| Part Substitutes Found a replacement part that will fit your Opel or a cross-reference to another part that fits? List them here!! |
Rear Trailing Arms: Does GT Fit Manta?
I welded mine for the time being but I need a new one and can get a a junked GT.
http://www.cardomain.com/memberpage/470044 |
Re: panhead bar Gt to manta
The trailing arms (2 of them) run front-to-rear, the panhard bar (1 of them) runs side-to-side. Do not put GT trailing arms on a Manta, they are not curved to match the framerail....they'll bottom out, the spring rate will go infinite. You'll either bend something in vertical compression, or if you're in a corner you'll spin out from the suspension bind.
Bob Last edited by RallyBob; 09-22-2004 at 08:15 AM. Reason: spelling |
Thanks. It is the trailing arm not the panhead bar then that I need.
Opel Adventure # 77 NC
Real Name: Kevin
Calvin,
I have a spare trailing arm for a Manta. I will bring it to Springfield friday. We could probably put it on in the Baymont parking lot. later, Kevin |
I'm curious. Just how do you snap a trailing arm (I call them control arms)??
Also, if a stock one can snap, can a home-made one be built tougher? Should be a pretty simple proposition...
I believe Calvin's custom rear sway bar mounts to the trailing arms, so it puts unusual stresses on them. That, plus some years had a seamed tubular arms rather than a seamless tubing arrangement, and those are notoriously weak. Making new ones is not tough, I use 1" x .095" DOM tubing, they're strong as heck!
what bob said is why it broke. after route 66 I will post some suspention pics and you can see why.
