how long did you run the car ? these old cars have a lot more water to heat up than a new one so it takes some time to heat it all
did you have the fan on too ?
here's the deal guys: i was working on my car in the garage and the heater level switches on my 67 kadett disconnected (actually broke off) from the wire lines. i fixed them at least for now but i can't feel any heat. yes i made sure that the switches were to left to allow maximum flow, but i do not feel or hear any air flow. what might be wrong? please help!
*special note: i did not take it for a test drive, just turned it on inside the garage, does the car have to be moving for the heater to work correctly?
it's not a lowrider, it's an all nighter!
ran it for thirty minutes. checked the wires that attach to the blower switch and they seem to be okay. there is a cream colored wire and there is a black one.. switched them around but still nothing.. what could be wrong?
there may be an air lock in the heater matrix stopping the water getting there , i dont know the kadett well so cant remember if it has the same switch in the water hose but ob a gt there is a valve just before the heater hose enters the fire wall , if the kadett has this it might be in the water off position
as to the wires you dont want advice on them from mei could rewire your radio as a heater but it would be a one off job as it burnt
it's in the ON postion. hm...
Mario;
Did you flip the deflector handle under the dash? There's a handle to way up under the dash that changes it from running in fresh air from the outside, to using just the air inside the car. It should have a little black ball end on it and it'll click or ratchet sound as you pull it.
Just a thought.
Gene
in the engine bay or on the dash ?
gene does the kadett use the same valve as the gt in the engine bay ?
Baz;
If you're referring to me, this handle is in the passenger compartment, under the dash, driver's side, almost in the center up under the dash, it's just a little short handle.
yes gene you
i was thinking of a water shut off valve ,cable operated , i dont know which way the kadett regulates water to the heater matrix but thats how the gt does it
Baz;
I was assuming that he already checked that, but, this is something that if you didn't know about it, you'd never find out.
The heat control valve on my '69 1.1l is the same as on 1.9l Kadetts.
I would check the lever under the dash, it will cut off all air flow from the heater/blower.
hth
Kevin
soory it took me a while to write back. anyways, yes sirs, i moved the delfector handle under the dash on and i made sure that the valve near the heater core was open. you should hear the blower right?
Mario;
Yes you should be able to hear the fan, especially on high
hm..... i connected a couple of wires that were disconnected. one was cream colered and the other one is black. here's the deal: they are not in the same group of wires. one is wrapped in a grey tube along with other wires and the other is wrapped elsewhere. hope that i did not confuse you guys more than i am right now. can any of you have the courtesy to send me a pic of what the set up should look like?![]()
Mario,
If I'm understanding your problem correctly you're concerned with getting the blower to work. Do you have a simple circuit tester light that you can use to determine if electricity is getting to the switch? This was the first electical tester I bought and it helped me figure out ALOT of my electrical problems on my first Opel.
Mario;
As you have not mentioned it, I have attached a wiring diagram. This is for a '68, but, I think it's better than nothing at allIf you PM me your e-mail address, I'll send you the bigger file for easier viewing.
Gene
i do have a tester mr collins but where do i start?
