Go Back   The Classic Opel Forums > Technical Forums > Tech Links and Data > Part Substitutes
Part Substitutes Found a replacement part that will fit your Opel or a cross-reference to another part that fits? List them here!!
Old 08-02-2008   #1 (permalink)
Alberta Opeler
Ray Morley's Avatar
Ray Morley is on a distinguished road
oil filter cross reference
On my 70 Kadett Rallye 1.9 I am currently using the AC PF 41 Oil Filter.
Is this the only filter that will fit or does Fram, Wix, Purolator etc have ones that will fit this engine?
Ray Morley is offline
Old 08-02-2008   #2 (permalink)
BMWonly's Avatar
Bosch # 3330 should fit. That's what I am using on my 71 GT. Kragen sells those for about $6.50. Fits all these Opels (per their website):
OPEL
1971 - 1975 1900
1971 - 1975 MANTA
1971 DELUXE
1969 - 1973 OPEL
1964 - 1972 KADETT
1968 - 1970 RALLYE
BMWonly is offline
Old 08-02-2008   #3 (permalink)
dcm013's Avatar
dcm013
Fram PH966B, Purolator L10028, and AC PF53 oil filters are for Opel 1.9L.
dcm013 is offline
Old 08-02-2008   #4 (permalink)
LOTS of previous posts on the subject, including:
http://www.opelgt.com/forums/part-su...tml#post113865
in this Forum (to whence it was moved)
Old 08-03-2008   #5 (permalink)
1971 GT
CDN OpelNut's Avatar
CDN OpelNut
Ray - Also available at Canadian Tire, Quaker State QS3614.
Corey
CDN OpelNut is offline
Old 08-03-2008   #6 (permalink)
Alberta Opeler
Ray Morley's Avatar
Thanks for the info.
I was unaware that the AC PF 53 would also fit.
I will check out Can Tire for the QS 3614
Old 08-03-2008   #7 (permalink)
3614
Yes the -3614 fits... Interestingly enough this is the same filter for the Dodge Neon...
Paul
Paul is offline
Old 08-03-2008   #8 (permalink)
I use NAPA 1364. Because it's large. But that could be an issue, there are reasons some things that work on my car won't work on a purely stock GT. However, this might not be a problem on a Kadett.
Notice the similarities between the numbers 3614 and 1364. Quite common "coincidence" when cross-referencing filters.
jeff denton is offline
