Page 1 of 3
1 2 3 LastLast
Results 1 to 20 of 41
Thread: Header dyno #'s?
    Member Wolf Spyder is on a distinguished road Wolf Spyder's Avatar
    Mississippi
    413
    Header dyno #'s?
    Has anyone got any dyno numbers compairing stock, Pacesetter and sprint headers?
    LIFE IS NOT A JOURNEY TO The GRAVE WITH THE INTENTION OF ARRIVING SAFELY IN A PRETTY AND WELL-PRESERVED BODY, BUT RATHER TO SKID IN BROADSIDE, THOROUGHLY USED UP, TOTALLY WORN OUT, AND LOUDLY PROCLAIMING...
    "WOW! WHAT A RIDE!"
    7,554
    Quote Originally Posted by Wolf Spyder
    None that I know of, especially with a comparable combination. Exhaust diameter, carburetor type, camshaft, early engine?, late engine?...lots of variables. I wouldn't expect much from just a Sprint manifold on a stock engine...remember the 1975 Opels were only rated at 5 hp more than the '74 Opels, and this was with the EFI system and the Sprint manifold installed. Same goes with a Pacesetter on a stock engine...they usually feel lethargic below 4500 rpms in fact, far worse than even the stock exhaust manifold. On a modified engine, the Pacesetter starts to make a difference however.
    I am currently working on a 'street' GT tubular header, and hope to dyno a bone-stock late-model (low compression) engine with the standard exhaust manifold and exhaust system, plus a 32/36 DGV Weber on a stock intake.
    Then I want to pull the stock manifolds, and bolt on the header with another stock intake.
    Then I'd like to bolt on a ported intake.
    Then a larger diameter performance exhaust system.
    Of course, this will require jetting between each dyno session, but it would be interesting to see how each mod affects power and torque. When the header and exhaust are done, I'll be looking for someone in the New England area willing to have his car tested for posterity (dyno shop is in East Hartford, CT).
    Link to dyno shop map: http://www.mapquest.com/maps/map.adp...maplink2&name=
    5,072
    form a que only 1 entry per member
    Quote Originally Posted by baz
    Hope you don't mind Baz, but "que" isn't a common word here in the "Colony".
    Form a line, only 1 entry per member, is more appropriate, at least on this side of the pond.
    5,072
    dont mind at all just wish i had my cay in NE with a stock motor in it
    Senior Contributor Travis
    Apr 2002
    Temple, NH
    780
    Quote Originally Posted by RallyBob
    Do you have an estimated date?
    -Travis
    7,554
    Travis, this will be a small tube header for a stock engine. Probably not the best thing for your engine's state of tune.
    Apr 2002
    Temple, NH
    780
    Yes, I understand it will be optimised for much lower power motors then mine. However, it would still be interesting to see how it compared to my current sprint manifold.... and a good reason to take a day off from work
    -Travis
    Opeler Opel1_9 is on a distinguished road
    Jan 2006
    Danvers, MA.
    38
    I'll volunteer my bone stock 72 GT as a candidate. No doubt I'll be one of many volunteers.
    7,554
    Thanks guys. I'll post back here when it's ready for fitment. Maybe we can try both cars.
    I expect Travis will lose some power due to the smaller tubes and a full exhaust system with two mufflers, but on the other hand some low-end torque gain is entirely feasible. I want to make it pretty quiet too.
    When I build the second design (slightly larger tubes for larger displacement engines and/or built-up 1.9/2.0's), then I think Travis will see more benefit. But I'm strictly speculating. The dyno will tell all...
    Swansea, MA
    5,281
    My stock '72 wagon with Solex is available.
    This Space for Rent
    5,072
    quick gary do some editing and you will be the only one
    Oh, man, how I wish there were a chassis dyno near here! Just to play with fuel octane and ignition timing and valve timing...
    Senior Contributor calvin calvin's Avatar
    St Louis, Mo
    657
    when I switched from the standard opel header that is always for sale on ebay to the Rhonet (spelling) system that I got from BOB I think I lost some low end however it goes faster and there is more oomph in the middle and I think it breathes better should I by oversight chance to exceed the speed limit
    On the other hand now there are weber 48ies and not 40ies (if you pull the manifold off why not change the carb and headers at the same time? Same amount of bolts and you have them off already) of course the cam is different too.
    1,665
    Bob, as you perform each dyno run, could you please documrnt and post the setup for each run? Especially jetting and cam profiles.
    Mississippi
    413
    Quote Originally Posted by namba209
    Tis legal in Scrabble!
    "WOW! WHAT A RIDE!"
    7,554
    Quote Originally Posted by opelwasp
    That's the plan. Stock cams only though, that's the whole idea of this test, to see the results on a bone-stock engine. Too many variables will skew the results.
    Of course, air temp, humidity, gasoline brand/octane/chemical composition and altitude will mess the jetting up for other parts of the country. You really have to tune for your specific region.
    7,554
    Quote Originally Posted by Gary
    Sorry, GT's only on this one!
    True, but the key phrase I used was "common word". I too have used "que" playing scrabble.
    Now getting back on topic, I would really like to see the numbers that will come from the dyno runs. If nothing more than to see if what I'm doing with Willit? has really been worth all the time and money expended.
    2,640
    To quote a great movie line, "You can't handle the truth". But it has been great reading for the rest of us and a real journey for you. So, yes it's probably been worth it because you would have always wondered, what if?
    So Ron, keep up the good work and updates on Willit.
Page 1 of 3
1 2 3 LastLast
