3 possible causes:
- fuse blown (most probable)
- relay bad (comes right next)
- cable broke or came lose between stitch and where they split up (with some distance behind #1 and #2 causes).
What would cause both bulbs to lose high beams at the same time? Low beams work fine. Driving along with the brights on, all of a sudden nothing. Switched to low beams, no problem. Relay gone bad?
3 possible causes:
I'm reading that the "long range headlamps" are controlled by a fuse in the relay. Where would the relay be?
Roy, YOU don't get out that lucky! I thought you had your problem fixed or are you waiting for ME to fix it?
Don't recall ANY fuse in the headlight circuit! Check to see if the high beam terminal of the relay is putting out 12V when switched. If it is then your problem is futher down the line. Are you sure you didn't have one high beam out already and didn't notice it until the second one went out?
Presuming, according to your avatar, you've got a GT, The most probable cause is, the White wire came off your Hi-Lo dimmer relay at pin # 56A. If your Hi beam indicator in the light panel still works, then you've got a problem in the wiring down stream from the relay. HTH.
Note to Dieter, Roy, and Jeff, there's no fuse for the headlights on a GT!!!
Sorry, it is a GT. The blue light does work on the dash indicator.
When my GT did that a few years ago it turned out to be the relay. Why not swap in a relay from one of your other GTs and see if it fixes the problem?
I think OGTS sells a replacement relay, and check here for a post by DESTEC on how the relay works that also shows a Volvo relay that will work:
http://www.opelgt.com/forums/1c-ligh...mer-relay.html
Don
that is correct if the high beams are not working they have a bad relay or the splice from factory has corroded in the wire harness up by the Master Cylinder. Check relay first hard to believe it is switching but not connecting 12 VDC to lamps but stranger things have happened...good luck in your pursuit
If everything seems to be going well you have obviously overlooked something.
In this particular case Dieter, there is a fusible link at both the starter to the fuse panel and from the alternator to the fuse panel, but neither one will burn through and disconnect until after the headlight wiring goes south. It's the main reason we advise all new GT owners double check the wiring at the headlights. The headlight circuit is the only one on a GT that has no fuse and it is noted in the DESTEC schematic to install a fuse in the power circuit from the headlight relay to the headlight hi-lo beam relay.
Thanks for all the info, gentlemen. I appreciate it. Looks like I'll likely need to replace the relay. I'm slowly learning.![]()
If you're feeling mildly adventurous, you can R&R (Remove and Rebuild in this case) the relay. Simply remove it, taking note of which wires connect where. Then gently pry the edges up on the aluminum case, and the relay slides out of the case. Typically the only problem is a burned set of contacts inside, and there are two sets, one for the low beams and the other for the high beams. These can be readily cleaned up with either a point file (and if you don't know what that is, you are younger than me or didn't live through the 70's and learned that old burned points can be "restored" with a file, at least for another week!) or even a piece of fine emery cloth. However, if the "trip" solenoid (which flips the contacts between high and low) isn't working, or the mechanisms has failed, then a replacement relay is in order.
