Go Back   The Classic Opel Forums > Technical Forums > Tech Links and Data > Part Substitutes
Part Substitutes Found a replacement part that will fit your Opel or a cross-reference to another part that fits? List them here!!
Old 07-01-2008   #1 (permalink)
Alberta Opeler
Ray Morley's Avatar
Ray Morley is on a distinguished road
Pop-out Window Rubbers for Kadett
If anyone is seeking new (old new) rubber seals for the Kadett B rear pop out windows I found the rubber from a Type 2 Honda Civic (80-83) fits into the flange perfectly. They have to be cut to length but its a great easy solution.
Ray Morley is offline
Old 07-01-2008   #2 (permalink)
opelspyder's Avatar
Pop out rubbers
Also a company called Reprotec in Germany are reproducing them, with the chrome hindge. Very nice products. Usually on German Ebay
Keith
opelspyder is offline
Old 07-01-2008   #3 (permalink)
Alberta Opeler
Ray Morley's Avatar
The rubber I am describing is the total window surround that the edge of the glass presses against not the actual hinge insert rubber.
Another titbit I found is for the plastic console insert for the automatic transmission housing in the car. PRNDSL
In a pinch you can find an early automatic Monza. The shifter lens is longer and wider but with a bit of creative grinding and sanding you will have a lens that will be about 90% as good as an original.
