Dave,
What material thickness are planning to make this from? Do you have a dimensioned sketch? Even one that has been hand drawn? I can draw it in 2-D in Auto-Cad... or better Yet cut you one on the Water Jet at work...
Lemme Know
I am supposed to make this on the CNC tonight but i've been stuck for the last 2hrs just trying to make a drawing of the dang thing
I am trying to get the instructor to add inventor but auto desk so i can try it
solid works is a very painful program
anyway 2.2 intake flange (took 3 days to make ha ha)
Dave,
Lemme Know
Don't forget that the flange can't have those through-holes for mounting or they will overlap with the exhaust manifold. They need to be half-moon.
i agree autodesk inventor is easier but if you think solidworks is a pain try Pro/E
No i haven't run unigraphics, but i hear it's as bad as you say.![]()
They have just started using it here at my job. It has been a real pain. AND unfortunetly it is just about the only system we can run...
Dean
"Taste Death, Live Life" - "HotDog" - The Movie
Paul i forgot my thumb drive but i will get the info
i finally figured out how to do a drawing (you have to open up a blank drawing and import your part)
Bob i have to put the holes there so i can bolt it to the fixtureDon't forget that the flange can't have those through-holes for mounting or they will overlap with the exhaust manifold. They need to be half-moon.
the Solidworks works off relations to one another so you cant just go in and change one line
I started version "D" this time everything is coming from the dowel pin
thanks
David
We use Solidedge here at school and it seems pretty straight forward. Might wanna see about using it instead.
-Conrad (1971 GT)
Thanks for the info I found solid edge’s web sight but I can't tell too much from it
Well I finally got the drawing right at the end of class on Thursday
They have these things called radius gages to find the radius of different items. 1/2" was the biggest they had so I took to using different size sockets
One of the young kids in the shop helped me when he measured the size of the socket with some calipers, I was like Doh! The outside diameter of the socket not the size of the socket you dummy (talking to my self) ha ha
I am going to use 1/2 inch plate. I only had a few min of class time to upload this image so it’s not so hot
Davegt27
Dave, I have a suggestion, but don't know if it is something that you can do with the equipment available to you.
Have you considered making the port openings on your flange angled 'upward' to coincide with the roof of the 2.2/2.4 intake ports? This way instead of having a port that angles upward, then goes horizontal for 1/2", then angles upward again....you have a smooth transition from port to intake runner.
I'm also curious if you are going to keep the port shape symmetrical or if you're going to change the upper radii to match the stock head castings (which are asymmetrical from top to bottom). If the radii on the flange are smaller than the OEM port opening shape, then there will be quite a bit of turbulence due to the interference.
I can have the CNC take an angle cut so I was going to have the cut angled at the topHave you considered making the port openings on your flange angled 'upward' to coincide with the roof of the 2.2/2.4 intake ports? This way instead of having a port that angles upward, then goes horizontal for 1/2", then angles upward again....you have a smooth transition from port to intake runner.
the instructor said to just do a 2D drawing and we can get it cut out pretty easy
one of the you kids in the class (the same one that made me see the light on measuring the outside diameter of the socket) jumped up on feature cam and had a 2d drawing done in a 1/2 hour that was pretty close
he also did a tool path simulation which was pretty cool
OK you just lost me; I know the gasket had some flats at the top instead of the rounded radius.I'm also curious if you are going to keep the port shape symmetrical or if you're going to change the upper radii to match the stock head castings (which are asymmetrical from top to bottom). If the radii on the flange are smaller than the OEM port opening shape, then there will be quite a bit of turbulence due to the interference.
Other then that my drawing matches the gasket almost exactly
Let me try to upload a scan
Davegt27
Here's a pic of an intake for a 3.0 head (same ports as 2.2 and 2.4). You can see that the lower corners of the intake ports have a relatively tight radius, similar to a 1.9 intake port. But the top corners of the intake port have a bigger radius, so the intake ports look a little bit like a 'tunnel' in the side of a mountain, if you know what I mean. A bit more square at the bottom, and a bit more rounded at the top.
OK I see
I have a copy of my final drawing and I just laid the 2.2 gasket on top of it
The top of the intake port, I made it match the bottom which means I opened up the tops radius a little (it starts out as two radii)
The radius I have for the bottom is .406
Ht of the port I have 1.582
I can’t get Photobucket to work so I can’t show you a scan
David
David, looks like your learning alot.
The CNC machining trade can be fun/challenging.
What CNC machine are you using?
How are you going to generate the G-code program?
Have you got a machining plan yet?
How are you planning to hold the 1/2" plate?
What are you going to machine first?
What size end mill?
I have a few ideas, but want to see how they/you want to do it.
It's a perfect first CNC project to learn on, have fun!
Oh, remember to lock out the "Z" axis when testing the program the first time!
Lyle
They have 3 Haas CNC machinesWhat CNC machine are you using?
http://www.haascnc.com/VMC_MODEL_HIG...p#VMCTreeModel
I had the chance to sit in on one of the G-code classes but I don't think I will be generating G-code for this projectHow are you going to generate the G-code program?
If you mean have I figured out the tool paths then no.Have you got a machining plan yet?
The first step I did was to make a fixture on the manual mil.How are you planning to hold the 1/2" plate?
I guess I need to drill and tap some holes in the fixture next.
Not sure I think the next step is to export the drawing to Feature Cam so I can figure out the tools and the tool paths (then it goes to master cam I think)What are you going to machine first?
What size end mill?
Solidworks is pretty cool but hard and frustrating. I can now see why it cost so much to get things done.
I have started work on the throttle body flange and its even harder then the head side
David
The drawing gets exported to master cam
My instructor wrote the program and worked out the tool paths
Program took 8 min to run
This is the end part
David
Very cool parts Dave!
thanks guys
pretty cool being able to get stuff done
working on the TB flange now
Davegt27
