I believe the pictures are showing the rubber part upside down. Need to turn them over. You may want to wait until you get more responses but I am pretty sure they need to be turned over.
Put the front suspension together but just had a funny feeling I put these in wrong. Can't remember which way they came out.
Roy Bell
1973 Opel GT
74 Manta Rallye
Concord, North Carolina
Carolina Opel Club
OMC
I second Roy's opinion, but then I'm not sure without checking that the shown pieces shouldn't go underneath the spring. Since I have a well known history of getting things "backwards", I just shut up.
I guess I was unclear...sorry. I know they go under the spring, that wasn't my question. I was asking about the orientation. Which side goes toward the center of the car, and which side goes toward the outside of the car. It fits both ways.
I believe you have them pointed right, I refered to drawings in the service manual plus others I had apart to see which hole recieved the bolt.
I like the toes on the second thumbnail.
Don't drop the suspension on them or it won't matter anymore if the rubber parts are upside down or not.![]()
Definitely EX-member of the MWTE! © Mr. Corey Suggs
The one's on my Kadett axle are in like in picture 1, but I'm not claiming this is 100% correct.
When we were trying to figure out how the front spring worked, we determined that the part you're questioning might be an adjustment, could go in several different ways for softer or harder spring rate. Don't know for sure.
But I do know this, if you have some extra silver paint left, it would look great on your toenails.![]()
Check post #6 in the following thread- http://www.opelgt.com/forums/3a-fron...ront-axle.html
I am pretty sure it is like the first picture, the one on the left.
