i was lucky ehough i had a puller around its the same one used on the bitters and several others it works like a charm if u can get one. it also has a little ball bearing in the center screw part which keeps it from slipping when u tighten it down. i have heard u can get a type of pilot bearing remover that will do the same trick. i also saw a pic of a custom one looks pretty easy to make.also which wheel did u get from nardi.
