Gordy while I cant answer about your 67, but if its the same as 69 kadett, then there are two rubber "hinges" that push into the pillar into which pushes the chrome hinge bracket. That bracket holds the glass in place yet allows it to pivot and open a bit. I had to get new rubber bushings or hinges as I was not successful getting all of them out without ruining them. You will likely have to go overseas to get the rubber parts.
