![]() Provided Answers: 10
Unanswered: Rear Disk brakes caliper brackets
I have gotten several emails and Pm's on the rear caliper bracket subject so an order for brackets will be placed on March 20th. These are the brackets that allow a Cadillac caliper to be installed with a 262mm vented rotor. I don't have any in stock but I can have made as many as we need in a week's time. If you want a set of brackets for your car, the cost is $90 (including freight ) and you can place the order via paypal to edc_inc@bellsouth.net. All placed and paid orders will be released for production on the 20th, parts will be received on the 27th and shipped on the 30th of this month.
Real Name: James
Does this fit the both the early (pre '71 I think) and late rear end?
What rotor does it use?
"If you have complete control of the car, you're not going fast enough". PARNELLI JONES 1966 |
Dallasmanta
Real Name: Ron
JB, any chance you will put a complete package together since you are in the business and have parts relationships that can drive the initial costs down. If so what type of price range are we talking. I would have a need for one or two kits for a manta 74 and 75 Thanks Ron
#5 (permalink) | |||
It had the handbrake on the front wheels if memory serves me right
"The nice thing about standards is that you have so many to choose from" --Andy Tanenbaum-- Last edited by ggl; 03-11-2009 at 08:51 PM. |
Let us not try to reinvent the wheel shall we?
#10 (permalink) | |
The calipers are from a 1979 El Dorado, the rotors are Honda Prelude Si and the E-brake is from an El Camino. The bracket however I make to order and there was no interest at the time so none were made. I did make a new kit which uses '88 Acura rotors and calipers, which are easier to find used in many junk yards. I installed a set on Stealth with a Lokar E-brake cable kit which proved to be a good fit. It takes a lot of effort, time and resources to come up with viable options for brakes. I currently have 10 different brake options for the front and 6 for the rear but stopped posting since no interest was shown.
Real Name: gerold
Juan, I am new to the forum, but have plenty of Opels. I'm very interested in bigger brakes for them. Please let us know of the front and rear options that are possible, along with years of the donor cars. thanks for the great info-gerold.
Throwing in a big ol' "me too". My car's front rotors are toast and I just twisted off one of the bleeders. Rather than rebuild the calibers I'd like to do an upgrade. Doesn't need to be radical. Prefer to go with a setup where the rotor is separate from the hub (so they can be changed easily). 2-piston front, single rear.
#15 (permalink) | |||
For me to give you all options is a waste of time, let us be realistic here and explore the availability of the requirements for the options. First and most important, what wheels do you all have? If you retain factory wheels then you need to measure the inside of the wheel to see how much room you have. Depending on the available room ( it does vary from wheel type to wheel type), then a rotor / caliper combo can be selected. The stock wheel can only accomodate a 248mm vented rotor / caliper combination at max. Second would be the master cylinder/booster combo. Are you upgrading or using the stock unit? Again this also limits the caliper options due to the compliance in the system. Third would be rear brakes. Are you keeping the rear drums or installing disk brakes? If you are keeping the drums then are you increasing the wheel cylinder to 3/4" or keeping the 5/8" stock unit? If you are installing rear disk brakes then depending on #1 and #2 above, the rotor / caliper combo is then selected. Fourth and last, but not least, would be the type of brake hose you will use. Are you going to use stock or braided SS? This also limits the caliper type you can use since you can't use a stock hose with a floating caliper. On Stealth, I have 262mm front and rear disk, single piston floating calipers. On the Ascona, I am trying out a new 248mm vented front brake system which allows the stock wheel to be used. There are other members which have either my front or rear disk setup and are happy with the performance. So there are many options depending on the variables at hand. The '75 Opel big brake system is not actually an upgrade since you are only moving the pads outward 4mm, which results in a very minor applied torque increase. Plus there is no help in the heat side of the equation since you are increasing to a slightly larger solid rotor. I have front brake designs from 246mm to 304mm, rear brakes from 248mm to 262mm. All my systems are vented rotor designs and I can have any quantity of brackets made quickly, since I now own a flow jet machine. But the most important question is, how much do you want to spend?
U-2 Driver
Juan,
I appreciate your time and effort in documenting your builds. There's one thing though, you give us way too much credit. I don't wrench on cars for a living, I fly jets. So I have no clue what the answer is? Cheap is good, and so is easy. But best of all, your willingness to show the rest of us how to make our cars better is most appreciated! Right now, I'm back to a stock 72 with the 13" rear wheels, but that could change. So tell me what I should want, and chances are, I'll do exactley what you say, just becasue I have seen your work and it is Sierra Hotel! Cheers! |
#17 (permalink) | |
The biggest, mostly off the shelf, brake system I put together for an Opel is the 304mm vented front system. This is a slip over the hub design and does move the front wheels out 5mm. It has a multitude of parts from different manufacturers which work well in unison. The front and rear rotors are from a Chrysler Lebaron, the front calipers are from an S-10 and the rear from a '79 Eldorado. The hoses are from a 1988 Acura Legend and of course the custom caliper brackets are made by me. Take a look at this post... http://www.opelgt.com/forums/perform...ew-brakes.html
Brake upgrade
Here is what I have:
I have 15 inch wheels and would like to keep the stock master cyl. I am not wanting to go crazy with price but want something that is a very good upgrade and will look good as well. Can somebody give me a suggestion on what I need for Rotors and Calipers that is easy work for A NOVICE AT THIS KIND OF WORK. Is there anything else I need to be concerned with? Thanks for the help for this brake handicapped GT lover! Rob
1970 Opel Gt
#19 (permalink) | |
Brakes are simple but sometimes simplicity is complicated.
