The install, especially if all the modifying is done, is no different than a 4-speed install, with a new clutch. The only hint/help I can offer, especially if you're doing this by yourself, like I did, is to unbolt your intake/exhaust manifolds, and undo the upper and lower radiator hoses and jack up the front of the motor (you want the back of the motor to tilt down, thus giving more room/access to installing the trans) The 5-spd has the bellhousing and case of the trans as one piece and a bit more difficult to install than a 4-spd.
I wasn't sure of the model series of the Rekord
