Results 1 to 12 of 12
Thread: GT Engine Tilted?
    Opeler jak133 is on a distinguished road jak133's Avatar
    Mar 2008
    cedar rapids, iowa
    63
    GT Engine Tilted?
    just had engine and trany rebuilt is the engine supposed to tilt to the left?
    5,075
    in a gt yes
    its to help with hood height
    Aug 2004
    Planet Earth
    538
    Right?
    It tilts left, depending on where you are looking from.
    More clearly, it tilts so that the passenger side is lower then the driver's side.
    This is done with motor mount top brackets (which are side-specific), and the trans mount bracket.
    Mar 2008
    cedar rapids, iowa
    63
    Quote Originally Posted by Anonymous D View Post
    then its right or left either way its tilted correctly
    Tennessee
    1,358
    Motor mount brackets
    No, the tilt is built into the engine cradle itself on a GT. There should be two spacers from the factory between the inner frame and the engine cradle. The one tower of the cradle is taller than the other one, to create the tilt. Yes the top engine brackets are different, but not in height, but in length. The way to tell them apart is the drivers side has a small "dot" right next to the engine mount bolt hole. There is a thread with pictures on this as well-may be in a restoration thread.
    Yep - GTs Tilt (At windmills ??)
    The carb side of the motor is lowered to fit the air cleaner bend under the hood - Opel still had to put that nifty 'bump' there for clearance though ...
    It is about 14 degrees away from 'plumb' (or maybe 7 degrees?)
    Nov 2004
    Newnan, GA - greater ATL area
    1,469
    Quote Originally Posted by GTJIM View Post
    It is wayyy less than 14 degrees. I don't know the exact value, I estimate around 3-4 degrees, definitely not more than 5 degrees.
    1,796
    When looking at the engine its right or left
    BUT when your working on the body its from the drivers seat completely the other way around. Got to love them the #$#&^%$#^%n wipes.
    Maybe just to make it easier on everyone, use the standard used in the aircraft/military industry. Everything is based on sitting in the pilot's seat when referring to left/right/port/starboard.
    Member West Coast GT West Coast GT's Avatar
    Aug 2003
    San Francisco Bay Area
    932
    Does the engine tilt the opposite direction down under, seeing as how it's in the southern hemisphere?
    Well .....
    Quote Originally Posted by West Coast GT View Post
    For a start the driver's side is the wrong side instead of the right (hand) side!
    Opeler caramiciu is on a distinguished road
    Nov 2005
    Dracut,MA
    192
    engine tilt
    Quote Originally Posted by opelspyder View Post
    Would you happen to know where the pictures are..I cannot find them
    I am ready to put the engine in and got to make sure I do it right (especially the spacers??)
    thanks
