Old 02-20-2006   #1 (permalink)
helicopter hellhound
okiejohn's Avatar
okiejohn is on a distinguished road
Unanswered: Addco versus OGTS sway bars
there is a set of addco front and rear sway bars on ebay has any one used these with sucess?http://cgi.ebay.com/ebaymotors/Opel-...0521489QQrdZ1? or are the ogts ones better?? thanks
okiejohn is offline
Old 02-20-2006   #2 (permalink)
I moved this to the correct Forum and added the photo...
I have the Addco bars on my GT, and found them a HUGE improvement to the handling. I can't speak for the OGTS bars as I have never driven a GT with them, but there are some differences. The OGTS rear bar requires brackets be welded to the differential (although I have seen a bolt-on bracket; OpelJim, did you ever mount them?) while the Addco bar uses a simple angle bracket bolted to the spring bucket. The front OGTS bar brackets mount under the front engine cross member, while the Addco bracket attaches via holes drilled in the frame rail. So I would suggest that the Addco bars are easier to mount. But I have "heard" that the OGTS bars are a bit stiffer, so might be more performance oriented (at the expense of ride?).
JM2CW
Old 02-20-2006   #3 (permalink)
No Access
I've driven GTs with both types and the Addcos are fine unless the car is lowered. If it is it tears them up pretty good especially the front. The Ogts bar mounts differently and is a larger diameter than Addco and welding and other things make them harder to install. There is a pretty good price difference too. Just my experience with them.
nobody is offline
Old 02-20-2006   #4 (permalink)
petrieopel's Avatar
petrieopel
The ADDCO sway bars seem like a good deal.
Trent
www.OpelGTMotorsport.net
petrieopel is offline
Old 02-20-2006   #5 (permalink)
New Addco's are 135 for the front and 135 for the rear.They look good.I haven't driven it yet though.
GT Tim is offline
Old 02-20-2006   #6 (permalink)
Willy_g77's Avatar
Willy_g77
i have the addco front sway bar... major improvement in handling!!!
{)BILLY(} & The 71' GT
73 manta luxus
real cars don't power the front wheels...... they lift 'em
Willy_g77 is offline
Old 02-21-2006   #7 (permalink)
There is also an other set on there now.
GT Tim is offline
Old 02-21-2006   #8 (permalink)
opelnut10's Avatar
Sway bars
I have a GT/J european model with the factory sway bars, I went with the OGTS bushings instead of the stock ones, which were 30 tears old. It made a big improvment in the handling. Even when I went to the open driveshaft rear they plant the car flat in about any corner I have tried it in, almost neutral steering. The rear bar is most important, in my mind and that can be achieved by using a kadette unit, but it does require putting brackets on the rear end housing.
opelnut10 is offline
Old 02-21-2006   #9 (permalink)
jordan's Avatar
I have OGTS bars on the front and rear of my gt and the ride isn't compromised but the performance is definitely enhanced.
1970 Opel GT 1.9
1980 Moto Guzzi V50
2000 Saab 9-3 2.0 turbo
2000 KTM 200 exc STOLEN
jordan is offline
Old 02-21-2006   #10 (permalink)
OPEL-LESS!!!
greensmurf20's Avatar
greensmurf20
i have front and rear ADDCO bars on the GT i have at the house. they are a easy bolt on installation and are not hard to do. they work good for daily driving and make a noticable difference over stock, altho i've never driven or ridden in a car with OGTS bars.
currently own
greensmurf20 is offline
