Results 1 to 20 of 38
Thread: Lost GT Keys, Any Help
    Italian opel owner Mike Trout is on a distinguished road Mike Trout's Avatar
    May 2005
    Meadville, Pennsylvania
    274
    Well my buddy lost the keys to my 70 GT through an envelope in the postal system in there any way I can get a new set of keys made or do I have to change everything out?
    Mike,
    Your Civic may have 1.6 Liters, But My Mountain Dew has 2.
    1000 Post Club Sparky73 Sparky73's Avatar
    Jan 2004
    Saginaw, MI
    1,269
    Sent ya a PM as well, but where is the "Can of Keys" currently located? That may help..
    Current
    1970 GT; Under Construction
    Previous
    1969 GT; Street/Strip Project
    1969 GT; White with Black Interior, Automatic
    1969 GT; Black Parts Car
    1969 GT; White Parts Car
    1970 GT; Silver with Red Interior
    1971 GT; Orange with Black Interior, Turbo
    1972 GT; Red Parts Car
    1972 GT; Blue with Black Interior
    1973 GT; Pearl Blue with Black interior. Full body kit.
    Senior Contributor Killer Texas GT is on a distinguished road Killer Texas GT's Avatar
    Leonard, Texas
    886
    Any Lock shop should be able to make you a set of keys, provided he has the correct blanks, which I think OGTS may have some, or I think it was Charlse Goin that had some, but I do rember someone having some here in the group. If you can not find any I will check at the local lock shop and see if they either have gotten more in stock, or can get them? As I had him make me 15 keys for the Opels I did not have duplicates on and bought all he had at that time and I needed a few more. If all else fails I can put an ignition lock with matching door handles together for you. (send me a PM if needed)
    rk
    68 Kadett 2 Dr 1.1 SR/Rallye Suspension
    68 Kadett Rallye 1.9/4 Spd & AC
    69 GT 1.9/4 Spd
    70 GT 1.9/5 Spd,87 Impulse PB/MC/4 wheel 10.5" vented Disc/complete suspension/power assist & tilt wheel steering
    71 Kadett 2 Dr 1.1/4 Spd/4 wheel drum brakes(project:to a 1.9 FI/Auto 75 Big Brakes/Impulse vented rr Disc, Factory AC from Buick/Opel by Isuzu
    72 GT 1.9 FI/Auto 75 Big Brakes/Impulse vented rr Disc
    73 Manta Rallye
    75 Ascona 1.9 FI/5 Spd/Impulse rr Disc brakes
    OPEL WERKS
    Mike, if your door locks and ignition switch use the same key, you could pull one door handle with lock and take it to a locksmith and mayhap they can cut some new ones from the door lock cylinder. The gas cap is a whole different ball of wax though. A master locksmith can make a key for that by judicious hand filing a key blank. But it may be costly.
    2,654
    Quote Originally Posted by Mike Trout View Post
    Well my buddy lost the keys to my 70 GT Thanks
    Mike,
    OpelSpyder may still have some blanks and has a key cutter.
    Last edited by hrcollinsjr; 02-13-2008 at 05:52 PM. Reason: I deleted part of the message because I was repeating Namba.
    May 2005
    274
    Well, I am going to pick up the car from southern PA, and i ahve to trailer them back here i do have the setr of keys for my 69 but the 70 had the ignition on the same keychain that got lost. I do not know when I am getting the cars but I know I have to remove them promptly when im there (court case) I can only be on the property for a few minutes. the steering column lock doesnt work so there no problem with getting it on the trailer i just wasnt sure what to do.
    Mike,
    Chesapeake, Virginia
    1,403
    GT keys
    Quote Originally Posted by namba209 View Post
    A key cut by impression from the door handle will not turn the ignition lock because the ignition locks has more pins than the door lock. When you get it where you are going with it, take the door panel off and take the door handle off the door, there should be a key code on the inside lock part of the handle, a locksmith can cut a key from that provided he has a proper blank.
    Tennessee
    1,354
    Key codes
    If you do as suggested, pull the door handle off and get the code, chances are that the ignition is the same. I can cut a key by the factory code just like the dealer did. I find this is a truer cut key than even a locksmith can provide. Hopefully it still holds the original parts. My email is keithlundholm(at)yahoo.com or PM me. I can save you a little money from the locksmith as well
    May 2005
    274
    The only thing that I do know is that I had to keys and they were different, same with my 69 only one key works the door one works the ignititon and one of them was the tank but I know there was 2 keys for the 70 that looked different but when I get the car I will let you know
    6,162
    Quote Originally Posted by Sparky73 View Post
    The "Can of Keys" is currently located in Arizona
    Quote Originally Posted by BQS4 View Post
    Was'nt that the first place it went a few months ago? .......Maybe I'm mistaken..but, this is like the second or third time someone asked about it!!
    Member Mike Preble is on a distinguished road Mike Preble's Avatar
    Tucson, AZ
    376
    I can send the can of keys to you if you want it. Just PM me with your address and it will go out today.
    Mike
    1000 Post Club jlthunder is on a distinguished road jlthunder's Avatar
    Salfordville, PA
    2,205
    Just a thought. Can the can of keys come back to Carlisle in May? I'm sure there will be pleanty of people interested.
    1973 GT, Parted out, R.I.P.
    6,162
    The "Can of Keys" is also meant to collect any unwanted keys anyone might have. Strictly Opel keys, not just any keys. LOL
    I would like to try some of the gas cap keys that may be in the can, I already ruined one gas cap taking it apart trying to make a key using the instructions in this forum. I used too much heat to melt the little sealing disc that holds the two shells together. I won't even take the key just use it to cut another one, bought some blanks off of ebay awhile back have about 3 more shots at it. LOL
    If everything seems to be going well you have obviously overlooked something.
    ustaGT roadings is on a distinguished road roadings's Avatar
    Jul 2006
    USS Kearsarge(lhd3)
    30
    I could do a search around the house and find my long since departed '73 GT's keys to add to the can.
    Dinger
    "Some ships are designed to sink… others require our assistance."
    May 2005
    274
    Well i had a chat with the postmaster today he is searching for me, I called my toyota dealership if I show proof of ownership (i have the title) they can make me a key at the dealership for my truck. so thats one key down now i need my two opel keys and 2 GMC keys there somewhere in NY. But I would love to see the can of keys at carlisle because I am buying a parts car that has no keys but claims to have a descent engine.
    Mike,
    Pleasanton, CA
    787
    Maybe my local locksmith liked the gas cap challenge. He spent a lot of time sticking the blank in the cap, rotating it, pulling it out, looking for marks, filing, and repeating the steps. After breaking one blank in the cap and 30 minutes into his second try, he told me that he would call me when it was done. He called me the next day and told me to pick it up with the new keys he had made. He only charge me $22.
    Jerry
    UFO pel investigator Aardvaark is on a distinguished road Aardvaark's Avatar
    Aug 2007
    Des Moines, Iowa
    2,415
    Aardvaark has made a donation to the forum!
    This offer to sell Opel key blanks is still good. I have 4 left to sell. Scroll to last post. First come first served. PayPal ok.
    http://www.opelgt.com/forums/canadia...89-hi-all.html
    -Mark
    '75 Manta
    Quote Originally Posted by ungermm View Post
    Jerry
    Thats a pretty good deal, I thought it would be easy that way,(poke and hope) I used blue machinist dye and lighted magnifying stand, by the time I had the first one whittled down it was a goner. I took the lock apart, it is unique keying because not only is it keyed it keyed at different steps. I was close, but it wasn't horseshoes.
Tags for this Thread
