That's the reason for the seal forward of the cowl plenum, to seal off the engine compartment heat from entering the cabin. If your hood does not close down on the seal, you will get hot air in from the engine compartment. With the Lenk Tuning Hood on Willit?, I had to raise the seal plate to match the inside of the hood and get after market bulb seals to close it all off. luckily, I got bulb seals that were 1/2" and with the hood pins it sealed the area nicely.
