| Opel Tips & Tricks Place your special tips and tricks here! |
A bit of basics first. Distributors "time" the ignition point by a combination of mechanical, RPM dependent, and vacuum, load dependent, advances built into it. For these "advances" to work correctly, they must operate freely. Mechanical advance is controlled by a pair of centrifugal weights and tension springs, but for these weights and springs to do their jobs, the distributor cam assembly must rotate freely about the central distributor shaft. That brings us to that oft forgotten item, lubricating the distributor cam assembly so that it rotates freely about the center shaft. This should be done routinely with very lightweight oil, at least once a year! 1. Remove distributor cap. 2. Turn rotor in CW direction by hand, let go and observe how freely it snaps back in CCW direction (mechanical advance springs). 3. Remove rotor and lubricate distributor shaft center felt pad with a couple of drops of light weight oil and again check freedom of movement around center shaft. 4. Replace rotor and cap and check engine timing.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 01-02-2007 at 11:32 PM. |
Cam-in-head?
Good post- That's something I check right away when I buy an Opel; the mechanical advance is usually stuck solid, especially if the car has been sitting for some years. An easy fix and the power and fuel economy will jump.
-Kurt Last edited by tekenaar; 12-17-2006 at 01:17 PM. Reason: corrected post #1 |
