Alternate Fram Oil Filter Numbers
+ Reply to Thread
Results 1 to 12 of 12
Thread: Alternate Fram Oil Filter Numbers
    Member My location azopelnut azopelnut's Avatar
    Apr 2003
    Yuma Arizona
    685
    Paul Heebink
    I usually use a Fram PH966B for my GT but while cleaning out a box of parts came across a Fram PH3614 and a PH 3387A. They both look to be the same as the PH966B.
    Anybody know fit these will work or how they may differ from the PH966B?
    Paul "azopelnut" Heebink
    1970 GT 12A-Rotary 5-speed
    1972 GT 2.0, 5-speed
    1973 GT #1, 1.9 4-speed
    1973 GT #2, 1.9 4-speed
    1973 Ascona 4-door 2.2 5-speed A/C
    1974 Manta, 1.9 Auto A/C
    1975 Fiat X19
    Member My location David McCollam
    Nov 2002
    Texas
    587
    Fram filters.
    Paul,
    Check the thread pattern on the filter. It could be that they are different from the 966B. It may thread on, but make certin the threads are tight and not loose after a turn or two. If so, they may have a standard thread and even thought they fit up, they will be loose on the threads and could loosen under vibration. Just a thought.
    Dave
    Last edited by tekenaar; 01-07-2007 at 12:58 PM. Reason: lose - misplace; loose - untight
    Viking My location hallgeir will become famous soon enough hallgeir's Avatar
    Mar 2005
    Norway
    857
    Hallgeir Bjørkavåg
    And another thought. Some filters have an internal pressure relief by-pass valve and also some has an anti drain back valve feature. Don`t know how it is in those filters you mentioned. Just a thought.
    Last edited by tekenaar; 01-07-2007 at 01:00 PM. Reason: has - singular; have - plural
    Hallgeir
    Opels now:
    -69 GT 1900, -95 Omega B 2,5 V6 CD Aut. -93 Astra Bertone 2.0i convertible
    Previous Opels:
  5. #4
    Member 73Manta72gt 73Manta72gt's Avatar
    Nov 2002
    Winston-Salem, NC
    377
    4
    3614 is the number I have been using both Fram and super-tech (Walmart $1.99) brands.
  6. #5
    Mid-West Opeler My location sawdust is on a distinguished road sawdust's Avatar
    Oct 2006
    West Chicago, IL
    1,632
    Hans
    Oil Filter Substitutes
    Fram PH3614
    Super Tech ST3614
    Car Quest 85374
    NAPA 1374
    They all Look the same to me.
    Projekt 2012 - Der OPEL GT
    I am past the Age of knowing when I should know better
    Other Cars:
    2010 Fusion Hybrid (White)
    1999 Mercury Cougar (White)
    LINK to my picture Albums
  7. #6
    Member 1000 Post Club My location Paul is on a distinguished road
    Ft Smith, Arkansas
    1,500
    The 3614 is the same as the 966B. The 3614 allso fits the first gen Neon. If you look up the Opel and Neon oil filter in an STP catalog, the number will be the same.......
    Paul
  8. #7
    Mike's Opel Shop Site Supporter My location opellane is on a distinguished road opellane's Avatar
    Apr 2004
    Goshen,New York
    239
    Fram PH3614 Oil Filter
    Been using Fram PH 3614 for a few years on my GT. Fram Filters are Nice has a grip coating on end of filter for easy removal/install. At Walmart I always pick up a few at a time.
    Try to get the Napa store to match one, might be there all day.
    MIKE
    1973 MGB, Red, Weber 38DG
  9. #8
    Non Civilian My location opelwasp is on a distinguished road opelwasp's Avatar
    Mar 2003
    Between Chico and Sac, CA
    1,847
    From my research Fram are junk. I stick to Mobil(M1102) or Bosch(3330). Mobil have stood up to testing best and Bosch are good too. Sucks Mobil cost abot $10 each.
    Engine Oil Filter Study
  10. #9
    Tennessean Site Supporter My location hrcollinsjr will become famous soon enough hrcollinsjr will become famous soon enough hrcollinsjr's Avatar
    Jan 2003
    Chapel Hill, TN
    4,519
    Harold Collins
    Quote Originally Posted by sawdust View Post
    Fram PH3614
    Super Tech ST3614
    Car Quest 85374
    NAPA 1374
    WIX 51374 for GT
    WIX 51364 1.9 eng. except GT
    NAPA 1364 1.9 eng. except GT
    Note: NAPA doesn't use the first number from the PN of the WIX filters.
    You may also go to the WIX website for applications and cross referencing different brands of filters.
  11. #10
    Cam-in-head? My location Opelkurt is on a distinguished road Opelkurt's Avatar
    Mar 2003
    Rochester, MN
    199
    Quote Originally Posted by opelwasp View Post
    I'll second that. Fram has been peddling a lot of inferior product for years, taking advantage of a good reputation they no longer deserve. They slap their name on no-name filters imported from darn near anywhere. The last straw for me was a Fram oil filter cartidge for my BMW motorcyle that came out in pieces at oil change, and the filter element had collapsed under normal oil pressure. Not good! Engine oil filters to avoid...
    On a tight (non-Bosch or Mobil) budget, AC Delco and Purolator are inexpensive and of decent to above-average build quality. I avoid Fram like the plague.
    -Kurt
  12. #11
    Idiot with a GT My location spamseptictank spamseptictank's Avatar
    Jul 2003
    Lakeland, Florida
    150
    According to Summit racing, the K&N KNN-HP1002 and AC Delco ACF-PF53 fit the 71 Opel GT 1.9L.
    FWIW,
    Dave
    The difference between your butt and your soul is that God only has to save your soul once. - David Zielinski
  13. #12
    Detroit,where my home was My location 2 Fast 4 U is on a distinguished road 2 Fast 4 U's Avatar
    Oct 2005
    Maria Hoop, Holland
    2,477
    Erick Janssen
    I've been using Fram filters as long as I can remember, never had problems with that brand.
    Now I'm using original GM filters they cost about 2.50 - 3.00 euro
    Opel Ascona;
    Only built from 1970 - 1975
+ Reply to Thread
