Results 1 to 20 of 25
Thread: New Wheels & Tires for my GT... HELP
    Opel GT Pilot bgdowski is on a distinguished road bgdowski's Avatar
    Jul 2007
    Dearborn Heights, MI
    100
    Alright everyone. I am pretty new to the aftermarket wheel/tire combos for GTs. A close friend of mine is getting a new set of rims for his honda civic ( i know i know, honda ) His bolt pattern is 4x100 so it matches my gt. the rims are 17 inches tall and 8 inches wide. They have very low profile Hankook racing tires on them, good tread left. My question is will they fit my GT with the appropriate spacers? And if so, how goofy will they look on my stock ride height. Any Input would be greatly appreciated...
    I kinda figured these rims would give my GT a "mean" stance. He will give them to me for a price nobody in their right mind can deny and weigh 26lbs a piece including rubber, so unsprung weight shouldn't be changed much (should it?)
    I know ride quality will suffer and without a slight lowering, it may look a little out of place. Will anything else suffer/be gained from these rims?
    I plan on respraying them Gloss Black so ignore the "flat black" look.
    Thanks for baring with me through my ignorance...
    Currently in Daytona Beach, FL working towards my Bachelor's in Aeronautical Sciences (Professional Pilot).
    Here's what I've learned by searching and asking in the past.
    The offset will be WAY OFF of course. You'd need pretty massive spacers to push the rim out far enough to not rub everywhere, especially on front. Steering geometry is important. Running spacers to get it close is often frowned on given you have got two sets of lugs to keep tight and the ones on the spacers are hard because there's no wheel on to help torque against.
    I've got 15" rims on mine with 1" or so worth of spacers and I've not had a problem but even now they rub the inner fender at full lock. Some say running the spacers and putting the center of weight outboard like that is hard on the wheel bearings. Wide rims with low profile tires don't feel as good on the road either I'm told. Not as much side wall to absorb the road.
    I personally don't like the look so much either and am trying to move back to more period correct rims, 13" and appropriate offset and tire size for many of the above reasons.
    There's lots of threads on the issue.
    PS here's a diagram I made to help me understand it, those rims (front wheel drive) probably have massive positive offset you'd have to correct for (you may not even be able to get spacers/adapters to handle it, even if you could, the question remains, SHOULD you, don't know.
    Jul 2007
    100
    Offset
    He isnt sure on the offset, but he said they are somewhere around 44 i believe. For the price i am getting them for, i can sell them for twice as much if i end up not liking them, so it wouldnt be a financial loss at all. Its just making the initial investment because, well, my GT is in MI and i am at college in FL where the rims are... The GT isnt coming to college with me until i spray it this summer, so i want to bring the rims home with me for the summer and spray them...
    More info/help PLEASE!
    This list of threads (especially the "sticky" at the top) will keep you reading for a while.
    Moderator Ooooner is on a distinguished road Ooooner's Avatar
    Concord, North Carolina
    1,133
    Go here to see what 17" wheels with 40 low profile tires look like...
    Row of Opels 07 (2) - Opel Photo Gallery
    Roy Bell
    1973 Opel GT
    74 Manta Rallye
    Carolina Opel Club
    OMC
    Jul 2007
    100
    Yeahhhh
    Ive been reading up on some of these treads ever since the buying opportunity presented itself. Im just not finding much info on 17" rims with low profile tires other than they are a rough ride... Thank you for the link and i am continuing to read. From what ive gathered, the largest spacer i will probably need is 1.5", maybe?
    If you have the rims there, you can actually measure where the hub surface is in relationship to where the center line of the rim is, compare this to what the stock Opel should be and you'll know what spacer (actually an adapter at this point is probably the right term, although you don't want to change the lug spacing as is what adapters are usually used for, you just want the spacing, spacers are really just shims and you'd need to stack several to get close that 1.5" and your lugs would never reach anymore anyway.) Adapters have recessed holes for the stock lugs then they have their own lugs sticking out for the wheel.
    Here's another homemade picture and then I'd better shut up because I don't really know enough to be dispensing advice.
    Jul 2007
    100
    Ooooner, thanks for the picture post! do you have any other pictures of GTs with 17's? Do you have any info on the gt you posted (spacers, tire width, ect.) Also is that GT running stock ride height?
    Last edited by bgdowski; 03-31-2008 at 04:28 PM. Reason: Wanted to add another Question...
    1,133
    Quote Originally Posted by bgdowski View Post
    The picture is my car. The 17" wheels with 40 low profile tires are stock height. I wanted to make sure the outside diameter was the same as the stock 13" wheels so it would not mess up the speedometer or the height of the car. As for using spacers, I have .200 spacers on the rear just to get the wheels out far enough so they would not rub the inner fender. They were not rubbing before I put the spacers on but I thought it would look and perform better with the wheels out a little more. I made the spacers myself in my school machine shop and went with .200 thick spacers so I would not have to replace the studs on the wheels. Any thicker than .200 and I would have had only about three turns of the lug nut on the studs. Not good. With the .200 spacers, I have around five to six turns. Hope this helps...
    Roy Bell
    1973 Opel GT
    74 Manta Rallye
    Carolina Opel Club
    OMC
    Jul 2007
    100
    It definately helps alot. I like the look. Are the rims you have FWD or RWD rims? Offeset on them?
    1,133
    To be honest, I am not sure of the offset. I would have to check on that. But as far as FWD or RWD wheels, I didn't know there was a difference. Maybe I am out of touch with that... Hummmm...
    Roy Bell
    1973 Opel GT
    74 Manta Rallye
    Carolina Opel Club
    OMC
    Jul 2007
    100
    From my understanding FWD rims have more of a + offset than the RWD rims, but maybe im just stupid. I dono!
    Any more pictures of GTs with 17's would be awesome guys!
    Opeler dcm013 dcm013's Avatar
    Troy, MI
    315
    Roy may have big rims and low profile tires on his GT but I bet his roads are LOTS smoother than we have here in MI. I don't know if you've been back lately but the roads around Detroit are simply terrible. My son hit a pothole with his Acura a couple weeks ago that took out not only the tire but the rim as well, so there's more to consider than just ride comfort. Given the economic situation here in MI I suspect the roads will not improve much for a long time. I'd avoid any rim requiring really low profile tires, assuming you plan on driving the car around here.
    Don
    Jul 2007
    100
    Dcm013, thanks for the concern regarding MI's roads. They are truely horrible, arent they? I took that into account and thankfully the roads down in Daytona Beach are significantly better than back at home! Last time i was home, a few weeks ago, my truck nearly fell into a pothole...
    1,133
    The roads here in North Carolina aren't much better. The drawback to the low profile tires is that it is a much harsher ride. You feel every bump on the road. It doesn't help the ride to have polly bushings either but it is a "sports car" and you are supposed to feel the road. So I don't mind at all. I enjoy it.
    Roy Bell
    1973 Opel GT
    74 Manta Rallye
    Carolina Opel Club
    OMC
    Jul 2007
    100
    I enjoy feeling the road also, and dont mind having my teeth rattled a bit. Im young, i can handle it.
    I ran 16's on my Kadett in upstate NY for almost a year with 40-series tires, and ruined all 4 ball joints, both outer tie rods, and trashed all the rubber bushings in the front suspension.
    Rim diameter really doesn't have much to do with fitting the wheels on the car. A cylinder is a cylinder, and as long as you keep the outside diameter of the tire the same all that's different for 13s or 17s is the wheel width. A 13x7, 16x7, or 20x7 rim are all going to need the same offset. As a general rule, with a 7" wide rim, you need roughly 20-25mm of positive offset, but you can usually get by with as little as 0 on the rear and 10-15 or so on the front of a GT IIRC. Since you are starting with 44mm or so, 44mm-20mm=24mm, which is pretty close to an inch worth of spacer. Widest possible would be 44mm-15mm=29mm or about 1.25" spacer.
    I had 16x7" rims with 38mm of offset on my GT and tried 1.5" spacers on the front (0 offset total) and had rubbing issues, but they were fine with 1" spacers (13mm offset total.) Either set of spacers worked on the back, but the rims would not clear without at least 1/2" of spacers (25mm maximum offset, 0mm minimum.)
    Nov 2004
    Newnan, GA - greater ATL area
    1,469
    No you are not stupid. You are completely right.
    Jul 2007
    100
    Thanks for the info guys, and Dieter, thanks for clarifying that for me
    Jul 2007
    100
    Before going and getting the rims i wouldnt mind seeing some more pictures? anyone? rear end shots?!
