Actually, he said:
Did you do the sand blasting, or was it professionally done? My neighbor is putting together some very large, very heavy, metal working tools - scale has been a problem.I'll be facing both sides to get the correct height.
No, that's not a defect, that's a feature.
Ok so having the "half circle" for the bolts isn't important. I copied a 2.4l manifold so it should be larger than a 1.9 already. I still plan to compare my digital model against the one you sent to me. Hopefully it will be here today.
I have three manifolds I can test it with, stock 1.9l, 2.4l, and a cut down 3.0l.
What series copper alloy are you talking about? Either way you make good safety points. In the past did you use a stock gasket for your tubular headers? Personally I plan to use a regular gasket since I doubt the gap between the two ports will cause much issue.
As Rallybob said I plan on milling it off. It's nasty stuff so that is all that particular carbide tool will get used for. Sand blasting isn't a bad way to go for the vast majority of people but I already have to face the material down to the correct thickness so this takes two steps down to one. If you do go about removing the scale via milling I'd recommend a fly cutter with a brazed carbide tool since they are cheap and can be reground with common equipment. Modern high performance end mills require cnc grinders to properly regrind. Indexable tooling is the other way to go but that is more expensive.
I have these "Gorilla Mill" variable helix end mills I am looking forward to trying out.
1972 Opel GT: 2.4, big brakes, efi - inprogress
Much thanks!
Very heavy = three interlocking pieces, each weighing ~100(ish?) pounds. That's just the buiness end though, stand and handle/monkeybar extra.
Not sure what copper alloy specifically, to be perfectly honest. But once annealed it was 'dead soft' for sure.
I have used custom header gaskets (1.9 and 2.2 type) on all performance applications. I used to have them made when I owned C & R. They have the divider between cyl #2 and #3. Not doing so skewed the ability to jet each cylinder correctly. Not sure it's much of an issue on a street engine, but for racing it's rather important. Plus not having the metal port 'surround' means I can port the gaskets (they were graphite with metal core) to match the head's port shape. Again, very critical for racing, as stock gaskets hang into the intake port tract!
Copper is a soft abrasive metal by definition but the difference between a 400 series alloy (common) and a 1700 (harder alloy) series is pretty big. The nice thing about copper is the coefficient of thermal expansion is almost exactly the same as common stainless steel (304B).
Most so far seem to be for street vehicles so I am honestly not worried about the gaskets. If the few racers who said they wanted the flange and/or turbo header need a gasket made they can contact me. Otherwise I still plan to run with a regular gasket.
I am considering running boost on the 2.4 I aquired… what kind of realistic gains from a stock engine would I see at 9 - 14lbs? If a 1.9L can hit 160ish with 8 - 9lbs of boost O_o I'm a bit worried that even during normal nonabusive driving I'd see reliability issues out of stock torque tube and rear end with a turbo or supercharged 2.4L.
Once upon a time... OGTS was selling the Intake/Exhaust manifold gasket with a center divider in the #2/#3 hole. I believe they are in the process of having a new batch made...
Please don't even consider ANY boost on a stock 2.4 shortblock. The stock pistons fail (ring lands) under high rpm naturally aspirated use. They won't tolerate forced induction for long, even at modest levels. You'll need custom forged pistons. Rods and crank are strong enough however.
HP depends on breathing, rpms, and turbo size. If you choose the same size turbo I did, expect about 15-20 more HP than me, but a heap load more torque at the same boost levels. At 150 hp with a turbo 2.4 I'd expect 200+ ft lbs of torque. More than enough to shred stock Opel parts!
O-o Well it looks like I need to get searching on a solution for that problem!
The flange didn't arrive today so hopefully it will be here Monday.
Update:
The flange didn't arrive yesterday. Maybe today!
Rallybob - I measured the distance between the #2 and 3 cylinder exhaust ports on my 2.4L. It is a few 10ths over .2". Do you know how thick they made that on your design?
I'm in the process of removing the manifolds from my 1.9 so we can get ready to do a mockup of the piping. I'll have the mild steel for the flanges this week so they could begin shipping as early as late next week. The turbo manifolds are still a ways off.
I'm going to be gone three out of the 4 weekends in July for various military trainings so I am not sure how this will affect the timeline to completion yet.
So much for 'priority' mail! Thanks USPS....
Very thin. I allowed for insertion of the tubes into the flanges, so they would be able to be welded internally. Wth bigger tubes you can weld to the face of course.Rallybob - I measured the distance between the #2 and 3 cylinder exhaust ports on my 2.4L. It is a few 10ths over .2". Do you know how thick they made that on your design?
http://farm4.static.flickr.com/3077/...a21724e4_o.jpg
This shows it pretty clearly!
That looks to be less than .1" - I'll wait to get your sample before I mess with the model in that area.
What are your recommendations on the tubes inner diameter at the individual exhaust ports and when they come together for the turbo?
I've used 1.25" weldable cast steel 'Schedule 40' pipe fittings for most manifolds. Enough for 400+ hp, anything bigger and you'll just get more lag. I'm going to use 1.5" pipe fittings for my Dad's GT, but that's a 600+ hp turbo and a 2.6 litre engine with a lot of headwork and a hot cam, so it can support it.
On my wagon turbo header I used 'Schedule 10' fittings made from 304L stainless. Dimensions below.
I'm jumping in kind of late here, but if the CAD file I did is the one you are referring to then you can trust it. It was done using Bob's old template and a vernier on my 2.2 head to tweak it just a bit. I was originally going to have them waterjet cut by one of my vendors but there was not enough interest.
Another member here mentioned that there were some fit issues with the flange when they made from your template. I can't get Inventor to open the darn thing so I am not really worried about using the other CAD file since I've already created one based off of the 2.4 exhaust manifold I have. If you could send me an IGES file of the model so that I can compare the three designs that would be great.
