Don, if you're referring to a GT, the flasher is at the bottom left of the vertical leg of the instrument panel next to the heater control panel. Not real easy to remove and install, but it can be done by feel. HTH.
Howdy folks,
Just installed led turn signals and need to pull the
flasher unit to do a mod to the relay to keep it
from thinking a bulb has burned out. I'll be danged
if I can find it. I can hear it blinking but sure can't
tell where it is. Before I pull the whole dash apart
I thought I might ask. "Where the heck is that
sucker?" There's all kinds of relays lined up along
the fuse box but none seem to be the one. (with
them all pulled it's still blinking.) All right, back to
it.
thanks,
Don.
Hi there Gene, yeah, my sonar-like hearing was kinda
telling me the same thing. An easier fix might be to
just mount some bulbs in line just so the flasher thinks
everything is OK.
thanks,
Don.
Oh, by the way, here's the front turn signals. I pretty much gave
up thinking I'd ever come across a set of correct lights. Went
ahead and painted the inserts a kind of amber color and installed
some bright burning amber leds. (the little chrome spot on the
insert.) Looks alright I guess.
