Results 1 to 9 of 9
Thread: Dash panel clips
    Member BDD is on a distinguished road
    Wisconsin
    605
    Dash panel clips
    For the clips that the instrument panel screws fasten into, is there a source for these or do you have to make new ones for any that are missing?
    These are strips of metal folded over onto themselves, slipped over the steel tabs on the body (or dashpad?) with holes that the dash panel screws thread into.
    2,676
    Quote Originally Posted by BDD View Post
    There may be a more specific name for them but a search for "spring nut" or "speed nut" will yield the type of of fastener you're talking about.
    You're just not having any luck with that dash are you? Check your PM!
    Acworth, GA
    1,155
    The clips are available just about anywhere. We use them all of the time when you are restoring a vehicle.
    There is a section at your Napa, Autozone, etc. called "HELP" which has all sorts of stuff hanging in red style packaging. There is always a little box with 10 of them on the shelf for about $5.00 in different sizes. Just match to the ones you need and you're good.
    2,001
    If you can't find the exact ones you need at your local parts house go to mcmaster.com and use their search feature to find the correct page and then you will be able to buy exactly what you are looking for. The only thing is you will be forced to buy in quantity, like 25,50, or 100 but the price will not be bad for an item like this. I believe you need the ones designed for a #8 screw. BTW if you want new black screws for the dash you can get them from mcmaster also, just order item # 91775A730
    Wisconsin
    605
    I am missing at least 2 clips that are small and painted black. One would go at the top of the instrument panel and one would go at it's lower left corner. These are smaller than the ones I usually see. They are narrower and one side that's folded over is not as long as the part at the back side that the screw threads into.
    My dash pad has the mounting brackets that have a piece welded on the back of each bracket which will only allow one of these smaller, narrower clips to slide into. This may have helped in the alignment of these clips.
    Are these smaller clips available at Auto Parts places or does somebody have some extra's? I guess these are called speed nuts at McMaster-Carr.
    I am also missing 2 bolts and the nuts that attach the front dash vents. In my case the threaded stud (bolt) and the square plate at it's base have fallen off of the dash pad. Does anybody have any of these with good unrusted thread and some ideas on how to reattach them to the foam?
    I'm replacing my vent hoses and working on the wiring but found that I need these clips, etc.
    Thanks.
    Acworth, GA
    1,155
    Thanks.
    Not to be a wise gluteous maximus here but read post #3
    Wisconsin
    605
    Thanks.
    Does anyone have these bolts with base and what adhesive can be used that won't melt this foam?
    Acworth, GA
    1,155
    You can use the same square/bolts from the rear tail trim. You can get them at either Home Depot or OPGTS. I purchased the ones for my car from Home Depot and epoxied them in place. Make sure the metal is bare prior to expoxy the base in place.
    Wisconsin
    605
    FYI. None of the clips at Autozone or Advance Auto here fit.
Tags for this Thread
