Unanswered: Watts link buildup
The plus side of a watt's link is that it allows for near perfect vertical travel of the rear axle compared to a panhard bar. In fact by comparison, my watt's link allows for 12" of vertical travel (the shocks only go 9" so that's a moot point) with zero deviation from left to right. The stock panhard bar allows for about 3/16" of side-to-side deviation in 9". The down side to the watt's link is far greater complexity and price. So, in typical fashion for me, I decided to build my own instead of buying a 450-euro pre-built version from Germany. In the end I have about 7 hours into mine, and material costs are about $170 total. ![]() ![]() ![]() ![]() ![]()
My Flickr photos. Jan. 3, 1984 - Jan. 3, 2009, that's 25 years of this damn Opelitis! C.R.L. 9/22/69 - 12/8/99, J.M.L. 3/3/43 - 6/15/04 Last edited by RallyBob; 11-16-2008 at 09:41 PM. |
And the last two pics:
Doggone it Bob, there oughta be a law against such superb craftmanship. A minor suggestion, if I may, from my USAF flight control system push-pull rod sustems. How about a .040" safety wire hole in the jam-nut, with a .040" hole in the purple rod end for some .032" nichrome safety wire. Just a suggestion.
'72 Opel GT (Sara)
Thanks for the kind words guys. I should have mentioned that anyone wanting to see more pics can go to my flickr site as I have a few more details in there.
Ron, I decided to use nylon-insert nuts on the fasteners, and the large center pivot bolt will also have some loctite added. I'm not going to safety wire this setup as it's 'only' a street car! If anyone else decides to try this themselves I could make a detailed list of parts I used...metal thickness', bearing part numbers, etc. For your average street car the center pivot need not be as long as mine is, as you'll probably never approach this much suspension travel in situ. Bob
My Flickr photos. Jan. 3, 1984 - Jan. 3, 2009, that's 25 years of this damn Opelitis! C.R.L. 9/22/69 - 12/8/99, J.M.L. 3/3/43 - 6/15/04 Last edited by RallyBob; 11-17-2008 at 03:36 PM. Reason: spelling, punctuation |
Oops, almost forgot to mention. I drilled a few extra holes into the differential cover and the diff housing itself, and fitted a few dowels to help spread the lateral loads on the differential cover. Probably not necessary as I've never seen anyone else do it, but it was cheap and simple to do.
No....its not a Buick....
Awsome!!!!! I was wondering if there is any worry of warping the diff cover with so much welding?? Or for that matter, are you using HEAVY DUTY bolts to mount this back on? My thoughts are that this could possibly cause a leak in the diff with so much stress being there.....although,now thinking about it, I suppose it IS a central location(pivot point)....so most of the "stress" would be where it attaches to the car??? As always Bob, you da man!!
Joe
#11 (permalink) | ||
#12 (permalink) | |
Are you going to make photos how the linkage is mounted to the chassis??
#13 (permalink) | ||
Excellent craftsmanship!
Ford Motor Company added a Watts Link to the rear suspension of the 1997 Model Year Town Car, Crown Victoria and Grand Marquis to improve tracking and I beleive it is still in production at the Saint Thomas Assembly Plant in Ontario, Canada. The differencial cast iron housing was modified to incorporate the mount for the pivot bolt. During durability testing it was discovered that the cast iron housing had to be modified further to withstand the high laterial loads during rough road handling tests without fracturing. The laterial load pins and cover reinforcements are certainly required. |
Alrighty, here's my list of parts I used. I had a few of the items already which I didn't have to buy, and the metal itself was free (nice to be next door to a metal shop!). I also bought a couple items at a local hardware store (bolts).
Speedway Motors stuff: *1170810 - RH male alum. rod end, 5/8" shank w/ 1/2" hole, 2 req'd @ $9.99 ea *1170810L - LH version of above rod end, 2 req'd @ $9.99 ea *1756046LH - LH jam nuts, pack of six, $3.99 *1756046RH - RH jam nuts, pack of six, $3.99 *91034158-14 - 7/8" OD alloy tube, with LH/RH internal 5/8" threads and 14" long overall, 2 req'd @ $7.99 ea (note this fits a Manta/Ascona A, not GT) I could have made the links with chromoly rod ends and steel wedged tubing for a little more money. A GT would need shorter links as well, but I have not measured for them. McMaster-Carr stuff: *91247A483 - 3/4"-16 x 4" long grade 5 bolt, five-pack, $10.96 *91342A240 - 3/4"-16 nylon insert thin locknut (.406" tall), 10 pack, $6.93 *5909K33 - 3/4" caged needle roller thrust bearing, 2 req'd @ $2.60 ea *5909K59 - 3/4" hardened thrust washer, .126" thick, 4 req'd @ $2.20 ea *7815K48 - 3/4" ID flanged high strength (alloy 932) bronze bushings, 2 req'd at $5.60 ea Misc. *3/8"-24 x 3" long grade 8 bolts for back brace - 2 req'd (hardware store) *Also 2 each grade 8 flat washers and nuts, also 3/8" *Short pieces (mine are 2.275" long) of 1/2" OD x 3/8" ID stainless tubing for supporting the back brace. *1/2"-20 x 1.25" grade 8 bolts and nuts (2 ea) to attach lateral links to the center pivot. *Short piece of 1.25" OD x 1" ID steel tube for center pivot sleeve, I think it was 1.25" long? *I used 12 gauge steel for the vertical pivot main body, and for the reinforcements welded to the diff cover. The remainder of material was 14 gauge steel. My vertical link uses 5.25" center-to-center holes for the transverse links. I think you can use about 4.5"-4.75" and get 8" to 9" of travel from the rear axle before it starts to deviate left-to-right. This would make the entire setup more compact. The center link I made is 2.25" wide at its' widest point, and the ends have a 1.25" radius. The back brace strap is made from 14 gauge steel, it's 5" center to center at the mounting holes, 1.625" wide at the center, and 1" radius at the ends. The return flange I bent (for strength) is 3/16" wide. IIRC, the 'box' I welded to the diff cover is 4.5" x 3.25" across its' face. Another note: I could have easily simplified this by deleting the needle roller bearings. They do make the pivot far smoother, but I've never seen anyone else bother to do this. Removing them makes the entire pivot a lot shorter, by about 3/4". I cut the large 4" x 3/4" pivot bolt down after I made the watt's link, it barely protrudes past the head of the short nylon locknut now. Note: after everything in the pivot is greased well, the pivot lock nut is tightened only until there's zero slop so the bearings will pivot smoothly...do not torque it down! I will also use loctite on the locknut to keep it from loosening, although it's probably redundant. At this point I have not made the attachments to the chassis itself, but the material costs will be minimal. Basically I will extend the factory panhard chassis mount downward as needed, and add another similar mount to the other side of the car. Add two more mounting bolts to the transverse links and there you have it! HTH, Bob
Bob, every time I see something built by you I envy you for your TIG welder! That's about the only tool that I don't have, but certainly want!
Dieter
#17 (permalink) | |
BTW what's your labor rate for custom work? Seven hrs. bill time X shop= a terrible Opel habit.
#18 (permalink) | ||
UFO pel abductee.
What! You didn't machine a new billet diff cover???? Ha!
Nice design and fab, as usual.
#22 (permalink) | |
A) I'm not a machinist B) I'm not a machine programmer B) I have no milling machines C) I think the cost of the billet I would need to begin the project is about double my total investment so far! Any time I can fabricate and weld I go that route. Far cheaper for me, and well within my abilities. Someday I'd love to learn to machine stuff but I can't justify the cost of the machinery for my own personal use...yet.
#23 (permalink) | |
The trick is to TIG every time you get a chance. Practice!
#24 (permalink) | ||
