Well, I guess I have been called worse than "Tilford"! And you're welcome.
As for the clutch cable, it can be lubed, but it might be related to the clutch release arm or the pressure plate. Do you know if it still has the stock clutch, or was it upgraded to the Chevy S-10 disk and pressure plate? I don't know much about the specifics of either conversion, but it might be related to either the release arm pivot (the S-10 pressure plate requires the flywheel be ground flat, which in turn requires the pivot bolt to be screwed further in that factory spec) or the guide tube that the release bearing slides on. I haven't heard of stiff clutches related to either coversion, so there must be some kind of problem.
And I moved this post to the "Drivetrain" heading, since it is happier there!
