I prefer sandblasting to remove rust where needed. A sandblaster that is too strong will warp flat body panels and can create damage but is great for frame blasting.I use a smaller preasure pot sandblaster(a cheaper siphon feed will also do) with powdered glass as it gets all the rust out and doesn't warp the sheet metal.Soda blasting tends to not remove all the rust from the pores and granite is heavy, dusty and can cause warping.Then it should be coated immediately with epoxy primer as surface rust begins very quickly and is not always visible by eye. Filler work can be done on top of the epoxy which further prevents rust.Epoxy is the best for rust prevention and adhesion both underneath and on top but can be expensive.It also is a good sealer on top of fillers. Self etching primer may also be used instead of epoxy on bare metal but is not a good base for fillers and epoxy is better for adhesion.
Good paint does not have to be removed and can be sanded ,chemically washed and painted or sealed with epoxy to prevent any reaction with the top coat.Paint can be removed by sanding or chemically stripping if required.
A colour change is not a problem but involves more work depending on the quality you are looking for. Generally a quality colour change requires shelling the car so all edges showing the old paint won't show or a lot of expert masking. Colour change can look cheap if not done correctly and can therefore depreciate value.
I hope this helpsJohn
John
John
