I thought for sure I would be outbid. I emailed the seller the day before for more info. He said it had a good title & was already notorized. My max bid was a bit over $500
The car came with a new set of AE .030" over pistons. But the bores are really clean with no ridges or marks. I think a light honing & new rings would be fine as long as I can free up the pins. I'd hate to bore it out if it doesn't need it. I wouldn't mind building another "hopped up" engine for it though. Something like what Kevin has in his wagon.
There are 2 sets of pistons on eBay right now at $100 each. there's also std. & over rings for around $10. My egine is the base 1.0 not the 1.0 S with a little more HP. I think the "S" pistons & valves could be used. I'll be asking more questions & reading old posts as I build the engine. If I understand correctly the 1.0 is basicly the same as the 1.1 & later 1.2 engines.
