Intake valve power ringz
Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By RallyBob
  • 3 Post By hrcollinsjr
Thread: Intake valve power ringz
    UngerDog ungermm's Avatar
    May 2004
    Pleasanton, CA
    1,257
    I'm rebuilding the head on my free GT and came across an article that included increasing performance with a trick of cutting rings on the back side of the intake valves. It reminded me of the ancient Chinese piston dimple trick. I searched this site, but couldn't find anything about this. Is this worth the effort for a stock 1.9 high compression rebuild?
    Prepping Valves for Performance
    Spofford, NH
    12,475
    Bob Legere
    All I'm thinking is 'stress risers'. Looks like you would just create half a dozen places on the valve for a crack to propogate from.
    Even the guy who wrote the article doesn't make any power claims. He says 'less prone to detonation' and 'better fuel economy'. FWIW...
    SpringGT likes this.
    Opeler My location SpringGT's Avatar
    Mar 2006
    Houston, TX
    1,050
    10
    I very much agree. Introducing this many grooves and sharp edges on a valve head while removing all of that material is just asking for trouble, even if it had any power benefits.
    Non Civilian My location opelwasp's Avatar
    Mar 2003
    Between Chico and Sac, CA
    2,032
    I would suggest trying Singh Grooves before weakening your valves.
    1971 GT (Opelwasp)
    1974 Manta A (Polizei)
    1973 Manta A (junker)
    1973 GT (junker)
    2001 Dodge Durango SLT 4x4
    2004 Dodge Neon SXT
    2002 Suzuki SV650S
  7. #5
    Jan 2016
    Albuquerque, NM
    538
    Joseph Bauer
    Quote Originally Posted by opelwasp View Post
    I know, another thread resurrection...
    I would not recommend any modifications to the combustion chamber that result in a sharp radius. Taking a look at what some of those "improvements" are, I'd bet that these individuals do not have an engineering degree. Any potentially sharp radius edge in a combustion chamber, will add heat sinks. And I'd be worried about running a groove right up to the edge of the gasket, that will provide a channel for pressurized gases to target a small section of your gasket. Long term, I see gasket failure being a problem.
    Of all the high end engines I've seen internal shots of, a consistent but rough surface seems to be the ideal surface to create for a carb'd engine. The crazy builds, replicate golf ball dimples in the intake runners via CNC machining. So the "lynz" in the intake port do make sense, if you're trying to add turbulence but there are other more consistent ways to do this. The problem I see with the CIH, is the intake manifold. If I was trying to maximize performance and fuel economy at the same time with a CIH, I'd ditch the intake manifold and make a tubular intake. Think headers, but for your carb. Run a 38 DGV and a tubular dual plane. The intake pulse will be stronger and flow will be improved, because the air / fuel charge won't slam into the bottom of the intake. Either round or rectangle tube would be an improvement, and good pipe bender.
    ~Joe
    "Autoholism is an incurable addiction medicated daily with car porn." ~Me
    "the sickest of the sick — a car guy who is collecting parts for the restoration of a car he doesn’t even own yet." ~Anonymous
  8. #6
    Jan 2003
    Chapel Hill, TN
    7,795
    Harold Collins
    Quote Originally Posted by Autoholic View Post
    Did Smokey Yunick? I'm not disagreeing with your previous statement. While a formal education may look good, it doesn't always equate intelligence. I'm sure many great discoveries have been made by people lacking a 'formal' education in the area of their discovery.
    Garfield (Comic) about Odie:
    "It's amazing what one can accomplish when one doesn't know what one can't do."
    kwilford, guyopel and Autoholic like this.
  9. #7
    Jan 2016
    Albuquerque, NM
    538
    Joseph Bauer
    Smokey experimented however. I'd be willing to bet for every performance discovery he made, he made 3 discoveries of how to decrease performance. A formal education in engineering would just help you make less bad discoveries and possibly more good discoveries. One way or another, it all comes down to education. It's just how did you learn what you know? Both routes cost money, tools and experience. Only one helps you understand why most of the time. Anyone can create an explosive, fewer can explain why it went bang.
    I'm not trying to make it sound like a college education is all that and a bag of chips. College is a tool, for some it is needed / required to do what they want to do. Some just need a solution, they don't care why the solution worked.
    ~Joe
  10. #8
    Nov 2012
    Australia
    132
    Alex
    cutting rings on the back side of the intake valves/ golf ball dimples in intake
    G'day again, I hadn't heard of rings cut in the back of intake valves but I saw a rally engine in the 80's with a deep ring cut around the back of exhaust valves to stop exhaust flow reverbing back. And I have incorporated a golf ball pattern in the bottom of the intake manifold plenum floor in the hope two stop fuel pooling with minimal effect on the flow. Its good to experiment I always remember Murphies Law (if it can go wrong it will ) and stick with kiss (Keep it simple stupid ) if an idea gets to complicated sit back and find a simpler approach .
    Have fun with your project and remember you are building it for you and other don't have to agree.
    1. Question: power mirrors, power windows, seatbelts
      By lylebig1 in forum General Discussions
      Last Post: 07-07-2009, 03:18 PM
    2. Weber 38DGAS Power valve
      By Tru-Craft in forum Aftermarket Down-draft carbs
      Last Post: 04-28-2008, 06:50 PM
    3. Intake Valve to Cover Fitting
      By Ooooner in forum 6A - Engine Mechanical
      Last Post: 07-15-2007, 04:10 PM
    4. No Power, running rich, worn cam lobes (was "Help on Valve Timing")
      By ParkerVH28 in forum 6A - Engine Mechanical
      Last Post: 07-01-2005, 12:47 AM
    5. weber power valve
      By greensmurf20 in forum Aftermarket Down-draft carbs
      Last Post: 06-29-2005, 03:17 PM
