoer-*- check valve-*-controle klep / ventiel chisel-*-beitel-*- choke-*-choke-*- choke (cold start valve)-*-koude start klep-*- choke linkage-*-choke kabel verbinding-*- choke valve gap-*-chokeklep spleet-*- chrome plated-*-verchroomd-*- cigar lighter-*-sigaretten aansteker circlip-*-borgveer-*- circuit breaker-*-stroom onderbreker-*- circuitdiagram-*-elektrisch schema-*- clamp-*-klem-*- clamp bolt / screw -*-klembout / schroef-*- clamp bracket screw-*-klembevetsigings schroef-*- clamping washer-*-veerring-*- clatter-*-ratelen-*- claw-*-klauw-*- cleaner-*-reiniger / schoonmaker-*- clearance-*-speling / ruimte-*- clevis pin-*-vorkvormige pen-*- clicking-*-klikken-*- clip-*-klip / klem-*- clockwise-*-met de richting van de klok mee-*- clutch-*-koppeling-*- clutch disk-*-koppelingsplaat-*- clutch hub-*-koppelingsplaat naaf-*- clutch lining-*-koppelingvoering-*- clutch pedal-*-koppelingspedaal-*- clutch pressure plate-*-koppelings drukplaat-*- clutch plate alignment plate-*-koppelingscentraliseer gereedschap-*- clutch slip-*-koppeling slip-*- coarse adjustment -*-grove regeling-*- coil-*-bobine, spoel, spiraal-*- coil ignition-*-bobine ontsteking-*- coil spring-*-spiraalveer-*- compressor-*-compressor-*- cold chisel-*-koudbeitel-*- collapsible-*-inklapbaar-*- collar-*-kraag / flens-*- collar screw-*-kraagbout-*- collets-*-ringen / beugels-*- combination pliers -*-combinatietang-*- combination spanner-*-combinatiesleutel-*- combustion-*-verbranding-*- combustion chambers-*-verbrandingskamer-*- commutator-*-collector-*- compensating jet-*-compensatie sproeier-*- compression-*-compressie-*- compression gauge-*-compressiemeter-*- compression ratio-*-compressieverhouding-*- compression ring-*-compressie(zuiger)veer-*- compression tester-*-compressie tester-*- computer-*-computer (ECU)-*- condenser (capacitor)-*- condensator-*- condenser (thermodynarnic)-*-condensor conduit-*-bescherm pijp / mantel / goot cone-*-konische pen/deel-*- conical-*-konisch-*- connect-*-verbinden / aansluiten-*- connect in parallel-*-parallelschakelen-*- connect in series-*-serieschakelen-*- connecting box-*-aansluitdoos-*- connecting clamp-*-verbindingsklem-*- connecting link-*-aansluitpunt-*- connecting rod-*-zuigerstang-*- connecting rod bearing-*-zuigerstanglager-*- connection-*-verbinding-*- connector-*-stekker-*- constant voltage-*-constante spanning-*- constand-velocity joint-*-homokinetische koppeling-*- contact area-*-contactvlak-*- contact breaker-*- onderbreker-*- contact breaker points-*-onderbrekerpunten / contact punten-*- continuity tester-*-continuiteitstester-*- continuous current-*-continu stroom-*- control-*-controle-*- control unit-*-controle eenheid-*- coolant-*-koelvloeistof coolant bleed screw-*-koelsysteem ontluchtingsschroef-*- coolant hose-*-koelwaterslang-*- coolant pump-*-koelwaterpomp-*- cooler-*-radiator-*- cooling fan switch-*-ventilatorschakelaar-*- cooling fin-*-ventilatorvin-*- cooling system-*-koelsysteem-*- cooling system flushing-*-koelsysteem doorspoelen-*- copper gasket-*-koperenpakking-*- core plug (cylinder block)-*-vriesplaatje-*- corrosion-*-corrosie / roesten / oxideren-*- counterbalance-*-tegen balans-*- counterclockwise-*-linksomdraaiend-*- counterbore-*-verzonken-*- countergear-*-tandwiel van secundaire as-*- countershaft-*-secundaire as van versnellingsbak-*- counterweight-*-contra gewicht-*- coupling-*-koppeling-*- covering-*-bedekken-*- crack-*-scheur / barst-*- crankcase-*-krukas kast-*- crankcase bearing-*-krukaslager-*- crankcase filter-*-carterventilatie-filter-*- crankcase ventilation-*-carterventilatie-*- cranking-*-ronddraaien-*- crankpin-*-krukpen-*- crankpin bearing-*-krukpenlager-*- crankshaft-*-krukas-*- crankshaft bearing (main)-*-krukas hoofdlager-*- crankshaft bearing-*-krukaslager-*- crankshaft bearing journal-*-krukas taplager-*- crankshaft endfloat-*-axiale krukas speling-*- crankshaft pulley-*-krukas poelie-*- crankshaft sprocket-*-krukas kettingwiel-*- crankshaft web-*-krukwang-*- crimped-*-geperst-*- crimping tool-*-pers gereedschap-*- cross-flow engine-*-motor met de uit- en inlaat tegenover elkaar-*- cross-flow radiator-*-radiator met de uit- en inlaat tegenover elkaar-*- crownwheel-*-kroonwiel (grootste wiel van een stel)-*- cruising-*-toeren-*- cruising speed-*-kruissnelheid-*- crumple zone-*-kruikelzone-*- cubic capacity-*-inhoud-*-inhalt-*- current consumption-*-stroomverbruik curve-*-buigen / kromming / bocht cut off-*-snij af / knip af-*- cut-out relay-*-stop relais-*- cut-outs-*-stoppen / afbreken / uitschakelen-*- cylinder barrel-*-cilinder-*- cylinder block-*-cilinderblok-*- cylinder bore-*-cilinderboring / diameter-*- cylinder head-*-cilinderkop-*- cylinder head bolt-*-cilinderkopbout-*- cylinder head cover-*-kleppendeksel cylinder head gasket-*-koppakking-*- cylinder liner (sleeve)-*- cilinderbus-*- cylindrical spring-*-spiraalveer-*- D damp-*-vochtig-*- damp-proofing sealant-*-waterbestendig kit damper (shock absorber)-*-schokdemper damper spring-*-demperveer-*- dashpot-*-trillingsdemper-*- DC (direct current) -* -DC (gelijkstroom) -*- dead centre-*-middel punt-*- decarbonization-*-ontkolen-*- declutch-*-ontkoppelen-*- defect -*-niet werkend / kapot / defekt-*- deflector (luchtstroom)-*-afbuigplaat-*- defuming valve-*- vlam onderbreekklep-*- degassing chamber-*-ontgassing kamer-*- degassing pipe-*-ontgassing slang-*- deionised water-*-gede-ioniseerd water-*- delivery-*-toevoer-*- delivery pipe-*-toevoerleiding-*- delivery valve-*-toevoerklep-*- delta connection-*-drie hoek schakeling-*- demister-*-ruitontwaseming-*- dent-*-deuk-*- deposit-*-afzetting (vuil)-*- depress-*-druk verminderen-*- depth gauge-*-dieptemeter-*- detent-*-blokkeer-*- detent ball-*-blokkeerkogel-*- diagnostic connector-*-diagnose stekker-*- dial gauge-*-wijzer klok (analoog)-*- dial test indicator-*-test meter (met wijzerplaat)-*- diaphragm-*-membraam-*- diaphragm accelerator pump-*-membraam acceleratiepomp-*- diaphragm clutch-*-diafragma koppeling-*- diaphragm cover-*-diafragma huis-*- diaphragm unit-*- komplete koppelingseenheid-*- die casting-*-mal gieten-*- die nut-*-snij ijzer (schroefdraad)-*- die stock /die holder-*-wring ijzer-*- diesel engine-*-dieselmotor-*- diesel fuel-*-dieselbrandstof-*- differential-*-differentieel-*- differential case-*-differentieelhuis-*- differential crown gear-*-kroonwiel (grootste tandwiel)-*- differential pinion-*-pinion (kleinste tandwiel)-*- differential side gear-*-planeetwiel van differentieel-*- digital clock -*-digitale klok-*- dim-*-dimmen-*- dimmer relay-*-dimlichtrelais-*- dimmer switch-*-dimlichtschakelaar-*- dipped light-*-gedimd groot licht-*- dipstick-*-peilstok-*- direct drive-*-direkte overbrenging-*- direction indicator-*-richting aanwijzer dashboardlampje-*- discbrake-*-schijfrem-*- discharge-*-ontladen-*- discharged battery-*-lege accu-*- disconnect-*-losmaken / verbreken-*- dished washer-*-schotelring-*- dismantle-*-demonteren-*- displacement dissipate-*-(motor)inhoud verliezen / verspilling-*- dissolve-*-oplossen-*- distance piece-*-afstands stuk-*- distributor-*-verdeler-*- distributor advance-*-verdeler vervroeging-*- distributor cap-*-verdeel kap-*- distributor injection pump-*-verdeler inspuitpomp-*- distributor shaft / spindle-*-verdeler as-*- distributor test bench-*-verdeler testbank-*- distributorless ignition-*-verdelerloze ontsteking-*- dohc (double overhead camshaft)-*-dubbele bovenliggende nokkenas-*- dome-*-bolvormige verhoging / koepel-*- domed nut-*-bolvormige moer-*- door-*-portier / deur-*- door light switch-*-binnen verlichting schakelaar-*- dowel-*-(pas)pen-*- down pipe-*-uitlaatpijp na uitlaatspruitstuk-*- down draft / draught-*-valstroom-*- downstroke-*-neergaande slag-*- drag coëfficiënt-*- luchtweerstand coefficient-*- drain-*-aftap punt-*- drain cock-*-aftapkraan-*- drain plug-*-aftapplug-*- drain the battery-*-accu leeg maken-*- draw (electric current)-*-vonk trekken-*- dribble-*-nadruppelen-*- drift-*-af drijven / doorslag-*- drift-punch-*-doorslag-*- drill-*-boor / boren-*- drip feed-*-druppel voeding / lader drive end-*-aangedreven zijde-*- drivebelt-*-aandrijfriem-*- drivegear -*-aandrijf tandwiel(en)-*- driven plate-*-koppelingsplaat-*- driveplate-*-tandkrans-*- driveshaft-*-aandrijfas-*- driveshaft gaiter-*-aandrijfas eindstuk-*- driveshaft joint-*-aandrijfas koppelstuk-*- driving gear-*-aandrijvend tandwiel-*- driving pinion-*-meeneempen-*- drum brake-*-trommelrem-*- dry cell battery-*- droge cel batterij-*- dry charged battery-*-overladen / droog gekookte accu-*- dry sump lubrication-*-motorsmering zonder carter-*- dual carburettor-*-dubbele carburateur-*- dual circuit hydraulic system-*-gescheiden hydraulisch (rem)systeem-*- dual circuit master cylinder-*-dubbelwerkende hoofd(rem)cilinder-*- ductile-*-buigbaar-*- durability-*-duurzaamheid-*- dust cap / cover-*-stofkap-*- dust excluding boot-*-stofdichte hoes-*- dust proof-*-stofdicht-*- dwell angle / cam angle-*-contacthoek dynamo-*-dynamo-*- dynamometer brake-*-remmentestbank-*- E earth (-)-*-aarde (- massa)-*- earth connection-*-aarde / massa verbinding-*- earth electrode-*-massa elektrode (bougie)-*- earth strap-*-aardingspunt-*- eccentricity / ovality-*-excentrisch / ovaal-*- edge-*-rand / hoek-*- effective output-*-effektief vermogen-*- efficiency elbow-*-werkingsgraad bocht-*- electric cooling fan-*-elektrische koelventilator-*- electric fan-*-elektrische ventilator-*- electric fuel pump-*-elektrische brandstofpomp-*- electric screen water pump-*-electrische ruitensproeierpomp-*- electric windows-*-electrisch bediende ramen-*- electrical solenoid valve--*elektrische magneetklep-*- electrode gap-*-elektrode afsland-*- electronic control unit-*- elektronische regeleenheid-*- electronic ignition system-*-elektronisch ontstekingssysteem-*- elliptic-*-ovaal-*- emery-*-polijstmiddel-*- emission control system-*-uilaatgasemissie controlesysteem-*- empty weight-*-leeggewicht-*- emulsion tube-*-luchtmengselsproeier / meng pijp-*- enamel-*-verf / lak-*- end float-*- axiaal speling-*- engine-*-motor-*- engine mounting-*-motor ophanging-*- engine oil cooler-*-motorolie koeler-*- engine oil level dipstick-*-oliepeilstok-*- engine speed-*-motortoerental-*- engine timing-*-motorafstelling-*- engine torque-*-motor koppel-*- engineering hammer-*-zachte(koperen) hamer-*- estate car-*-stationwagen-*- excess pressure-*-overdruk-*- exchange engine-*-ruilmotor-*- excitation diode-*-magnetiseringsdiode-*- exhaust-*-uitlaat-*- exhaust expansion box-*-expansietype uitlaatdemper-*- exhaust silencer-*-uitlaatdemper-*- expansion tank-*-expansievat-*- expansion valve-*-expansieklep-*- explosive mixture-*-explosief mengsel-*- extractor-*-trekker-*- eye-*-oog-*-auge-*- F facia-*-dashboard-*- failure-*-weigering (van motor) / storing-*- fan-*-ventilator-*- fan belt-*-ventilatorriem-*- fast idle-*-versneld stationair-*- fasten-*-vast zetten / draaien-*- fastener-*-tang / sleutel-*- fault-*-fout-*- fault diagnosis-*-foutdiagnose-*- feed pipe-*- voeding / toevoer leiding/pijp-*- feeler blade (gauge)-*-voelermaat-*- felt washer-*-vilten pakkingring-*- female thread-*-inwendig draad-*- fender-*-spatbord / stootkussen / blok-*- fibre washer-*-fiber ring-*- field coil/winding-*-veldspoel/winding-*- field current -*-veldstroom-*- file-*- vijl / vijlen-*- filler cap-*-vuldop-*- filler tube-*-vulbuis-*- filter element-*-filter element / patroon-*- filter magnet-*-filter mageet-*- final drive-*-eindaandrijving-*- firing order-*-ontstekingsvolgorde-*- firing stroke-*-arbeids (ontsteek) slag firing voltage-*-onstekings spanning fittings-*-accessoires-*- fixed jet-*-vaste sproeier-*- fixed pivot-*-vast draaipunt-*- flammable-*-brandbaar-*- flap-*-flap-*- flasher relay -*-knipper relais-*- flasher unit-*-knippereenheid-*- flat tire-*-lekke / platte band-*- flexible brake hose-*-flexibel remslang-*- float-*-vlotter / drijver-*- float arm fulcrum-*-vlotterarm scharnierpen-*- float chamber-*-vlotterkamer-*- float level-*-vlotterniveau-*- fload needie-*-vlotternaald-*- fload pivot-*-vlotterscharnierpunt-*- flood-*-(over)lopen/vloeien-*- fluid-*-vloeistof-*- fluid coupling-*-vloeistof koppeling-*- fluid pressure-*-vloeistofdruk-*- flywheel-*-vliegwiel-*- flywheel marking-*-merkteken op vliegwiel-*- foglight-*-mistlicht-*- follower-*-volger-*- forced lubrication-*-druksmering-*- fore and aft-*-voor en achter-*- four-stroke-*-viertakt motor-*- four-wheel drive-*-vierwielaandrijving-*- free movement-*-vrije slag-*- free play-*-te groot vrije slag / speling-*- free travel-*-vrije slag /vrij bewegend-*- frequency-*-frequentie-*- friction-*-wrijving-*- friction linings-*-koppelingvoering-*- front axle-*-vooras-*- front wheel drive-*-voorwielaandrijving-*- fuel-*-brandstof-*- fuel consumption-*-brandstofverbruik fuel feed pipe-*-brandstof toevoer leiding-*- fuel filler pipe-*-brandstof vul leiding-*- fuel filter-*-brandstoffilter-*- fuel gauge sender-*-tank meter opnemer-*- fuel injection-*-brandstof injectie-*- fuel inlet hose-*-brandstof vulslang-*- fuel line-*-brandstof leiding-*- fuel mixture-*-brandstof lucht mengsel-*- fuel pump-*-brandstof pomp-*- fuel rail-*-brandstof rail-*- fuel return pipe-*-brandstof retourleiding-*- fuel supply line-*- branstof voedingleiding-*- fuel tank-*-brandstof tank-*- fulcrum-*-draaipunt-*- full throttle enrichment-*-volgas mensel verrijking-*- full-flow oil filter-*-hoofdstroom olie filter-*- funnel-*-trechter-*- fuse-*-zekering-*- fuse box-*-zekering doos-*- fusing point -*-smeltpunt-*- G gaiter-*-bekleding-*- gas-*-gas / benzine gasoline-*-benzine-*- gear-*-versnelling-*- gear change-*-van versnelling veranderen-*- gear component-*-onderdeel van versnelling (bak)-*- gear lever boot-*-vernellingspook afdichticht rubber-*- gear lever knob-*-versnellingspook knop-*- gear linkage-*-verbinding / bediening mechanisme-*- gear ratio-*-versnellingsverhouding-*- gear selector-*-schakelmechanisme-*- gear teeth-*-tanden van tandwiel-*- gear train-*-set tandwielen-*- gearbox-*-versnellingsbak-*- gearbox drain plug-*-versnellingsbak aftapplug-*- gearbox housing-*-versnellingsbakhuis-*- gearshift lever-*-versnellingspook generator-*-generator-*- glovebox-*-dashboardkastje-*- glow plug-*-gloei bougie-*- glow plug tips-*-gloei bougie elektroden-*- grabbing (clutch, brake)-*-aangrijpen van koppeling / remmen-*- gravity-*-zwaartekracht-*- grease-*-vet-*- grease gun-*-vetspuit-*- grease nipple-*-vetnippel-*- grease retainer-*-houder voor vet-*- grinding-in(valve)-*-inslijpen (van klep)-*- groove-*-groef-*- gross vehicle weight-*-totaal autogewicht-*- ground-*-aarde / min / massa-*- ground clearance-*-grondspeling-*- grub screw-*-kartelmoer-*- gudgeon pin-*-geleide pen-*- guide sleeve-*-geleide gleuf-*- H hacksaw-*-ijzerzaag-*- half-casting-*-niet afgewerkt gietstuk-*- Hall sender-*-hall zender-*- hand operated-*-handbediend-*- hand primer-*-hand opvoerpomp / primer-*- handbrake-*-handrem-*- handbrake cable-*-handremkabel-*- handbrake lever-*-handremhendel-*- handle-*-hendel-*- hatchback-*-derde / vijfde deur [hatchback]-*- hazard warning lights-*-alarm knipperlichten-*- header tank-*-inlaatdeel radiateur/koelwatertank-*- headlamp / headlight-*-koplamp-*- headlamp lens-*-koplampglas-*- headless screw-*-schroef zonder kop-*- headlining-*-hemelbekleding-*- heat-*-warmte / hitte-*- heat shield-*-hitte schild-*- heat sink-*-warmtegeleider-*- heated rear window-*-verwarmd achterruit-*- heater blower-*-verwarmingsventilator-*- heater control cable-*-verwarmings bedieningskabel-*- heater control panel-*-bedieningspaneel van verwarming-*- heater hose-*-slang van verwarming-*- heater matrix (radiator)-*-radiateur lamellen-*- heated plug-*-gloei bougie / spiraal-*- heater unit-*-complete verwarmingseenheid-*- heavy discharge meter (battery)-*-vollast accumeter-*- helical groove-*-spiraalvormige groef-*- herringbone teeth-*-V-vormige tanden (tandwiel)-*- high beam-*-grootlicht-*- high gear-*-hoge vernelling-*- high melting point-*-hoog smeltpunt-*- high tension coil-*-hoogspanningsspoel-*- holding down bolt-*-bevestigingsbout-*- holding down spring-*-drukveer-*- hollow-*-hol-*- hollow bolt-*-holle bout-*- horn-*-claxon-*- hose-*-slang-*- hose clamp-*-slangklem-*- hose coupling-*-slangkoppeling-*- hot air shroud-*-hete lucht verharden-*- hot dip galvanising-*-galvaniseren in vloeibare zink-*- hood-*-motorkap-*- hub-*-wiel naaf-*- hub bearing-*-wiel naaflager-*- hub cap-*-wiel naafdop /wieldop-*- hub flange-*-wielflens-*- hydraulic-*- hydraulisch-*- hydraulic brakes-*-hydraulische remmen-*- hydraulic force-*-hydraulische kracht-*- hydraulic jack-*-hydraulische krik-*- hydraulic tappet-*-hydraulische klepstoter-*- hydrocarbon-*-kool waterstof-*- hydrometer-*-vocht meter-*- hydropneumatic suspension-*-hydropneumatische wielophanging-**- hypoid gear-*-hypoïde overbrenging-*- I identification plate -*-identificatieplaatje-*- idle adjustment screw-*-stationair regelschroef-*- idle cut-of valve-*-stationair sproeier afsluitklep-*- idle speed-*-stationair toeren-*- idle speed boost-*-verhoogd stationair toeren-*- idle speed control valve-*-stationair toeren regelklep-*- idle jet-*-stationair sproeier-*- idle mixture-*-stationair mengsel-*- idler (gear, pulley)-*-spanrol-*- idling-*-stationair lopen-*- ignition-*-ontsteking-*- ignition advance-*-voor ontsteking / vervroeging-*- ignition cable-*-bougiekabel-*- ignition coil-*-bobine-*- ignition control-*-ontstekings regeleenheid-*- ignition delay-*-na ontsteking / verlating-*- ignition distributor-*-verdeler-*- ignition key-*-contactsleutel-*- ignition setting-*- onsteking tijdstip-*- ignition stroke-*-arbeidslag-*- ignition switch-*-contactschakelaar-*- ignition system-*-ontstekings syteem-*- ignition timing-*-onstekingstijd-*- impact screwdriver-*-slag schroevendraaier-*- impeller-*-vin / propeller / schoepenrad-*- imperial (units of measurement)-*-engelse maataanduiding-*- impulse-*-stoot / schok-*- inbuilt-*-ingebouwd-*- inch-*-duim (25.4 mm)-*-zoll-*- independent suspension-*-onafhankelijke wielophanging-*- indexing-*-inhoud van boek / woordenlijst-*- indicator-*-meter / instrument / lamp-*- induction-*- inlaat induction stroke-*-inlaatslag-*- inductive semiconductor-*-transistor bobine-*- inert-*-niet reagerend / inert / vertragend-*- inertia reel seat belt-*-veiligheids rolgordel-*- inflammable -*-onbrandbaar-*- injection-*-inspuiting-*- injector-*-verstuiver-*- inlet manifold-*-inlaatspruitsuk-*- inlet valve-*-inlaatklep-*- inner tube-*-binnenband-*- input shaft-*-aandrijfas / prise as-*- inspection pit-*-smeer put-*- instrument-*-meet gereedschap / instrument instrument panel-*-instrumenten panel / dashboard-*- shroud-*-versteviging-*- insulated-*-geisoleerd insulating tape-*-isolatie band / tape-*- insulation-*-isolatie-*- intake period-*-inlaat periode / tijd-*- integral-*-geheel-*- intensified-*-vergroten / intensiveren-*- interconnected-*-doorverbonden-*- interference-*-storing-*- interference suppression-*-storing onderdrukking-*- interior-*-interieur-*- interior light -*-binnenverlichting-*- interlocking-*-in elkaar grijpend-*- intermittent -*-pulserend-*- internal-*-inwendig-*- J jack-*-krik-*- jacking-*-opkrikken-*- jacking point-*-kriksteun-*- jam nut-*-borgmoer-*- jaw-*-kaak-*- jet-*-sproeier-*- jet needle-*-sproeiernaald-*- jingling noise-*-klingelend geluid-*- join-*-aansluiten / verbinden-*- joint-*-aansluiting / verbinding-*- jointing compound-*-afdichtingsmassa-*- jointing sleeve-*-verbindings mof-*- journal-*-as tap-*- jump leads-*-startkabel-*- junction box-*-verbinding- / lasdoos K kerb weight-*-totaal gewicht-*- kickdown-*-geforceerd terugschakelen bij automaat-*- kickdown cable-*-kabel voor kickdown-*- king pin-*-fuseepen-*- knee-bar-*-hoekstuk/beugel knock-*-pingelen / klop-*- knock sensor-*-pingel- / klopsensor-*- knocking-*-kloppen-*- knurled-*-gekarteld-*- L laden-*-belasten-*- laminated-*-gelaagd / gelamineerd-*- lamp-*-lamp-*- lamp body-*-lamphuis / armatuur-*- latch-*-grendel-*- layshaft-*-hulpas, secundaire as-*- lead-*-lood-*- lead acid battery-*-loodaccu-*- leaded fuel-*-gelood brandstof-*- leak-off pipe-*-drainage pijp-*- leakage-*-lekkage-*- leakdown test-*-lektest lean mixture-*-arme lucht-brandstof mengsel left-hand-*-links-*- left-hand thread-*-linkse draad-*- level gauge-*-niveau meter-*- level plug-*-niveau plug-*- lever-*-hendel / hefboom-*- lifting bracket-*-hijsoog / -beugel lifting tackle -*-katrol / takel-*- light-*-lamp / licht / licht in gewicht-*- light alloy-*-lichte legering-*- light oil-*-dunne olie-*- line up-*-in lijn stellen-*- liner-*-voering-*- link-*-verbinding-*- linkage-*-verbindingsstang-*- linked suspension-*-actieve wielophanging-*- live axle-*-aangedreven starre as-*- live lead-*-stroomvoerende draad-*- load-*-last-*- load sensing valve-*-lading afhankelijke klep-* lobe-*-kam / nok-*- locating clip-*-borgveer-*- locating dowel-*-paspen-*- locating lug-*-pasnok-*- lock-*-slot-*- lock barrel-*-clinder slot-*- locking compound-*-borgmiddel-*- locking strap-*-remband (automaat)-*- locknut-*-borgmoer-*- locktab-*-borglip-*- lockwasher-*-borgring-*- long-nosed pliers-*-lange bek tang-*- longitudinal-*-langsliggend-*- loudspeaker-*-luidspreker-*- low beam-*-dim licht-*- low speed-*-langzaam snelheid-*- low tension lubricant-*-laag druk smering-*- luggage compartment-*-bagageruimte-*- ????-*-lpg [liqufied petroleum gas]-*- M magnetic-*- magnetisch-*- magnetic stand-*- magnetische standard / houder-*- main beam-*-grootlicht / hoofd balk-*- main bearing (crankshaft)-*-krukashoofdlager-*- main bearing shell-*-hoofdlagerkap-*- mainshaft-*-hoofdas-*- maintenance-free battery-*-onderhoudsvrije accu-*- maladjustment-*-foutafstelling-*- mandrel-*-drevel-*- manifold-*-spruitstuk-*- manifold absolute pressure-*-absolute druk in spruitstuk-*- manifold pressure sensor-*-druk sensor in spruitstuk-*- manual stop lever-*-[nood] stopknop-*- mating surfaces-*-bij elkaar passende oppervlakten / pasvlakken-*- mean value-*-hoofd waarde-*- membrane-*-membraam-*- mesh-*-gaas-*- metal filings-*-metaal vulling-*- metal hose-*-metalen slang-*- metering components-*-onderdelen regeleenheid-*- methylated spirit-*-spiritus-*- metric system-*-metrisch stelsel-*- metric threads-*-metrisch schroefdraad-*- mica-*-mica-*- micrometer-*-micrometer-*- microswitch-*-microschakelaar-*- mirror -*-spiegel-*- misalignment-*-niet in lijn-*- misfire-*-over slaan-*- mixing chamber-*-meng / wervel kamer-*- mixture-*-mengsel-*- mole wrench-*-gripsleutel-*- molybdenum disulphide-*-molybdeen disulfide MoT test-*-APK-*-Tüff mounting bolt-*-montagebout-*- mounting bracket-*-montagesteun-*- mounting plate-*-montage plaat-*- movable-*-beweegbaar-*- moving contact-*-beweegbaar contact-*- mud flap-*-spatlap-*- mudguard-*-spatscherm-*- muffler-*-uitlaat-*- multi-cylinder-*-multi cilinders-*- multi-function-*-multifunctioneel-*- N needle bearing / roller-*-naaldlager-*- needle roller cage-*-naaldlagerkooi-*- needle valve-*-naald klep / afsluiter-*- negative camber-*-negatieve camber-*- negative earth-*-negatieve aarding-*- negative lead-*-min kabel-*- negative pole-*-min pool-*- neon timing light-*-stroboscope afstellamp-*- net weight-*-nettogewicht-*- neutral-*-neutraal-*- nickel plated-*-vernikkeld-*- no charge-*-geen laadstroom / kosten-*- no-load switch-*-nullast schakelaar-*- nominal value-*-nominale waarde-*- non-return valve-*-terugslag-klep-*- notch-*-nok-*- notched nozzle-*-sproeier / gecalibreerde opening-*- nozzle holder-*-sproeierhouder-*- number-*-aantal / getal-*- nut-*-moer-*- O octane number/rating-*-octaangetal-*- off-set-*-uit het midden-*- ohc [over head camshaft]-*-boven liggende nokkenas-*- ohmmeter-*-weerstand- / ohmmeter-*- ohv [over head valve]-*-kopklep motor-*- oil-*-olie-*- oil can-*-olie kan-*- oil change-*-olie verversen-*- oil cooler-*-olie koeler-*- oil deflector plate-*-olie slinger schot-*- oil drain plug-*-olie aftapplug-*- oil filler cap-*-olievuldop-*- oil filter-*-olie filter-*- oil filter removal tool-*-oliefiltertang-*- oil level-*-olie niveau-*- oil level dipstick-*-oliepeilstok-*- oil pipe-*-olieleiding-*- oil pressure-*-oliedruk-*- oil pressure gauge-*-oliedrukmeter-*- oil pressure switch-*-oliedrukschakelaar-*- oil pressure warning light-*-oliedrukwaarschuwingslamp-*- oil pump-*-oliepomp-*- oil pump gear-*-oliepomp tandwiel-*- oil pump strainer--*-oliepompzeef-*- oil scraper-*-olie schraapveerring-*- oil seal-*-oliekeerring / olie afdichting-*- oilway-*-oliekanaal-*- one-way valve-*-terugslagklep-*- open circuit-*-verbroken verbinding-*- out of action-*-niet werkend-*- out of balance-*-in onbalans out of round-*-niet rond-*- outlet valve-*-uitlaatklep-*- output-*-uitgang vermogen (pk, kW)-*- output shaft-*-hoofdas-*- overall length-*-totale lengte-*- overall width-*-totale breedte-*- overcharge-*-overladen / te vol-*- overcooling-*-onderkoeld / te lage temperatuur-*- overdrive-*- overdrive [toerenverminderende versnelling]-*- overflow-*-overlopen-*- overflow pipe-*-overloop pijp-*- overflow valve-*-overloop klep / ventiel-*- overhaul-*-reviseren-*- overhead cam-*-bovenliggende nok-*- overhead valve-*-kopklep-*- overheating-*-oververhit, te heet-*- overinflation-*-band te hard-*- overload-*-overladen, te zwaar belast-*- overpressure-*-overdruk-*- overrun-*-overtoeren overrun fuel cut-off-*-overtoeren brandstof afsluitklep-*- oversize-*-grotere maat / overmaat-*- oversteer-*- overstuur-*- overtake-*-inhalen / over nemen-*- overweight-*-overgewicht, te zwaar-*- P padding (upholsterie)-*-binnen bekleding-*- paraffin (kerosene)-*-petroleum-*- parallel (alignment)-*-parallel lopend-*- parallel (electr.)-*-parallel schakeling-*- parcel shelf-*-hoedenplank-*- part throttle enrichment-*-deellast verrijking-*- partition-*-gedeelte / tussenschot-*- pawl-*-pal-*- peak power-*-piek vermogen-*- peg spanner-*-verstelmogelijkheid in worm-en rolstuurinrichting-*- permanent magnet-*-permanente magneet-*- petrol-*-benzine-*- petroleum jelly-*-vaseline-*- pin-*-pin / pen-*- punch-*-slag, drevel-*- pinchers-*-pincet / punt tang-*- pinch-bolt-*-puntige bout-*- pinion -*-kleinste tandwiel / rondsel-*- pinking-*-pingelen-*- pintle (nozzle)-*-tapverstuiver-*- pipe-*-pijp-*- piston-*-zuiger-*- piston clearance-*-zuigerspeling-*- piston crown-*-zuigerbodem-*- piston head-*-zuigerkop-*- piston pin-*-zuigerpen-*- piston pin bearing-*-zuigerpenlager-*- piston pin retainer-*-zuigerpen borging-*- piston ring-*-zuigerveer-*- piston ring compressor-*-zuigerveer klem-*- piston ring end gap-*-zuigerveer speling-*- piston skirt-*-zuigerwand-*- pivot-*-schanierpen-*- pivot bush-*-scharnierpenhouder-*- pivot bolt-*-scharnierbout-*- pivot post-*-scharnierstijl-*- plain bearing-*-glijlager-*- plastigage-*-plastik draad meter-*- platinum-*-platina-*- plenum chamber-*-inlaat spruitstuk ruimte-*- pliers-*-tang-*- plug-*-plug / bougie-*- plug lead-*- bougiekabel-*- plug socket / spanner-*- bougiesleutel-*- plunger-*-plunjer / zuiger-*- plunger pump-*-plunjerpomp / zuigerpomp-*- plunger valve-*-plunjer klep-*- pop-rivet-*- blind klink nagel / popnagel-*- positive camber-*-positief camber-*- post-heating-*-na verwarming-*- potentiometer-*-potentiometer regelbare weerstand-*- power stroke-*-arbeidsslag-*- power transmission-*-krachtoverbrenging-*- power-assisted steering-*-stuurbekachtiging-*- pre-ignition-*-voorontsteking-*- preload-*-voorspanning-*- premium-*-super benzine-*- pressure limiting valve-*-over druk ventiel pressure loss tester-*-drukverlies tester-*- pressure plate-*-drukplaat / koppelingsplaat-*- pressure reducing valve-*-reduceerklep-*- presure regulating valve-*-drukregelklep-*- pressure relief valve-*-druk aflaat ventiel-*- pressure-operated switch-*-drukschakelaar-*- primary current-*-hoofdstroom-*- priming-*-grondverven / handmatig bedienen-*- priming pump-*-handbediende pomp-*- propeller shaft-*-cardanas-*- protective cap-*-beschermkap-*- pull rod-*-trekstang-*- pull-off spring-*-terugtrekveer-*- puller-*-trekker-*- pulse width-*-puls breedte-*- pump-*-pomp-*- punch-*-drevel-*- push-on connector-*-stekker verbinding-*- pushrod-*-stoterstang-*- Q quarterlight-*-tocht / ventilatie raampje R rack-*-tandheugel-*- rack-and-pinion steering-*-tandheugel stuurinrichting-*- radiator-*-radiateur-*- radiator fan-*-radiateur ventilator-*- radiator hose-*-radiateur slang-*- radiator shroud-*-radiateurhoes-*- ratchet-*-ratel-*- ratchet spanner-*-ratelsleutel-*- rated voltage-*-normale spanning-*- rear axle-*-achteras-*- rear axle ratio-*-achterasverhouding-*- rear lights-*-achterlichten-*- rear window-*-achter ruit-*- reboring-*-opnieuw boren-*- recess-*-verzinken (van kop)-*- recharge-*-herladen-*- recirculated air-*-recirculerende lucht / niet verversend-*- recoil-*-terugveren-*- reconditioning-*-bruikbaar maken/reviseren-*- reduction gearing-*-vertragingsbak-*- reduction ratio-*-vertragingsverhouding-*- refitting-*-herstellen / monteren-*- refrigerant-*-airconditioning vloeistof-*- relay (elect)-*-relais (elekt)-*- relay (mech)-*-aanhangsel (mech)-*- release bearing-*-druklager-*- release mechanism-*-openings-/ losbreekmechanisme-*- reliable-*-betrouwbaar-*- relief valve-*-aflaat ventiel-*- removal-*-demonteren / verwijderen-*- repair-*-repareren-*- replacement-*-vervanging-*- restrictor-*-weerstand / restriktie-*- retainer-*-houder-*- retaining plate-*-bevestigingsplaat-*- retaining screw-*-bevestigingsschroef-*- retaining strap-*-bevestigingsstrop / beugel-*- retard (ignition timing)-*-vertraagd ontstekingstijdstip-*- retract-*-terugtrekken-*- return line-*-retourleiding-*- return spring-*-terugtrekveer-*- reverse (gear)-*-achteruit (versnelling)-*- reverse order-*-omgekeerde volgorde-*- reversible ratchet-*-omkeerbare ratel-*- reversing light-*-achteruitrijlamp-*- revolution-*-omwenteling-*- revolution counter-*-toeren teller-*- rich mixture-*-rijkmengsel-*- ride height-*-grondspeling-*- right hand-*-rechts right-hand thread-*-rechtse schroefdraad-*- ring gear-*-starterkrans-*- ring nut-*-ringmoer-*- ring terminal-*-aansluitring-*- ring-to-groove clearance (piston)-*-zuigerveer speling-*- road holding-*-wegligging-*- road test-*-proefrit-*- rocker arm-*-kleptuimelaar-*- rocker box-*-klep deksel-*- rocker finger-*-nokvolger-*- rocker shaft-*-tuimelaaras-*- roll-*-rol / overhangen in bocht-*- roll pin-*-rolstift-*- roller bearing-*-rollager-*- roller cage-*-rol kooi roof rack-*-imperial-*- roof rack load-*-imperial belasting-*- rotational speed sensor-*-rotatiesnelheidsmeter-*- rotor (US=brake disc)-*-remschijf-*- rotor (alternator)-*-rotor-*- rotor arm (distributor)-*-distributierotor-*- rotor winding-*-rotorwikeling-*- roughness-*-ruwheid (oppervlakte)-*- round off-*- afronden-*- routine maintenance-*-normale onderhoud / onderhoud beurt-*- routing-*-route/volgorde-*- rpm (revs per minute)-*-omwentelingen per minuut-*- rubber grommet-*-rubber beschermring-*- run-out-*-uitgelopen-*- running in-*-inlopen van motor-*- rust-preventive (paint etc)-*-roestwerend middel-*- S saloon-*-4-deurs auto-*- scavenge pump-*-afvoerpomp (bij carterloze motor)-*- scored-*-gegroeft, beschadigd-*- scraper-*-schraper-*- scraper ring-*-schraapveer (zuiger)-*- screen (filter)-*-zeef-*- screw-*-schroef-*- screwdriver-*-schroevendraaier-*- scriber-*-paspen-*- seal-*-afdichting / pakking-*- sealant-*-afdichtmiddel-*- sealing groove-*-afsluitgroef-*- sealing washer-*-keerring-*- seat angle (valve)-*-klepzittinghoek-*- seat belt-*-veiligheidsgordel-*- seat runner-*-stoelgeleider-*- seat width (valve)-*-klepzittingbreedte-*- securing clip-*-borgclip-*- see page-*-zie pagina selector fork-*-schakelvork-*- selector rod-*-schakelstang-*- self-adjusting-*-zelf-instellend / regelend-*- self-adjusting brake-*-zelfstellende rem-*- self-adjusting clutch-*-zelfstellende koppeling-*- self-locking nut-*- borgmoer-*- self-locking pliers/wrench-*-zelfblokkerende tang-*- self-tapping screw-*-zelftapper-*- semi-automatic-*-half-automatisch-*- sender unit-*-voelereenheid-*- separator-*-scheider-*- series (elect. connection)-*-serieschakeling-*- servo (brake)-*-rem bekrachtiger-*- set (adjust)-*-instellen-*- shaft-*-as-*- shank (of a twist drill)-*-schacht (van een spiraalboor)-*- shift lever (US)-*- schakelpook-*- shim-*-opvulplaatje-*- shock absorber-*-schokdemper-*- short circuit -*-kortsluiting-*- shoulder-*-zijkant van autoband-*- shunt-*-parallelweerstand-*- shut off-*-uitschakelen-*- sidelights-*-zij verlichting-*- silencer-*-demper-*- single -*-enkel / een-kant-op-*- single-acting brake cylinder-*-enkelwerkende remcilinder-*- single-point fuel injection-*-centrale brandstof injektie-*- skimming-*-klein laagje verwijderen-*- slack-*-ruimte / speling-*- slave battery-*-hulpaccu-*- slave cylinder-*-hulpcilinder-*- slide caliper-*-schuifmaat-*- slip-*-slippen / schuiven-*- slip joint pliers-*-waterpomptang-*- slip ring-*-sleepring-*- slot-*-sleuf-*- slotted nut-*-moer met sleuf-*- slow running jet-*-stationaire sproeier-*- small end (connecting rod)-*-drijfstangoog-*- snap-ring (circlip)-*-circlip / borgring-*- snug fit-*-nauwe passing-*- socket spanner-*-dopsleutel socket-headed screw-*-zeskant kop bout-*- soft-faced mallet-*-rubber hamer-*- solder-*-solderen-*- solenoid-*-elektromagneet/spoel-*- solenoid plunger-*-elektromagnetische zuiger-*- solenoid-operated valve-*-elektromagnetische klep-*- source-*-bron-*- spacer-*-afstandstuk-*- spanner-*-sleutel-*- spare parts-*-reserve onderdelen-*- spare wheel-*-reservewiel-*- spark plug-*-bougie-*- spark plug cap-*-bougiekap-*- spark plug gap-*-elektrodenafstand-*- spark plug socket / spanner-*- bougiesleutel-*- speed limiter-*-snelheidsbegrenzer-*- speedometer-*-snelheidsmeter-*- splash guard-*-spat lap-*- spline-*-sleuf-*- splined key-*-sleutel met sleuf / sleuven-*- splined shaft-*-as met spie sleuven-*- splined washer-*-kartel ring-*- split pin-*-splitpen-*- spring-*-veer-*- spring balance-*-veerbalans-*- spring seat-*-veerbodem-*- spring washer-*-veerring-*- sprocket-*-kettingwiel / tandriemwiel-*- sprong mass-*-afgeveerde gewicht-*- spur gear-*-tandwielen met rechte vertanding-*- stake-*-open laadbak-*- starter-*-startmotor-*- starter bush-*-startmotorlager-*- starter inhibitor-*-start blokkering-*- starter jet-*-startsproeier-*- starter motor-*-startmotor-*- starter ring gear-*-starterkrans-*- steel-*-staal-*- steering-*-besturen-*- steering column-*-stuurkolom-*- steering damper-*-stuurdemper-*- steering gear-*-stuuroverbrenging-*- steering linkage-*-stuurstang-*- steering lock (anti-theft device)-*-stuurslot-*- steering rack-*-stuurheugel-*- steering rack gaiter-*-stuurhuis-*- steering wheel-*-stuur-*- stem-*-stang-*- step by step-*-stap voor stap-*- stop screw-*-aanslagschroef-*- stop-light-*-stoplicht-*- stopping ability-*- stopmogelijkheid-*- strainer-*-zeef-*- strangler (choke)-*-smoorklep-*- stroboscopic timing light-*-stroboscoop afstellamp-*- stroke-*-slag-*- stub axle-*-astap-*- stud-*-tapbout-*- stud extractor-*-tapboutverwijder gereedschap-*- subframe-*-subframe-*- suction line-*-zuigleiding / kanaal-*- sump-*-carter-*- sump drain plug-*-carter aftapplug-*- sunroof-*-schuifdak-*- super (fuel grade)-*-superbenzine-*- supercharged engine-*-motor met compressor / turbo-*- supercharger (turbo)-*-compressor / turbo-*- support strut (tailgate)-*-steunbalk-*- suppressor (electrical)-*-onderdrukker-*- surplus-*-overschot-*- suspension-*-wielophanging-*- suspension strut-*-veerpoot-*- swept volume-*-cilinderinhoud-*- swinging arm-*-schommelarm-*- swirl chamber-*-wervelkamer-*- switch-*-schakelaar-*- swivel-*-fusee-*- synchro hub-*-gelijklopend assen-*- synchroniser ring-*-synchromesh-ring-*- synchroniser sleeve-*-schakelmof-*- synthetic-*- kunstmatig / synthetisch-*- T tachometer-*-snelheidsmeter-*- tail light-*-achterlicht-*- tailgate-*-achterschot tamperproof-*-beveiliging tegen ondeskundige handelingen-*- tap (thread cutter)-*-tap (uitwendige draad snij gereedschap)-*- tap and die set-*-tap en snij ijzer set-*- taper pin-*-conische pen-*- taper-roller bearing-*-conisch lager-*- tapered journal-*-conische as-*- tapered ring-*-conische ring-*- tappet-*-klepstoter-*- tappet clearance-*-klepspeling-*- tappet guide-*-klepstotergeleider-*- tarpaulin-*-dekkleed-*- tdc (top dead center)-*-bovenste dode punt-*- temperature gauge-*-temperatuurmeter-*- temperature sender-*-temperatuurvoeler-*- temperature-operated switch-*-thermostaat-*- tensioner-*- spanner-*- tensioner pulley-*-spanrol-*- terminal-*-aansluitpunt / accupool-*- test-*-test-*- test lamp-*-testlamp-*- test meter-*-meetinstrument-*- thermostat-*-thermostaat-*- thermostat housing-*-thermostat huis-*- thermotime switch-*-thermische tijdschakelaar-*- three-legged puller-*-drie armige pully trekker-*- throttle-*-gasklep-*- throttle cable-*-gaskabel-*- throttle plate-*-gasklep bevestigingsplaat-*- through bolt -*-doorlopende bout-*- thrust -*-druk / stuwkracht-*- thrust bearing-*-druklager-*- thrust plate-*-drukplaat-*- thrust washer-*-drukring-*- tie-bar-*-trekstang-*- tie-rod-*-spoorstang-*- timer-*-timer timing belt-*-distributieriem-*- timing belt tension-*-distributieriem spanning timing chain-*-distributieketting-*- timing gears-*-distributietandwielen-*- timing light-*-afstellamp-*- timing mark-*-afstel merkteken-*- toe-in-*-toespoor-*- toe-out-*-uitspoor-*- toothed belt-*-getanderiem-*- top up-*-volgooien / bijvullen-*- torque-*-koppel-*- torque converter-*-koppelomvormer-*- torque wrench-*-momentsleutel-*- torque wrench setting-*-aanhaalmoment-*- Torx key-*-torxsleutel-*- Toughness-*-taaiheid-*- tow bar-*-trek haak / trek stang-*- towing-*-slepen / trekken-*- towing eye-*-sleepoog-*- towing weight-*-sleep gewicht-*- track (width)-*-spoorbreedte-*- track-rod-*- spoorstang-*- track-rod end-*-spoorstangeind-*- tracking-*-beweging volgend-*- trailing link-*-langsdraagarm-*- trailing shoe-*-secundaire remschoen-*- transfer port-*-overstroomopening-*- transistorised ignition system-*-transistor ontsteking-*- transmission-*-versnellingsbak-*- transverse engine-*-dwarsliggende motor-*- tread (tyre)-*-loopvlak-*- tread wear indicator-*-slijtage indicator-*- trim (decorative items)-*-bekleding-*- trim panel-*-binnenbekledingsplaat-*- trip mileage indicator-*-kilometer dag teller-*- trolley jack-*-garagekrick-*- trouble shooting-*-foutzoeken-*- tubular drift-*-ronde doorslag / drevel-*- tuning-*-afstellen-*- turbocharger-*-turbolader-*- turning circle-*-draaicirkel-*- twist drill-*-spiraalboor-*- two-stroke engine-*-tweetaktmotor-*- tyre-*-band-*- tyre pump-*-bandenpomp-*- tyre rotation-*-draaing van wiel-*- U underbody-*-wagenbodem-*- underinflation-*-te lage (banden)spanning-*- undersize-*-te klein/ondermaat-*- understeer-*-onderstuur-*- union-*-wartel aansluiting-*- union nut-*-wartelmoer-*- universal joint-*-kruiskoppeling-*- unleaded (fuel)-*- ongelood benzine V v-belt -*-v snaar-*- v-engine-*-motor met de cilinders in v vorm-*- vacuüm-*-vacuüm-*- vacuüm actuator-*-vacuüm (rem)bekrachtiger-*- vacuüm advance-*-vacuüm vervroeging-*- vacuüm gauge-*-vacuümmeter-*- vacuüm hose-*-vacuümslang-*- vacuüm pump-*-vacuümpomp-*- vacuüm servo (brake)-*-vacuümremservo-*- vacuüm unit-*-vacuümtank-*- vacuüm valve-*-door vacuüm bediende klep-*- valve-*-klep / ventiel-*- valve cap (tyre)-*-ventieldopje-*- valve clearance-*-klepspeling-*- valve core-*-bandenventiel-*- valve cover-*-kleppendeksel-*- valve gear-*-kleppenmechanisme-*- valve grinding-*-klep in slijpen-*- valve guide-*-klepgeleider-*- valve seat-*-klepzitting-*- valve seat insert-*-hardstalen klepzitting-*- valve spring-*-klepveer-*- valve spring compressor-*-klepveer indruk gereedschap-*- valve spring seat-*-klepveerzetel-*- valve stem-*-klepsteel-*- van-*-bestelwagen-*- variable-venturi-*-variabele venturi-*- vehicle identification number(vin)-*- auto identificatie nummer-*- vent pipe-*-ventilatie leiding-*- ventilation unit-*- ventilatie-eenheid-*- venturi-*-vernauwing / venturi-*- vernier calipers-*- schuifmaat-*- vice (clamping device)-*-bankschroef-*- voltage-*-spanning-*- voltage regulator-*-spanning regelaar-*- voltmeter-*-voltmeter-*- W warm-up valve-*-opwarm klep-*- warning light-*-waarschuwingslamp-*- warning signal-*-waarschuwingssignaal-*- warning triangle-*-gevaren driehoek-*- warp-*-kromtrekken-*- washer-*-sluitring-*- washer jet-*-ruitensproeier-*- water (coolant) pump-*- koelwaterpomp-*- water temperature gauge-*-watertemperatuurmeter-*- water-cooled-*-watergekoeld-*- water-tight-*-waterdicht-*- watt-*-watt wax-controlled thermostatic valve-*-wasthermostaatklep-*- wax thermostat-*-wasthermostaat-*- wear-*-slijtage-*- weatherstrip-*-afdichtstrip-*- wedge-*-spie / keg-*- welding-*-lassen-*- wheel alignment-*-wieluitlijning-*- wheel balance-*-wielbalans-*- wheel base-*-wielbasis-*- wheel hub-*-wielnaaf-*- wheel lock-up-*-blokkeren van wiel-*- wheel rim-*-velg-*- window-*-raam / ruit window lift mechanism-*-ruitmechanisme-*- windscreen-*-voorruit-*- windscreen washers-*-ruitensproeiers-*- windscreen wipers-*-ruitenwissers-*- wing nut-*-vleugelmoer-*- wiper-*-wisser-*- wiper motor-*-wissermotor-*- wire brush-*-staalborstel-*- wire gauge-*-draaddikte meter-*- wiring diagram-*-elektrisch schema-*- wiring grommet-*-kabeldoorvoer / bescherming-*- wiring harness-*-kabelboom-*- wiring plug-*-draadstekker-*- woodruff key-*-halvemaan vormige spie-*- worm gear-*-wormwiel-*- worm-drive hose clip-*-slangklem-*- worn out-*-versleten-*- wrist pin (US)-*-zuigerpen-*- X x-frame-*-x-vormig chassis-*-
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 04-09-2006 at 03:38 PM. |
LinkBacks (?)
LinkBack to this Thread: http://www.opelgt.com/forums/opel-tech-articles/9684-english-dutch-technical-dictionairy.html
| Posted By | For | Type | Date | |
| English - Dutch Technical Translation | This thread | Refback | 11-10-2006 04:10 PM | |
