Is a specific cylinder miss-firing, or is it random and sporadic.
If sporadic, check your internal ground strap in your distributor. These models have a habit of breaking that ground strap loose.
new motor and carb new cap and rotor plugs wires timing corect carb adj and still missing new coil too
aggh running way rich too![]()
Opeler Forever,
Ben
Ben, if you're running the stock jets that came in the weber then there is no doubt you are running rich at our altitude. The weber is jetted for sea level so you will have to lean out the mixture by changing your jets. If you look on line I believe there is a web site that tells you the jetting. I know Liz has a cheat sheet as well.
what ground stap
running jets 140s in float bowl
160 and a 170 on top and
two 50s in the outside
Opeler Forever,
Ben
I am about to overhaul my Weber and wonder what jets I should use at 4500 feet altitude.
Denny
here is pic
now where does the braided ground strap
need to be![]()
Opeler Forever,
Ben
new braided ground strap
retimed re adj carb new jets i put 130's in the float bowl left the rest
past emissions at idle
hcc standard 700 reading 220
co standard 5.00 read 1.44 co2% 13.6 at 856 rpm s
high speed test hcc standard 700 reading 394 co% standard 5.00 reading 10.44 co2%7.6 at 2389 rpm
help still runing rich right ?
Opeler Forever,
Ben
with a co reading of 5.00
If i remember this right try to hit the 3.0 range for the CO reading I believe thats 12:1 air fuel ratio best for power!!
yep your rich as beep
This and that
High carbon monoxide (CO) emissions are a telltale sign of a rich fuel mixture. On older carbureted vehicles, fuel-saturated plastic floats, incorrect float settings, leaky power valves and misadjusted chokes are often responsible for the rich mixture. On newer vehicles with feedback fuel controls and fuel injection, leaky injectors, excessive fuel pressure and sluggish or contaminated O2 sensors are all possibilities to investigate.
...I pulled the above off the following website.. Emissions Testing: Exhaust Analysis
More possibly pertinent information further down on that page regarding failed CO emissions at acceleration. They note a flooded charcoal canister could be the problem in addition to much of the same as what's above.
How does one hook up the Charcoal Canister to a Weber anywho? Does all of Utah require emissions testing? What's the rules? I always thought in most places there was an age limit on cars that didn't require testing. You're little Opel is too new?![]()
your HC is good no misfire none at all don't worry about this part
Now I'm sure the air induction is long gone
I.E smog pump
Put a three way CAT
on and your done you can always remove the CAT after the emisions testing
This and that
after looking at my carb again i guss its 135 jets i am running
so is my jet setup is ok
or should i go to a diffent size ?
Opeler Forever,
Ben
The 135 Main jet on the Primary side is the Otto perfered size for a stock 1.9. However, you will need to check your idle jet as it is controls idle and part throttle...
Look for the "Final Rejet a Weber thread"
But 135-140 on the gas 160-170 on the air works well.
Most start with 135/160 primary 140/165 secondary
My Sons Manta runs a 32/36DGAV (18B Double Pump) Motor is a 2.0L Pistons - Stock Valves - 75 Manifold w/ 2" exhast and a 74' Manta Street/Hot Ported Intake)(2.0L Pistons, Stock Valves, 75 Manifold w/ 2" exhast and a 74' Manta Street/Hot Ported Intake. Its Jetting came too 140a/160f Primary, 140a/160f Secondary
My Kadett runs a standard 32/36DGEV, the motor is a 1.9L Stock High Compression pistons & valves, 75 Manifold w/ 2" exhaust and a 74' Manta Street/Hot Ported Intake. Its Jetting came too 135a/160f Primary, 140a/160f Secondary.
A GT I just built is running has 140f/160a Primary, 180f/175a Secondary. The Secondary was based solely on the GT was running lean during hard accelleration so I wanted to bump the jets. and these were the largest I had. I had a ton of 120-140 fuel & 135-165 air jets and these two jets, So I stuck them in to see how they would run.... it seemed to work great. The Motor is a rebuilt 1.9L w/ 2.0L Pistons & Valves, Isky Hot Street Cam, 75 Manifold w/ 2" exhaust and a 74' Manta Hot/Street ported intake.
I am pretty sure the idle jets are 50 for all three carbs.. Although I think the Manta has 55 jets on both sides.
CURRENT
'06 Pontiac GTO
'71 Opel Kadett 4 Door 36D (w/ Opel Parts & Service 2.0L)
'74 Opel Manta (Bens Manta)
'74 Opel Manta (w/ LK5 transplant)
Past
'73 Opel Manta (Blue Max)
'75 Opel Manta (Yellow)
'85 Bitter SC
'73 Opel Commodore B GS
'73 Opel GT (w/ Vinyl Roof)
At least 16 or So Parts Opels
Also look here for 32/36 jetting info . . .
Oh, and Charles, your GT is running "pig-rich" in the secondary. . . basic jetting rule-of-thumb for everything but "full-race" is not to allow main fuel jet to exceed air corrector jet size, i.e. fuel/air ratio less than 1:1.
So, just replace your secondary main fuel jet with a 155/160 and it'll run even better . . . trust me!
Opels like 4.5 - 5.2% CO for maximum power. They like fuel.
But for street use, better off with 3 - 3.5% under load. Idle can be as low as you want it to be (1 - 1.5%), as long as it doesn't have a lean-misfire condition, since that would increase HC emissions.
