| Opel Tips & Tricks Place your special tips and tricks here! |
Brake piston pusher
Here is the picture of the setup Keith |
This looks like a nice set up, I have used the grease gun method when air has failed though the grease is a mess to clean up and dissolve out of the caliper. I imagine the porta-power will need a fluid fill up quite often this way.
Patent Apllied for yet?
Great Idea, Do you use brake fluid in the pump instead of Hydraulic Oil?
That way you would not have to worry about getting all of the Hydraulic Oil flushed out of the caliper with denatured alcohol with some other type of pressure pump.
hydraulic
I do use hydraulic fluid, as this still is used for my shop press. Once the pistons are out, most of the fluid comes out, a little brake cleaner, and it is flushed out. I usually clean them up afterwards, and even wash them with a soapy water, air blow the calipers out, and then paint, and reassemble. You will need to refill your pump, but stubborn pistons are a thing of the past. I think I have trown some away in past years just because air pressure and lube would not push the piston out. Even after working them in and out a little. This set I just did were like that, and turns out the pistons were in excellent shape, just stuck for all this time
Keith |
Keith;
One thing I have noticed over the years, is that granted there's some rust, or even "varnishing" in the piston bore to keep the piston from coming out, but, mostly I have found that it's a ridge at the opening of the bore that's made from crud, rust, road grime, brake dust, etc, similar to the ridge at the top of a worn cylinder in the motor itself. I have found that taking a sharp X-ACTO knife, and gently scrapping this ridge off generally allows the piston to pop free using the aforementioned air pressure, or even a couple of screw drivers in the piston groove will easily pop the piston out, for those who don't have an air compressor.
I don't believe you guys have seen rust until you work on a late '30s car. In any event, we use a different method which works without any tools per say. We heat brake fluid to about 130 degrees and drop the caliper in. We then leave it over night and the next day, the pistons come out generally with just your fingers.
Remember the pistonis basically floating in place being held by the internal O-ring and the outer seal. Most of the problems come from deposits that form behind the front seal which tend to lock up the piston. The O-ring side is usualy OK so if you like Gene says, depending on how long it has been locked up, clean the area and it should slide out with slight effort.
I've never had any trouble getting the pistons out with compressed air, but as you said, they rarely ever come out at the same time.
I found that a good way to plug the open bore, while removing the other piston, is to use an expandable-rubber engine block freeze plug. It also helps keep the other piston from flying completely out, since it fills part of the caliper gap. The proper freeze plug size for the opel caliper is 1 7/8"-2" (47-50 mm) and is available at Auto Zone, et al. Bob |
