Results 1 to 20 of 30
Thread: begging for help.
    1971 Opel GT maglinjosvinn is on a distinguished road maglinjosvinn's Avatar
    Feb 2006
    Lansing MI
    383
    begging for help.
    this is the story to date:
    i'm using a solex on my 1.9L engine. this weekend, i took that solex off, dipped the parts in a bucket of cleaning agent, put everything back togehter with the new bits, and start the engine. its beautiful. fires right up after a couple presses of the pedal and idles at 1000 rpm, no questions.
    i fiddle with the idle air and mixture screw according to the rebuild kit's direction. i got my timing (with vacuum lines off) so that the dot on the flywheel is deadnuts on the pointer arm.
    so. i go for a ride. will not run under power. chokes off and dies every time. ok. cool. fiddle with it some more, nada.
    so i'm talking to this one guy, and he's like i don't know opel, but i know cars a bit, pull back your timing and see what happens. i do it, car revs up and its freakin AWESOME sounding at higher revs. but now it wont idle, and even though i've set the timing back again, it STILL won't idle.
    when i'm on the road i have to have the gas pedal ALL the way down in order for it to run... i can pick a speed and go that fast, i gotta always be accelerating.
    so. i need help. suggestions, ideas. so forth, so on. thoughts and input very welcome at this point.
    Pb Blaster is to opelitus what brown paper bags are to alcoholics. neither really cure the ill, just make it easier to pretend its not so bad.
    Opelitis since 1984 GoinManta is on a distinguished road GoinManta's Avatar
    Midlothian, VA
    2,233
    OK... a shot in the dark here.. Have you checked for vacuum leaks at the carb base? Set it back so it will idle and test by spraying carb cleaner or starting fluid at the bast while idling... Wouldnt have a open vacuum port on the inside of the carb next to the head that wasn't plugged ? Really sounds to me like vacuum issue of some sort.
    Charles
    CURRENT
    '06 Pontiac GTO
    '71 Opel Kadett 4 Door 36D (w/ Opel Parts & Service 2.0L)
    '74 Opel Manta (Bens Manta)
    '74 Opel Manta (w/ LK5 transplant)
    Past
    '73 Opel Manta (Blue Max)
    '75 Opel Manta (Yellow)
    '85 Bitter SC
    '73 Opel Commodore B GS
    '73 Opel GT (w/ Vinyl Roof)
    At least 16 or So Parts Opels
    Feb 2006
    Lansing MI
    383
    *nods* open port? where would i find something like that. i'll be sprpaying all the vacuum anything with quik start in the morning.
    Brother, it's 1 freak'n degree outside! I just got back inside and my brain's frozen. Hope you have a heated garage. I don't.
    Feb 2006
    Lansing MI
    383
    hahahaha. *FEARLESS*
    i was outside last night in the wind trying that solution with the pulling back the timing.
    i'm serious.
    i don't want heat. iwant a smooth running GT.
    Last edited by tekenaar; 01-20-2008 at 10:15 AM. Reason: dono't - either "do not" or "don't"
    Quote Originally Posted by maglinjosvinn View Post
    I hope you dont mean starting fluid.......Its a bit volatile. WD-40 might be a BIT less dangerous. I've seen some pretty big BOOMS with starting fluid....I hate that stuff.
    just be careful. The open port would be down at the base of the carb, usually there is a short piece of hose clamped on it and plugged but it may be missing on yours. Check the float level as well it might be wrong.
    Man I hate the solex.... I fought with mine for 10 years till I finally gave up on it.
    Joe
    2,668
    Your problem has probably already been diagnosed by others, the problem now is to find the leak. While you're under the hood check the advance mechanism in the distributor to see if it is moving freely. Underneath the rotor button is a small piece of felt type material, add a few drops of light weight oil to it to help keep the advance mechanism moving freely. This is often forgotten.
    1000 Post Club Sparky73 Sparky73's Avatar
    Jan 2004
    Saginaw, MI
    1,269
    Quote Originally Posted by jvandyke View Post
    Same here! I had been sick all yesterday with bad acid reflux.. so I stayed most of the day inside in bed. Girlfriend came over for a while and when she went to leave at around 11 last night, I finally felt it! Wasn't it just 40 something a few days ago? LOL
    Current
    1970 GT; Under Construction
    Previous
    1969 GT; Street/Strip Project
    1969 GT; White with Black Interior, Automatic
    1969 GT; Black Parts Car
    1969 GT; White Parts Car
    1970 GT; Silver with Red Interior
    1971 GT; Orange with Black Interior, Turbo
    1972 GT; Red Parts Car
    1972 GT; Blue with Black Interior
    1973 GT; Pearl Blue with Black interior. Full body kit.
    '72 Opel GT (Sara) newman27 is on a distinguished road newman27's Avatar
    Jul 2006
    Atlanta, GA
    1,730
    i'm serious.
    I admire your dedication! Not to derail this thread too much, but we have snow here in "Hotlanta" even!
    Matt
    Restoration Thread
    Comments Thread
    Quote Originally Posted by newman27 View Post
    I admire your dedication! Not to derail this thread too much, but we have snow here in "Hotlanta" even! Matt
    Yea, but it's a WARM snow
    Sick with Opelitus broszzy is on a distinguished road broszzy's Avatar
    Aug 2007
    Janesville wisconsin
    198
    10 below zero this morning here, glade i dont have tickets to th Packer game today....ICE BOWL II I got cold drinks and a hot fire lol
    Pat
    Feb 2006
    Lansing MI
    383
    alrighty back on track then
    pulled the carb off again, checked the seals when she mounts to the manifold...
    what i have is the following:
    carb top, 1/4in spacer, carbbottom, thin paper gasket, heatshield, slightly thicker gasket, manifold.
    i am prolly still suckin air... we pulled it and reassembled but she just refuses to idle.
    we got to get the timing set, with lines attached the dot in just a smidgen *above* the indicator window and pointer at the flywheel. she won't run worth spit when the lines are attached
    we looked at the mechanical advance. it moves, and you can suck on the vac line and she'll move just the tiniest bit, but it does seem excessively stiff. not that i would have anything to compare it to.
    pulled the plugs, they all have that nice dry burn look to them. check the points, its right. (.018 yes?)
    pulled a plug and put it right to theh coil, nice strong spark
    now. for the test runs, as long as you pump the gas pedal she'll run like a dream, but the s econd you try to just hold hte pedal and maintain a speed power goes right out the window and you gotta struggle for the next couple seconds to get rid of the backfires and stutters.
    Feb 2006
    Lansing MI
    383
    Quote Originally Posted by yellaopelgt View Post
    Joe
    wait a second... open port? float should be good... whats this jive about an open port?
    i KNOW there's two threaded holes immediately to the front (of the car) from the idle mix screw...
    and for the r ecord there's no charcoal can, it rusted and vanished on a road trip some time ago. lol.
    Pleasanton, CA
    787
    If you haven't already, take a look at these two articles. The articles have drawings of the components involved and how to go about go about locating vacuum leaks. Later on you can also do a search on how to tune your carb.
    better vac pic - Opel Photo Gallery
    Vacuum Leak Article - Opel Photo Gallery
    Flat Base ...
    Did you check the base of the carb (where it sits on the manifold gasket) for flatness with a steel rule? Over-tightening the four hold-down nuts bows them every time ... and does not seal a thing ... they need to be just gently 'nipped up'.
    The symptoms show that your motor is running lean - pumping the pedal just shoots fuel in with the accelerator pump to cover up the problem. You may have to check all the way back to the fuel tank for blockages - including the pesky 'sock' filter above the fuel pipe inside the tank. Is the fuel pump working to capacity? Is there an in-line fuel filter that is blocked (there is one inside the fuel inlet on the carb)? Did your 'cleaning' move gunge into the fuel transfer tubes drilled inthe carb or block the idle passages? Is the fuel tank properly vented? - if not a vacuum can build up in the tank stopping fuel flow.
    Oh - and if you have any water in the fuel tank or lines it sinks to the bottom ... and freezes - in your climate!
    Feb 2006
    Lansing MI
    383
    yeah... the list of miseries are all relatively possible. i know that dad cranked down on the carb today really tight, but it was obvious that the heat shield was causing it not to sit proper.
    i don't know where these spacers are supposed to go. i mean, there's obviously a thick one in the carb itself, but the heatshiueld hits the manifold and causes everything to sit funny as hell. maybe tomorrow i'll call in sick to work and get the tank pulled out. i'll have to take the sock out from the top of the tank, as the petcock is welded into place now. i'll check my electric fuel pumps' built in filter while i'm at it too.
    *sigh*
    Last edited by tekenaar; 01-21-2008 at 04:30 PM. Reason: spaceres . . . extra thick? ;-)
    Midlothian, VA
    2,233
    Quote Originally Posted by broszzy View Post
    But its a dry cold..
    CURRENT
    '06 Pontiac GTO
    Past
    '85 Bitter SC
    Feb 2006
    Lansing MI
    383
    alrighty, put another carb on it, runs 'better' but still has issues withh anything higher t han 2000 rpm. its enough to get to church tonite, but still a headache for driving 3 towns away for work.
    all new gaskets, spacers. nuts finger tight. jets are all by the book.
    thoughts?
    Midlothian, VA
    2,233
    nuts finger tight
    That would be it.. replacing the Carb doesnt solve the vacuum problem if you didnt tighten the carb down.
    Charles
    CURRENT
    '06 Pontiac GTO
    Past
    '85 Bitter SC
    Feb 2006
    Lansing MI
    383
    well... how tight am i going for? i mean, i could really reef down on them basically i turned them on by hand then tightened in a x pattern another 1/8th a turn
    the other carb has a corner that is clearly 'rolled' up on it, and very obviously the problem, despite the fact there was a good profile on the gasket.
    we also watched it run, and its obvious that there is fuel intermitantly coming out of the spout in the primary from the prime pump, without messing with the pedal. lastly, my fuel from the 'injector' in the middle of the primary is all spotty and certainly not a nice even spray.
    to make matters worse, i have to hold the choke butterfly slightly open in order to start the car at all, and setting the 'fast idle' hasn't done a thing ever for me. lol. i can get it started just fine, really, so its just a headache more than anything.
    the mechincal advance is still iffy at best, its so freakin stiff... but i haven't the slightest clue how to 'adjust' it so it actually does what its supposed to
    dad feels the intermittant power at higher rpms is from too much fuel, namely, that priming pump being all iffy.
    oh. btw . this has done this with both carbs. not 100% about the priming pump issue, but the rest is spot on.
