i was going to get those vented rotors for my opel.. cools the brakes better.. although i dont have them on my opel i do have them on my nissan sentra and they work great.. but i was told you can't have them "turned" when they are done they are done..
{)BILLY(} & The 71' GT 73 manta luxus real cars don't power the front wheels...... they lift 'em |
#3 (permalink) | |
Now if you mean some kind of HIGH PERFORMANCE Brembo product, such as multi-piston calipers or a larger bore master cylinder and such, then the sky is the limit. Or maybe the bank loan that is needed. But I don't believe that Brembo makes any such products specifically for these vintages of Opels. Now if you had RallyBob's fabrication skills, there are LOTS of choices. Have a search for "Wilwood", as I believe that Bob and others have adapted some of their products to Opels, at least for racing applications. HTH
1450 Seeker...
A nice upgrade that WORKS without getting crazy is to simply switch everything over to '75 brakes. Opel GT Source has the all the parts assembled as a kit, it's on the pricey side compared to assembling the parts yourself, but there is a lot of piece of mind. The next upgrade is braided stainless lines, spendy, but it makes an enormous difference in pedal feel. Finally, the single biggest upgrade that you can make to your brakes, is your TIRES!!! Your brakes are only as good as the amount of stickiness (or coefficient of friction in negative acceleration) your tires have.
Also poke around in the "Brakes" Section of this forum, many people wiser than me have discussed this problem at length. There is also some good information at http://www.tgsi.com/brakes.html (even though products can not be purchased from that site anymore).
Keep it Blitzed |
No Access
Just an idea or way of doing some brake modifications.
http://www.opelgt.com/forums/showthr...=brake+upgrade |
Let's call a brake, a brake.
Let's take a look at the facts. Brembo makes brake replacement parts and rotors. ATE was one of the original suppliers for brake components to Opel. Currently, if you want a high performance brake setup to go with that freshly tweeked engine. Picture this, widened ATE front brake calipers from a '75 Manta/Ascona and vented 246 x 22mm rotors, paired with 3/4" rear wheel cylinders.
There is a kit available from Risse Motorsport in Germany for 75 Euro to widen the stock '75 ATE caliper. There are also the BMW calipers that are available rebuilt from ATE-US. The vented rotors are also available and the calipers use BMW pads. Total cost for the calipers and rotors from the pre-8/77 vented rotor BMW 320i is about $200. The rotors and expanded calipers would cost about the same. If you have the ATE calipers this might be a good choice. That's actually what I have on my Manta. The wheel cylinders are available as well for about $25 a piece. Throw on some Speedbleeders, SB7100 front and SB8125 rear, $28 plus shipping and you're set. Could be all done for about $300 or so, plus your labor. Good luck. |
#8 (permalink) | |
Keith Wilford working on my '71 GT and '75 SportWagon Last edited by kwilford; 06-09-2005 at 01:12 PM. |
#9 (permalink) | |
For a GT, the proportioning valve is a good idea. For a Manta or Ascona/Sportwagon, it's really not necessary. IIRC, the proportioning valves I used to get from Germany (Parsget) to go with the 3/4" rear cylinders was from a Euro-spec Porsche 944 or something like that. I know it was a TUV-approved setup. I could look at the part number if that info is needed by someone, I should still have one or two of those proportioning valves kicking around in the barn. Bob |
The meaning of "all".
Keith,
The use of the word "all" in my desciption above indicates my opinion that these parts could be installed inclusively for the named price or possibly within a reasonable variance of that amount. Is that what you are referencing? Thanks, |
#11 (permalink) | |
Copyright İ 2003-2009 barry williams All Rights Reserved save praying to God for sunday today we pray to Nike and run like hell |
#13 (permalink) | |
rebuilt ate calipers 78 bmw-320i
advance auto parts in kansas city has rebuilt ones for $45 each plus $10 core charge, no pads i think
i found a new right one for $125 at star motors,no left
rotors- brembo
I sure this is a repeat question.
1-if i get manta 75 rotors from brembo,then get 77-83 bmw ate calipers, use my same opel master cylinder, and i will have a big brake, non- vented front discs set up 2-but i will also need a proportioning valve( llike in a circle track catalog) and rear 3/4 wheel cylinders from ogts
#17 (permalink) | |
2- ## I haven't put the 75 front "big brakes" on my GT yet. I do have the 3/4" wheel cylinders installed for 4 years now & haven't had any problems. I guess once the front system is on, I'll see if the proportioning valve will be needed. As for buying the 3/4" (19mm) wheel cylinders. autopartsgiant.com has them new for about $11 each. Automotive Specialty (TRW) part # W-13002. They have great prices on all Opel parts. I've been dealing with them for years. ~ Tom Last edited by Mach1Tom; 06-09-2005 at 08:49 PM. |
I can not find the 3/4 wheel cylinder on autopartsgiant.com even from part numbers, can some one post the link to the exact part. Also are they a direct bolt up?
Wheel Cylinder
i assume this is it
#20 (permalink) |
Dean - Yes, those are the 3/4 (19mm) Wheel Cylinders
Jordan - Yes, they are a direct bolt in. No modifications of any kind to install. I tried, but couldn't post a direct link to that page. From the center of the Home page is " START HERE". Scroll to 'Opel' & 1975, then "SEARCH". 'click' BRAKE SYSTEM , then "Look it Up" 'Select Model' 1900 or Manta (same parts), then "Look it Up" 'click' Wheel Cyl & Parts, then "Look it Up" ~ Tom |
