Results 1 to 20 of 20
Thread: 1.9 Kadett and GT Motor Mounts
    Alberta Opeler Ray Morley is on a distinguished road Ray Morley's Avatar
    Sep 2006
    Devon Alberta
    171
    I plan to install my two mounts on my 70 Kadett Rallye this week as both mounts are pretty well squashed.
    When I compare the two new mounts one is larger than the other.
    Which one goes on the drivers side?
    Moderator Mach1Tom is on a distinguished road Mach1Tom's Avatar
    Jul 2002
    Pittsburgh PA
    410
    Ray, If I'm reading my factory Parts Book correctly, both mounts should be the same.
    68-70.... Kadett (1.5-1.9 eng) # 684273 MOUNT (damper)eng. frt mtg
    71-72.... 31-36-39 "........." # 684273 " ............................... "
    ~ Tom
    Tennessee
    1,358
    Engine mounts
    Kinda funny, I replaced my mounts on the 70 Rallye tonight. I found the transmission mount plays an inportant part on the Kadett, so make sure it is good as well. I then simply chained the front of the engine and hoisted it up to replace the mounts. A lot easier of a job than the GT for sure. Bolt access is a little easier. The mounts are the same, and the GT carries the same number as well
    Member West Coast GT West Coast GT's Avatar
    Aug 2003
    San Francisco Bay Area
    930
    Quote Originally Posted by opelspyder View Post
    ... A lot easier of a job than the GT for sure. Bolt access is a little easier...
    Why is a GT harder? I need to replace my GT's engine and transmission mounts and haven't figured out yet how to approach it.
    I was thinking of maybe using a floor jack under the engine, then dropping the cross member. Would this be the best way?
    Sep 2006
    Devon Alberta
    171
    Here are two pics of the mounts I was sent. One is larger and has a longer stud on the top.
    When I got them in the mail last fall I noticed they were different in size but I thought thats the way they should be..........a larger one for one side and a smaller one on the other side.
    Otto.........help.............
    6,165
    To be honest, it looks like you get the same part from different manufacturers. The difference is slight, but, I don't think it's going to matter much.
    Tennessee
    1,358
    Engine mounts
    The GT's mounts are a little harder to get to is all, and the car sits a little lower in the front. The mounts are on the crossmember on the Kadett, and they are slightly forward where you can with ease remove the lower bolt. In a GT they are a little harder to get to is all IMHO.
    Obvious!
    Quote Originally Posted by Ray Morley View Post
    Here are two pics of the mounts I was sent. One is larger and has a longer stud on the top. ..
    The one on the right in the first picture has an OPEL logo moulded on to it - the left hand one has not - so it is probably a 'cheapie' knock-off copy.
    Guess which one is correct!
    I suppose you could always put a spacer under the short one ... until you find another genuine OPEL one ......
    Opeler wattiefan is on a distinguished road wattiefan's Avatar
    Sep 2006
    Waconia, MN
    113
    Just did the same thing on my 72 gt
    While the engine was propped up, we took the crossmember down and cleaned the years of leaking old sludge off of it and the motor mounts basically fell out. Quick replacements came from ogts. We went ahead and did that while we were replacing the seal on the oil pan. It is much easier(although still a pain) to get to.
    Sep 2006
    Devon Alberta
    171
    old and new motor mounts
    Thanks for the advice on my motor mount questions last week.
    I had no problems at all changing them and to my surprise I discovered that when I took the old mounts out the larger one was on the drivers side and the smaller one was on the passenger side.
    My main concern with my original posting was that my two new mounts were different sizes.
    The old mounts were in terrible shape and much smaller in size compared to the newer ones due to age and wear. After installation the engine ran much smoother with virtually no vibration at all.
    860
    the GT engine sits at a slight angle so it would stand to reason a smaller mount would have been on the right side where it sits lower. I believe Gil at OGTS had told me once that even the metal motor mount bracket which attaches to the engine was a little different left and right sides.
    2,674
    Quote Originally Posted by Gordy View Post
    ... the metal motor mount bracket which attaches to the engine was a little different left and right sides.
    The metal brackets ARE different but I don't recall there being any difference in the actual mounts themselves. Unless it is accidental because of variations between manufacturers.
    Tennessee
    1,358
    The Kadett mounts and the GT mounts
    The mounts are different, but do not affect tilt angle. The Kadett does not tilt, but the engine mount ear on the driver's side is a lot longer, but no tilt is incorporated on that car as far as I can tell. The engine oil pan sits level and close to the front suspension cross member on those. The GT's tilt due to the engine cradle, for air cleaner clearance. All the mounts are the same, we are seeing differences due to manufacturing and extreme wear. The GT's engine mount ears are different, even in parts books. What is different, I don't know" I think hole location, but the driver's side is indicated by a small dot or indention by the mount's hole on that side.
    Pleasanton, CA
    787
    I thought the mounts on a GT tend to get squashed more on the passenger side due to them being close to the heat of the exhaust manifold.
    4,161
    Quote Originally Posted by ungermm View Post
    That's exactly my experience with my GT, and from Ray's photo, common to Kadetts as well
    Angles ...
    ... The GT's engine mount ears are different, even in parts books. What is different, I don't know" I think hole location, but the driver's side is indicated by a small dot or indention by the mount's hole on that side.
    The diference is that one side angles up - the other down to compensate for the 7 degree angle the motor sit on with the GT. Also one has the engine mount hole further away from the motor than the other - the actual metal brackets are not interchangable from side to side.
    Tennessee
    1,358
    Degree tilt
    No if you set the engine cradle down and look at it in the frontward view, one post of the engine mount is taller than the other. I don't think the tilt is quite 7 degrees as this has been discussed. Then mount ears off the engine do not have a 7 degree tilt on one side to the other that I can see with them side to side. I think I am going to pull out all the pieces and settle it once and for all about this tilt factor. I will measure everything, and check angles on the mounts with an angle finder. And then post my information
    Tennessee
    1,358
    A few resources to be noted
    Okay, here is the engine mount for a GT. Both rubber mounts are the same. The Driver's side measures taller at 7 to 7-1/2 inches tall from the flat of the frame rail mount to the lower edge of the rubber mount. This is from where it would mount in the car. The passenger side is about 6 inches tall. That is a 1-1/2 difference. The cradle is looking from the back of the car to the front. The engine mounts have no apparent tilt than from the other ( Although I have not put an angle finder against the two. The both measure 4 inches long. The driver's side hole is right at 3 inches from the mounting point of the block, the passenger side measures 4 inches, but it's mounting hole is about 3-3/8 inch from the engine mounting flange. The drivers mount ear has a small dimple directly from the outside of the mount hole to indicate what side it is. I think this only affects centering of the engine to the chassis, like the Kadett. I do not believe it affects tilt at all. Please do not through in the fact of the shims that are located between the engine cradle mounts and the body frame rail. They are both the same thickness, and do not affect tilt. The intake is not a good point to measure tilt from, as it has been verified that Opel made different height intakes on 1.9s. I'm not sure the exact tilt yet of the engine, but if there is anything to add to this that I have overlooked, please inform us, as this is about the 10th time this has been discussed within the last year it seems. Lets lay it all out.
    Sep 2006
    Devon Alberta
    171
    One thing about this forum is...............
    A simple question can sure lead into a long informative thread. As long as we can all benefit from the information provided it makes this forum worth it weight in gold!
    Tennessee
    1,358
    Answers
    Yeah Ray, did you get all the info you needed? Kind of funny how these lead. I found that a lot of questions pertaining Kadetts, led to a GT discussion, because everyone assumes the car is identical underneath. They are not!!!
