Results 1 to 20 of 33
Thread: Slow starting auto trans
    Detroit,where my home was 2 Fast 4 U is on a distinguished road 2 Fast 4 U's Avatar
    Maria - Hoop, The Netherlands
    2,293
    I have a problem with my auto trans, after starting the car, in the morning or after work, and putting it into D and wanting to drive away the car wil only move very slow, like it's moving with the engine on idle in D, even with the "pedal floored", and after about 50 meters it picks up in speed and works fine after this, until the car is restarted after many hours the whole thing repeats its self.
    This has been going on ever since I had to replace my broken 2.0 with a 1.6, does any body have a clue what is causing this
    Opel Ascona;
    driving one is like living on the edge.
    Only built from 1970 - 1975
    How long has it been since the filter in the trans was changed?
    2,293
    I don't know, Gene, but can this happen just by pulling the auto trans and putting it back in again?
    Opel Ascona;
    Portland, Oregon
    779
    Quote Originally Posted by 2 Fast 4 U View Post
    I'm not Gene but the answer is YES. It's possible that you dislodged some goop that normally isn't a problem. This can happen because during the engine removal, the transmission can experience some odd angles and movement.
    If I were you, I would start by removing the transmission pan and replacing the filter then refilling with new tranny fluid.
    Opel GTs are not GM products
    2,293
    Than I'll have to find a oil filter for the auto trans
    Opel Ascona;
    If you can't find one there in the Netherlands, give me a shout, I have two kits sitting on the shelf.
    2,293
    Quote Originally Posted by BQS4 View Post
    I'll do that, thanks Gene
    Opel Ascona;
    UFO pel investigator Aardvaark is on a distinguished road Aardvaark's Avatar
    Aug 2007
    Des Moines, Iowa
    2,423
    Aardvaark has made a donation to the forum!
    Have you checked the hot fluid level on the dipstick? On some automatic transmissions it doesn't have to be very low for what your describing to happen with cold fluid since the fluid expands quite a bit as it heats up.
    -Mark
    '75 Manta
    . . . try fluid level check first (GM THM A/T transmissions are real finicky about too low AND too high! fluid levels), then change filter/strainer and clean tranny pan . . .
    2,293
    About the fluid level, I check that very often because the trans has a leak in the front and in the back seal, so that isn't the fault.
    I could remove the pan and put in a filter from one of three other auto trans I have, just to get rid of the problem for now until I have a new filter.
    Is there a way to flush the trans to see if there is more gunk in it??
    Opel Ascona;
    Just because so many people seem to forget how to check auto trans levels: You do check the level in the transmission with the car running and in either neutral or park, right? Because if you were checking it with the car off the level would not be correct due to an uncertain amount of fluid draining back into the pan from the torque converter.
    Sounds like you need to just install one of your other transmissions if you are losing fluid out both ends. That or pull yours out and replace seals and such.
    2,293
    I check the level in the trans with the engine running at operating temp [± 90°C] and in the N position.
    Opel Ascona;
    Transmssion Troubleshooting
    "Slow gear engagement
    Description:
    If the transmission is placed into gear when the engine is warm, it takes a while to engage into a gear. Occasionally you can speed up the engagement by pressing on the gas pedal, but it may occur with a clunking noise.
    Possible reasons:
    The transmission fluid level is low or incorrect
    There is an internal problem in the transmission
    The idle speed of the engine is wrong
    The transmission filter is clogged
    The throttle linkage is out of adjustment or damaged"
    2,293
    It's not slow gear engagement, but slow coming to speed and it doesn't happen when the trans is warm, only when it's cold and for about 50 meters/yards of driving, then the trans works normal until it hasn't been used for a number of hours
    Opel Ascona;
    Aug 2007
    Des Moines, Iowa
    2,423
    If after you service the filter and still have the problem, I've had great luck
    with balky auto trans control systems by adding a bottle of Lucus TransFix after removing a similar amount of the atf. I most recently put it in a '63 Ford Cruisomatic to stop a front pump seal leak and it not only pretty much stopped the leak but the trans now shifts much better. If it's headed for a trans shop anyway, it might save you a trip. I really don't like additives for the most part except as a last resort to maybe avoid a large repair bill.
    -Mark
    '75 Manta
    Member guyopel is on a distinguished road guyopel's Avatar
    Feb 2003
    Duluth,Ga.
    661
    This is starting to sound like a Torque Converter Stator
    that is damaged ( Roller Clutch ) . This would require Trans. removal ....I would O.H. Trans. at this point because metal from Torque Conv. goes into the Trans. pump.
    John
    Guyopel
    I have not failed - I've merely found 10,000 ways that won't work."
    ---Thomas Edison
    It's amazing what God lets man get away with when lightning is so cheap. Mark Twain
    Acworth, GA
    1,154
    I see this problem all the time with vehicles brought in for restoration and it is very common with auto transmissions that start out with a front seal leak.
    The main cause is some of the front seals in the body are hardened and they take a bit of time to expand and come back to life. If you change the fluid and replace the filter, you might make the situation worst if this is the first fluid change after lots of miles. Simple way to see if it is a seal problem is to put the car in "L" when you start out from a cold condition. If the gear engages rapidly or after a few seconds without any additional RPMs, then a tranny reseal would be in order.
    I believe you should have either a TH180 or a TH200 which are simple to work on and not that expensive to reseal. As an example, a TH200 could cost you about $600 to reseal.
    Opeler trlmr is on a distinguished road
    Oct 2003
    Iowa
    115
    The pump for the trans is behind that front seal. The seal is old and hard and was probably deformed when you switched motors if you left the torque convertor hanging on the input shaft for any length of time. Now the pump is sucking air as it tries to prime itself after sitting for a bit. There is an air bleed valve that may be sticking also, but it is most likely the seal-pump combination. You can always try some of the seal softening additives and see if it helps.
    Aug 2007
    Des Moines, Iowa
    2,423
    Quote Originally Posted by trlmr View Post
    Do the seal softeners ever work? I've never had any luck with them.
    That's why I suggested the Lucas or other brand that coagulates the leak at the seal rather then softening the seal which would at best be pretty sort lived.
    -Mark
    '75 Manta
    2,293
    ......There is an air bleed valve that may be sticking also.......
    Where can I find the air bleed valve?
    @ blancojp: It's a TH 180 trans
    Opel Ascona;
