I've only had one real severe electrical problem on a stock GT, and it was a sweetheart. I was tuning the engine on Willit?, with it running, timing lite, dwell meter, the standard stuff all hooked up. Smelled wiring burning and sure enuff smoke was rolling out from under the fuse panel. I shut down the engine and disconnected the battery post haste, but not fast enuff. The whole fuse panel was toast along with 80% of the wiring. It turned out, the resistor wire to the coil had just been stuffed in the power panel area and years of constant vibrations had finally worn away the insulation, right next to the 4 studs in the center of the panel. One thing led to another and shortly the insulation melted away from a ground wire and the whole mess went up in smoke. 3 days to remove a harness from a donor car at the recyclers and 5 days to repair and replace what was gone. Got an electrical education on that one.
Enough said
