Have you checked your rod bearing clearance?
Also you may have a bent rod, or two or three or four, which can tighten things up drastically.
A short block assembly should turn over easily with a 12" long wrench on the front pulley bolt. Twice during each revolution it should be real easy, as two pistons are rolling over at TDC and two are rolling over at BDC.
So called rebuilt engines are the scariest, need checked over real good. You don't know what kind of knucklehead put the thing together. Huh, Joe?![]()
