Old 02-18-2007   #1 (permalink)
blancojp's Avatar
Provided Answers: 10
Unanswered: Braking power
Howdy All!
Just finished the final brake upgrade on my car and I now have real brakes.
It did require a few days work to remove the hood, left headlight assembly and work out all the bugs but the stopping power is phenomenal.
I used a 9" booster from a BMW 325I which bolts right up with no mods. The master cylinder is a 24mm unit from a Mitsubishi Eclipse which had to drill two holes to mount on the booster. The BMW booster moves the master cylinder forward 35mm so a remote mount reservoir was used.
The vehicle now stops flat without any effort and 60-0 times were reduced substantially. Pics are below.
JB
'70 Opel GT - 4 speed "Lucy"
blancojp is offline
Old 02-19-2007   #2 (permalink)
jtb
jtb's Avatar
Neat!
That master cylinder looks really familiar... I'm using one from an Eagle Talon (dodge product), I think it must be the same one. Good tip on the BMW booster - what year?
cheers,
jtb
jtb is offline
Old 02-20-2007   #3 (permalink)
blancojp's Avatar
Originally Posted by jtb View Post
Neat!
cheers,
jtb
The Talon/Eclipse are the same car, just a different badge here in the states.
The Booster is from any E30 type BMW, the bolt pattern is the same as the Opel unit. You just have to make the turn buckle to attach it to the rod.
The booster provides up to 700Lbs of support, versus the 500lbs supplied by the Opel unit @18 inches of vacuum. Makes the pedal nice and hard up top but takes no effort to quickly stop the car.
JB
blancojp is offline
Old 02-20-2007   #4 (permalink)
And Plymouth Laser. I think the Talon is more likely to have 4 wheel disc than the Laser. The base model Talon has more goody's than the base model Laser and the Eclipse can run the gamut from cheapest model to the most tricked out.
Old 02-20-2007   #5 (permalink)
heimue's Avatar
Where did you get the plastic connectors that go in the MC, to connect to the hoses to the remote reservoir?
Do you know/remember what the diameter of the MC "inlet" is, where the connectors stick in?
Dieter
heimue is offline
Old 02-20-2007   #6 (permalink)
blancojp's Avatar
The M/C is a 7/8" bore unit and the plastic fluid input port come with the unit. Both 10x1.0mm output ports are on top, the front is a short one and the rear is the tall one. You can't use this unit with stock brakes, you will get a short pedal travel but very little pressure. I need it because I have 4-wheel disks and the rear floating calipers have 80mm pistons which require larger fluid delivery to operate.
I was really knocked out with the results, my Opel brakes are now comparable to the brakes on my Cayene.
JB
blancojp is offline
Old 02-21-2007   #7 (permalink)
jtb
jtb's Avatar
Right, good point - I am running rear disc brakes too. I don't think this master cylinder would be appropriate for a stock opel gt.
jtb is offline
Old 02-21-2007   #8 (permalink)
mschmalenberg's Avatar
mschmalenberg is on a distinguished road
Brake booster
Would the BMW booster help a stock GT brake set up?
Mike
Brandon Twp. ,MI
71 GT, 2003 MINI Cooper S JCW#249
mschmalenberg is offline
Old 02-21-2007   #9 (permalink)
blancojp's Avatar
Yes, it will improve pedal performanceand feel since it will require less effort to operate.
JB
blancojp is offline
