Are you asking about the bearing in the bell housing that is moved by the clutch throw-out arm (this is called the throw-out bearing), or the bearing that goes into the end of the crankshaft (this is called the pilot bearing)?
Are you replacing the clutch with a stock type or an S10 type?
For the stock type, the throw-out bearing should be a close fit on the metal sleeve on that protrudes out into the bell housing, but should move smoothly. The pilot bearing should fit closely on the front tip of the transmission's input shaft. If either one is loose, then it sounds like you have the wrong one.
Regards,
Mark B.
