Results 1 to 20 of 28
Thread: Deltran Battery Tender
    '72 Opel GT (Sara) newman27 is on a distinguished road newman27's Avatar
    Jul 2006
    Atlanta, GA
    1,730
    When I leave my car idle for 3 - 4 days the battery has a tough time turning over the motor and gets pretty weak after just 5 - 6 attempts. So, I was thinking of getting a battery charger. I saw the Deltran brand advertised on My Classic Car on Speed channel. They seem to get good reviews. Anyone have personal experience with this brand?
    Matt
    Restoration Thread
    Comments Thread
    Opeler BobCGT is on a distinguished road
    Jun 2006
    Otisville Michigan
    178
    Battery Tender
    Ive been using the Deltran 'Tender Plus' for a couple winters now,and it keeps the battery in my Opel in good shape all through Michigan winters.
    Chesapeake, Virginia
    1,403
    Battery Tender
    Quote Originally Posted by newman27 View Post
    Matt
    The Battery Tender will maintain your battery at full charge, but, if it goes down in three or four days you have a problem with your battery or connections, or cables. It should stay up longer than that if everything is proper. Of course if the car is parked outside in cold weather the battery does not like that and will give you a problem.
    Trouble Maker Phoenix is on a distinguished road Phoenix's Avatar
    Mar 2006
    Snellville, Ga
    1,960
    What AMP rating do you have on your GT? Was it new/reman when Keith restored your car or was it reused from before th resto?
    Needs a 2dr Ascona, everyone else has one.
    UFO pel investigator Aardvaark is on a distinguished road Aardvaark's Avatar
    Aug 2007
    Des Moines, Iowa
    2,423
    Aardvaark has made a donation to the forum!
    The battery tenders work great if you don't do what I just did.
    Went to start the Manta this morning after it had sat for about a week
    on the tender and it was about flat. Looking around to see if something
    was amiss, I discovered I had accidently bumped the 6V/12V switch on the
    tender to 6V. Doh!
    Looks like the battery will be okay at least.
    Btw. Both my tenders are Sear Craftsman.
    -Mark
    '75 Manta
    Winter Lockdown ...
    If you are laying up your GT for the winter it pays to remove the battery and take it into the laundry or warm part of the car shed as batteries hate the cold. Hook it up to a battery tender and check the fluid level from time to time and your battery should be as good as it was when you started the Winter storage.
    BTW: A battery 'makes' electricity with a chemical reaction - the colder it is the slower that reaction takes place - thus lowering the output of even a 'good' battery at low temperatures.
    1,795
    Matt
    Sorry Matt that I had to quote you.
    Theres something wrong. I can let my GT sit for over a week. The only draw is a clock and a radio memory. And this is with a very small battery and it will spin over for over 3 minutes. One day I'll fix the leaking acc. pump.
    Off the top maybe a shorted battery
    or a small draw
    or bad diodes in the alt.
    Dan
    Jul 2006
    Atlanta, GA
    1,730
    Quote Originally Posted by Phoenix View Post
    I have the 45 amp alternator but can't recall if it was new or re-manufactured. On a day to day basis I don't have any issue though. The AMP gauge shows it is charging the battery and the car starts right up on the very first crank day in and day out. Only when the car sits for several days in colder weather do I have this issue.
    Today, for example, I went to start the car this morning after it sat for almost 5 days. The car turned over several times but, after the fifth attempt or so, the battery clearly didn't have enough power left and the car wasn't going to start no matter what. When I got home from work and the car had sat some more, it started right up on the first try. My theory is that the battery is losing some charge when it sits for several days in the colder temps and then doesn't have enough power to turn the car over the few extra times it needs after it has sat. The car starts many hours later presumably because the battery has gained back some charge and the car only needs one crank because it was "primed" in the morning.
    Anyway, my theory is that the battery tender would keep the battery at full charge and therefore have what it needs to start the car after being parked for a period of several days (i.e, the battery could handle the few extra cranks required). Then again, maybe I am just flooding the carb when it needs more than one crank to start up .
    Restoration Thread
    Comments Thread
    Jul 2006
    Atlanta, GA
    1,730
    Quote Originally Posted by wrench459 View Post
    or a small draw
    Dan
    Hmmm, well maybe so. I was posting when you posted this but note that this is a problem maybe a couple times a year. I assume if I had a bad alternator or any other major issue, it would be more consistent . I do have a rather complicated radio set-up with the XM Radio. I have an in-dash head unit, a separate XM tuner, an XM "adapter" module (takes the output of the XM tuner as an input and then sends the signals and data to the in-dash head unit), and an amp. Maybe a check of the connections is in order...
    Matt
    Restoration Thread
    Comments Thread
    Mar 2006
    Snellville, Ga
    1,960
    Sometimes Alarm systems and Stereos can make a draw like that.
    I have a similar problem on my monza. It takes a lot of cranking to get it started. That's because the fuel has evaporated from the carb. Your problem could be cured by using an electric fuel pump, that has a prime switch in the elctrical circuit. The monza has an electrical pump in the fuel tank, but only works under the "start" cycle, or when the oil pressure light is off with the key in the "run" position. So it takes a while for the fuel to get to the carb from the tank. To test my premise, pull the air cleaner off the carb, hold the choke open and manually open the throttle to see if there is fuel squirting in the venturi from the accelerator pump.
    Member SteveGT will become famous soon enough SteveGT's Avatar
    Oct 2008
    Blairsville, GA
    204
    Matt I have several vehicles for the biz that sometimes sit for days in the cold and always have used the Battery Tender Plus...simple out of the way 2-prong plug in and they crank right up...seems to keep the battery "topped off" when we go to crank them...North GA winters are tough on the batteries but the "Tenders" are a mainstay in my shop...the Goldwing is always on one
    SteveG
    '70 GT aka... Veronika
    1,795
    The "vat 40" can and will load test a battery/alt.
    The parasitic draw is another problem.
    For that we'll need the battery group of the one your using.
    Jul 2006
    Atlanta, GA
    1,730
    Thanks all for the feedback on the Deltran battery tender and the other things to look into - which I will. What I think I will do is buy the Deltran Plus unit (on eBay right now for $43) and then test this out over the Christmas break (which is the next time the GT will sit for a prolonged period - I can't go that long not driving the car for no reason ). I'll put the car on the battery tender and see what happens when I go to start her back up. That should be a good test.
    Matt
    Restoration Thread
    Comments Thread
    Jul 2006
    Atlanta, GA
    1,730
    I'm not sure what "vat 40" is... I have a Napa Power 65 (model 6026R) battery.
    Restoration Thread
    Comments Thread
    2,668
    I assume if I had a bad alternator or any other major issue, it would be more consistent . Matt
    Keith got the core from me and had it rebuilt locally. I think anything he installs like that he takes to a local shop and has them go through it. The battery should hold up for several weeks without any problems. Are all of your radio components switching off when you turn the key off.
    Jul 2006
    Atlanta, GA
    1,730
    Quote Originally Posted by hrcollinsjr View Post
    The in-dash unit draws a small amount of current to maintain settings and the clock. I have the clock display set to "auto shut off" after 30 seconds. The amp uses a "remote wake up" wire that is connected to a switched power source and I have verified that it only runs when the car is started and does shut off when the car is turned off (based on its power LED). As far as the other XM components, I can't recall now how those are connected - I will have to check. They are hidden in the passenger footwell under the carpet and so I haven't looked at them in over a year.
    Based on the replies here, it sounds like I do have a small draw that is affecting the battery and also am probably coming back to a car with a carb that doesn't have any fuel in it. The battery doesn't have enough power to get the engine turned over enough times to get fuel into the carb and start the car. The battery tender may be a band aid.
    Restoration Thread
    Comments Thread
    2,668
    Matt, Keith worked pretty hard on installing your "little" radio system. My money is on a battery going bad. A simple voltage test isn't good enough to determine if the battery is bad. I've had two that passed the voltage test but failed the amp test badly. There are any number of auto parts places that will test it for free, some will even test it in the car.
    Aug 2007
    Des Moines, Iowa
    2,423
    One other thing. Battery tenders usually allow the battries to last much longer. Paying for themselves.
    -Mark
    '75 Manta
    Depending on how old the battery is....I'm leaning in that direction as to the trouble. I also have a battery disconect switch of sorts in place to prevent any draw while the car is in storage. It was cheap....like 6.00 off e-bay....
    Probably not good for the radio memory but a good thing to have in an emergency.
    Joe
Tags for this Thread
