Where is the best place to buy a Weber carb 32-36? Thanks this is going on a 71 Opel Gt. Would like to buy brand new put a good used one would be fine. Thanks in advance, Brian
The cheapest I have found was $239.95 for a new 32/36 w/electric choke.
well maybe this will help,was looking through eBay and found these
eBay Motors: Opel GT Weber Carburetor 32/36 (item 230135863730 end time Jun-03-07 20:30:00 PDT)
eBay Motors: Weber 32 36 Carburetor KN Filter Opel GT Electric Choke (item 320119279525 end time Jun-05-07 11:00:00 PDT)
Rex
{Elda} "code green"1969 Opel GT 4 speed,Weber carb,Pertronix electronic ignition.
1972 parts car auto-RIP
1972 parts car -Rip
{saphire}-1993 yellow nissan pick up 5 speed!
1993 red nissan pickup automadic (unamed for now)
{Alexia}-1989 chevy camero
{Elliott}-1978 Pontiac Firebird
-1989 Ford probe(unamed for now)
17 years old -6 vehicles... and still moveing on
WATCH OUT,I'M A OLD CAR FANATIC!!!
Future wanna be concept and custom car designer/builder.
Weber Parts
32/36 DGV Series
Genuine Weber Carburetors
Any search for the ideal 2-barrel, progressive down-draft carburetor would surely end with the DGV Series. look no further for versatility, wide adaptability, easy installation, low initial cost, trouble-free maintance, excellent drivability, increased fuel economy and improved performance. Designed for 4-6 cyl engines, the DGV Series carbs feature diaphragm type accelerator pump circuits and models with manual, water or electric choke actuation. The DGV also has a power valve circuit to facilitate low vacuum running conditions.
Carb Part#
32/36 DGV 5A - New Manual Choke Carburetor
Rebuild Kit - Float - Base Gasket 22680.005
$239.96
Quant
32/36 DGEV - New Electric Choke Carburetor
Rebuild Kit - Float - Choke - Base Gasket 22680.033B
$239.95
Quant
32/36 DGAV - New Water Choke Carburetor
Rebuild Kit - Float - Choke - Base Gasket 22680.051B
$249.95
Quant
32/36 DFEV - New Electric Choke Carburetor (reverse direction)
Rebuild Kit - Float - Choke - Base Gasket 22680.070
$259.95
Quant
IF you find it Cheaper We will Beat It !!! Just Call 1-800-994-2272
Jet kits and parts
Yeah the first one I saw also but it is a manual choke. But the second one I was just kind of leary about it sitting for a few years and the rubber diaphragm drying out and cracking. Then again, a rebuild kit would still be cheaper than a new one. Plus it comes with a K&N
Hello I have 2 , new carburators Weber .in the original boxes
480 $ each from france contact me if yoi like at. d.j-eemi@wanadoo.fr
in fact i bougth to use on my GT buy finally I choose 2 Delorto carb.
Well I'm finally able to get a 32/36 carb for my brother. The instruction say to tighten the studs down to about 10 in/lbs well the problem is if I do that there isn't enough stud sticking through to tighten the washers and bolts to the carb using the thick gasket. When tighten down there is about 1/2" of stud it needs to be at least 3/4" to be able to tighten the carb down. Do I need to put some blue thread lock on there and put it to the right highth or get new longer studs. I think after using the thread lock it "should" be ok but I just wanted some extra experience to help me out. There is also a cardboard gasket that looks to go in between the carb and intake manifold. Do I use both gaskets? If so does cardboard go down first or does it go on top of the thick gasket?
Thanks for all your help [Brain]?
This pdf will tell you all you need to know, well at least a great portion to get started on the right track... enjoy!!!
Thomas
nice,a lot of info there!
PS i'm looking for a good used Weber carb![]()
Last edited by tekenaar; 07-18-2007 at 02:41 PM. Reason: a webber is only on the web . . . it's Weber!
Rex
1972 parts car -Rip
ok,thanks
Rex
1972 parts car -Rip
Thanks for all your help Brain
Brian;
You can go by a hardware store and get longer studs to go in. I don't the exact size, but, someone might chime in.
Thanks BQS4, That's kinda what I was thinking about doing anyways. I'll just take the new studs that came with it and get longer ones. I just figured if it came with the kit it should work. Oh well I should have known better![]()
The first rule when working with Kit Parts.
The Kit may not contain all the parts you need, but will certainly contain some that you don"t...![]()
Help me understand this, you're replacing the original Solex with a 32/36, right?
If so, manifold stud length should NOT be a problem other than possibly being too LONG! Let me explain, the throttle base of the Solex is ~3/8" thicker than that of the Weber, so something else is amiss here.
BTW, when you get that far, you should use the same "stack-up" on your Weber as was used on the Solex - manifold, paper gasket, metal heat shield, paper gasket, 1/8" phenolic spacer, paper gasket, carb base! . . . and NO SEALERS!!!!
my son and I rebuilt the carb ( weber ) on his GT last weekend and the PO had stacked washers about 7/16 deep to make up the difference. It was kind of a pain to work so we went looking for new studs and found a four pack at shucks auto of 8MM X 1.25 X 8MM X 1.25 bolts. the short side has 7/16 of thread and the long side has .800 of thread with the shoulder being 3/16 long. worked perfect with the only difference being coarse thread instead of fine on the long side, nuts and washers to boot!
Last edited by tekenaar; 07-20-2007 at 10:10 PM. Reason: course - path; coarse - not fine
