1970-GT
Lots of members have upgraded there front brakes, so you guys know what works! What is the simplest bolt on and go method? and the cheapest way to improve the front brakes on a street GT? I want to keep the stock master cylinder! I have 14 x 6 BMW wheels. Are the 75 Manta disks vented? Should I just cross drill stock GT disks? Use 74-75 Manta calipers? Places to find the parts? Your input would be appreciated! Thanks Lyle |
No, the 75 big brakes are not vented or cross drilled, but I would say they are the easiest and least expensive upgrade. Take a look a what FrankDaTank did which are available from precisionbrakes.com for about $1200, which is a 4 piston bolt on set.
1970-GT
Jeff, The Tire-rack sells Brembo disks for a GT for $25/pc. I was going to slot & cross drill them on the CNC.
Will the larger Manta calipers work with this disk? or should I use the Wilwood calipers? Lyle |
If you use the earlier discs with the '75 calipers then a small portion of the pad won't be on the disc negating any advantage the larger pads of the late model calipers might have had.
Harold |
1970-GT
Harold, thanks for the info. So the disks are larger in diameter, how about width?
I cant find Manta Brembo disks! If I do will they fit on my GT? Any suppliers you know of ? Has anyone just slotted & cross drilled the stock GT disk? And used ceramic pads? Simple and cheap! Lyle |
1970-GT
What year BMW calipers did you use? Lyle |
No Access
Lyle the mid 80s BMW 318I calipers fit just fine. You can get them for around 50 a pair used. I got the direct # for Brembo through autobarn and they hooked up a Texas distributor that had 2. part # is 25052 and they sell for about 32 each including shipping. Tim's set had a built in switch for pad wear that I thought was cool. Ya I did the parts setup for Tim.
Lots of good info on this Forum, but have a read at
http://www.opelgt.com/forums/performance-suspension-braking-upgrades/1094-bmw-77-320i-front-disk-brakes.html especially post #7 and http://www.opelgt.com/forums/performance-suspension-braking-upgrades/6623-increasing-brake-size.html in post #4 HTH
If anyone is planning on using the '75 calipers on the GT the bleeder screws wind up on the bottom and a different fitting is required for those calipers. I believe it is called a ISO bubble type fitting.
I put my calipers on so that the bleeder screws were on the top like they are supposed to be but had to make a really short metal brake line. HTH, Harold |
Harold,
I think your thinking of the BMW brake calibers; they have the bleed screw on the bottom if put on the correct side but there is no problem if you switch them left for right. I have the '75 Manta lager brakes on my GT and the calibers are on the correct sides, per the markings on the caliber, and the bleed screw is on the top. Both the 75 Manta calibers and the BMW calibers need an inlet adapter or a specially made flexible brake hose. The adapters are available from OGTS and from Earls Fittings. hth Brian |
1970-GT
Thanks for the help, this site as usual has so much info! Sometimes, its confusing to put all of it together!
Since Im not racing, and live in flat country, brake fade will not be an issue. Here is the plan: *Brembo 75 Manta solid disks, if I can find them! I will cross drill them myself. *BMW 318I calipers (1985) *Stainless brake lines Any part #s for the calipers? Napa?Auto zone? Are the bleeders on the top? Lyle |
#14 (permalink) | |
1970-GT
Will start to look for parts! Lyle |
#15 (permalink) | |
Bob |
#17 (permalink) | |
1970-GT
I just want a simple/cheap bolt on improvement. Bob, I will take your advice and keep the disks un-drilled. Less work is good! Lyle |
Lyle,
I don't know how much $ you want to spend but it sounded to me like the precision brakes thing I mentioned at the top of this thread was specifically designed for the GT and bolts up the way you want it to.
#20 (permalink) |
I have or had two sets of calipers off of '75 Manta's. IIRC the GT calipers had the inlet hose at the bottom of the caliper and the Manta's bleeder screws and inlet were at the top. I'll have to go check now.Harold |
#21 (permalink) | |
The "Drill"
There may be some slight use for drilling holes in brake discs on heavy, short term use on race tracks but on the street drilled discs crack between the holes; the holes fill with mud and rust which just means that the softer street pads get ground away faster. Drilling the discs yourself is not quite as simple as it seems at first glance. What hole size? How are they to be spaced? How are they to be champhered to reduce stress raisers and the impact of the hole edge on the pad? etc. etc. Even professionally drilled rotors can fall apart under heavy use with a stuck caliper puck which puts huge side thrusts on the disc. This is all more likely to "go sour" on the street under extended usage. Good Luck!
#23 (permalink) |
1970-GT
OK, no drilling or slotting! Too much work anyway!
What about the ceramic pads? Another racing product, not needed on the street? Do I really need to upgrade my street GT's brakes at all????? Lyle |
#25 (permalink) |
No Access
Opel in thier infinate wisdom did a brake bias of 65/35 on the GT. This means the fronts do almost all the actual braking. With a very lite car and tendency for the rear not to hook up all that well just spells disaster. Granted my brakes are nowhere near stock now but at least it stops flat. Better pads are a good idea but more braking force all the way around sure makes a difference. I run a 50/50 bias and the change is night and day compared to stock. You have to look at the whole picture when you start modifying the stock brakes.
