| Other Models A forum for Olympia, Rekord, and all other classic Opels including models not imported to the U.S. |
Unanswered: Engine expert needed- non Opel
Thanks!
Opelerjeff "They said it couldn't be done; so I did it! |
How many miles are on the vehicle? I have 225,000 on a '96 5.9 and still have good oil pressure. My '96 5.2 has even better pressure with only 110,000 miles. The first one was run on synthetic oil and the second on regular oil.
Harold |
Could it be something in the oil pan that gets sucked up and covers the oil pickup tube. This might explain why when cold it works and that it works after shutting it off for a minute after it happens. When cold it (what ever it is) is in the bottom of the pan not blocking pickup tube, once oil warms up it gets loosened from the pan and blocks the pickup tube.When warm it is floating around. When you shut off the sucktion on the pickup tube disappears and then the oil in tube flows back and puts it(the thing whatever it is) back to floating in the oil. Which finally gets sucked up again sometime later after you restart it.
Still Standing and Still Trusting in the Lord Jesus |
This probably doesn't have any relevance but what weight oil and brand of filter do you use? Harold |
Do they clean and wipe out the oil pan when they change the oil pump. I would but I am not sure a mechanic would bother. Not to knock mechanics just not something normally done.
#8 (permalink) | |
They are going to drain the oil and drop the pan. It would be obvious if there was something floating around in there. Heck, it would probably cause problems with it draining.
Can you easily get to the distributor and pull it? I'm wondering if there is a problem with the pump drive even though it won't explain decent oil pressure until the engine warms up. There is an intermediate shaft between the distributor and the pump. The pump is driven by a shaft being driven off a gear at the rear of the camshaft. The distributor has a straight blade that sits in the top of the oil pump intermediate shaft. How much oil are you putting in the engine? I've known of the wrong dipstick being installed. I filled to the full level on an old Ramcharger I owned and it always seemed to use a quart but never went below that as long as the engine was in good order. The owners manual called for 5 quarts the dipstick read full at 6 quarts. Are there any knocking sounds from the engine that might indicate excessive clearance anywhere? Harold Last edited by hrcollinsjr; 04-20-2006 at 07:01 PM. |
Oil pressure problem
My money is on the pickup tube/screen> When they changed the pump if they reused the old pickup tube and screen it could be partly blocked on loose. If the tube is loose where it goes into the pump it will loose suction by developing an air/oil pocket in the tube. When you shut it off it drops the air bubble and will suck oil when re-started until it develops the air bubble again.
Hi Jeff,
These engines have a lot of issues with oil psi and noise. The pick up is very small, wont take much to plug it. Overtourqing the intake manif can crack oil galleries. There are TSB's on the distb drive and bushing and another for an updated timing chain and tensioner. I would also recomend the MOPAR oil filter on this engine. Oil sludging is a very common problem with these motors, sometimes helped by running a good engine cleaner thru and 3K oil changes. I have also heard of spun and worn cam bearings, exploded hyd lifters. well let us know what you find out. Dan |
Thanks to all for your your replies (except you Opleman70
). I will pull the pan and check for a blockage in the oil pickup tube. The place that replaced the oil pump was a CarX dealer. I was not impressed with what they did. When my son-in-law gave me the van I checked the oil and it was overfilled by 4 quarts! I drained out the excess and the dipstick read full, before that it was well above the full line. Engine sounds great, no knocking of any type at all. I will post again once I get the pan off and see what I have or don't have.
