Results 1 to 20 of 29
Thread: Wire Source
    Opel Intern Redskinsjbs is on a distinguished road Redskinsjbs's Avatar
    Aug 2008
    Washington DC
    600
    1
    Wire Source
    Hi all,
    I would like to rewire my GT during these winter months but I have ran into a slight speed bump. Where can I purchase the proper color coded wires? I know of places where I can buy 100ft spools of each at a minimum, but I only need a couple feet in most cases.
    I know of the EZ wire kit, but being somewhat of a wannabe electrical engineer, I'd like to do the wiring myself and not just plug in a new set.
    So any sources where I can buy maybe 25ft spools of all of the various color coded wires required for the GT?
    J Swift Sincerely
    Flickr photos
    Videos
    1,667
    I doubt it, the GT uses some pretty unique color coding. I would just use the EZwire or the kit from American Autowire.
    Well, you could do what I did with Willit? I removed the vinyl sleeving to visually inspect each wire. Any that were suspect were replaced with the correct size, but not necessarily the same color. What I did was use a pigtail of the original wire attached to each end of the new wire with butt connectors and shrink sleeve, then used convulated tubing to rewrap the harness. For all intents and purposes, the wire is color coded at each end and appears to be one solid wire. HTH.
    That, or you could find 4 other GT owners wanting to do the same thing and you could split the costs up and go ahead and order the 100' spools.
    Were it me, though, I'd want to order the wire like in the kits for all my cars. They have the light function printed down the length of the wire, so no matter where you run across the wire you know what it's for and if it should have power or not.
    6,173
    Has anyone tried looking into PG Elektronik They make proper wiring kits that are "plug-n-play" with correct wires and connectors. In other words, pull your old harness old, throw away and run the new in behind it.
    Just a thought as a complete and correct GT harness is about 350 euros...
    Quote Originally Posted by Redskinsjbs View Post
    Hi all,
    1,667
    Gee...that's only $465 plus shipping. Too much to replace an over designed electrical system. American Autowire is $320 for a complete modern kit.
    Aug 2008
    Washington DC
    600
    1
    I think that I can get an equal variety (not the same exact color scheme) of wires from advance auto in 25ft rolls totalling about 175$ ---> That gives 10 different spools of 25ft of wire at 14 Gauge. I priced it at 14 gauge because much of the 16 and 18 gauge wire is the same or slightly cheaper, so I figured I should try to overestimate. SO then If I add in the price of the spade connectors and the electrical tape, I could do the whole rewire for about $200.
    The reason I don't want to use the EZ wire Kit is that I want to move the fuse box out under the hood. I like this arrangement more and I think that it is a better placement. I also will be adding 3 more circuits to the box for a beefier stereo (nothing fancy, just non-stock) and splitting up the more vulnerable ciruits. For me, in a perfect world every circuit would be fused individually, but nothing is perfect.
    J Swift Sincerely
    Flickr photos
    Videos
    Portland, Oregon
    779
    Have you looked at Ebay?
    I did a quick check there and there were a couple sellers who were offering 20 rolls of 4 colors. In their as they said "Ask about other coor combinations".
    It might be worth a shot.
    Opel GTs are not GM products
    Tennessee
    1,358
    Wire
    I have only found color coded wire special ordered. I bought all wire stripped for the front headlight harness in 1000' rolls, as that was the minumum they would stripe. I will soon order other color codes soon. I haven't seen other wiring prestriped in too many places. Also everyone talks about EZ Wireing harness, I have used one, and painless-very similar, but I like a company called American autowire. They have the wiring separate, and the fuse box has labeled terminals that allow you to run that group of wires where ever and what length. It is the best I have seen for usability. Painless and EZWire are limited, sometimes you have to splice things. But in our GTs, There are different relays and equipment, that make it hard to use these harnesses, without some serious engineering degree to figure out.
    2,001
    I am going to have to dig up the phone number of a guy here in the states that builds GT wiring harnesses complete. I know I have it I just don't know where. I got my complete harness from OGTS which came from Germany because all the instructions were in German, which made the install interesting. I don't know if they still have them available. All of the color coding was perfect.
    Aug 2008
    Washington DC
    600
    1
    The maths behind wiring aren't all that difficult in the GTs. I just recently finished an FDM machine, the reprap from reprap.org, so I understand wiring stuff pretty well.
    I like the idea of making the ends of the wires the same as the old ones, but I know that adds some resistance and if I am beefing up the wires, then I can't really use the old ones.
    So here is a preliminary decision. I will get 6 colors and label the wires down their length with a label maker, say every foot or so.
    J Swift Sincerely
    Flickr photos
    Videos
    Not necessarily so. If you use butt connectors, soldered correctly, there is no added resistance. Don't forget to use shrink sleeve over them.
    Aug 2008
    Washington DC
    600
    1
    [QUOTE=namba209;180993]
    I am beefing up all of the wires that may need it in preparation for a larger alternator some time down the road. So I figured that I would get rid of all of the old insulation while I was at it.
    Concerning the complexity of this job, there really isn't any. The name of the game is to go equal or higher in gauge. I am working on a GT wiring Diagram that I'll print out maybe 4x4 ft and laminate; it should be great for debugging. I'll just have to alter the color codes on my diagram to fit.
    J Swift Sincerely
    Flickr photos
    Videos
    1000 Post Club Sparky73 Sparky73's Avatar
    Jan 2004
    Saginaw, MI
    1,269
    [QUOTE=Redskinsjbs;180996]
    Quote Originally Posted by namba209 View Post
    DESTEC Schematic
    Current
    1970 GT; Under Construction
    Previous
    1969 GT; Street/Strip Project
    1969 GT; White with Black Interior, Automatic
    1969 GT; Black Parts Car
    1969 GT; White Parts Car
    1970 GT; Silver with Red Interior
    1971 GT; Orange with Black Interior, Turbo
    1972 GT; Red Parts Car
    1972 GT; Blue with Black Interior
    1973 GT; Pearl Blue with Black interior. Full body kit.
    I'm running a 100+ amp alternator on Willit? with no adverse affects on the original wiring that I have left, which includes the battery, ammeter and alternator wires. I found it interesting that the engine wiring harness on the V-6 is smaller than the original wires on the GT. It appears the Opel folks did some overkill when the designed the wiring harness.
    Aug 2008
    Washington DC
    600
    1
    [QUOTE=Sparky73;181004]
    I understand, but it is just too small. I need to be able to stand back from the wall
    J Swift Sincerely
    Flickr photos
    Videos
    6,173
    [QUOTE=Redskinsjbs;181007]
    Quote Originally Posted by Sparky73 View Post
    The DESTEC wiring diagram could almost be read by Ray Charles Seriously though, you can't get much better than JJ's diagraham, unless you took a FSM one to a photo shop and had it enlarged....
    Aug 2008
    Washington DC
    600
    1
    [QUOTE=BQS4;181013]
    That is baisically what I am doing. I just want something to do in my engineering class.
    J Swift Sincerely
    Flickr photos
    Videos
    2,001
    Everyone always seems to forget about the pdf I created from the 1973 FSM which is the whole shebang so here is the link.
    Aug 2008
    Washington DC
    600
    1
    Has anyone ever used these guys? Automotive wire, Automotive electrical supplies, connectors, relays, switches.
    They offer a lot more colors, and rolls in increments of 20ft (Much better if I only need 5 feet or so)
    J Swift Sincerely
    Flickr photos
    Videos
