You have to unbolt the sprocket gear from the camshaft, which is held by three 8mm "serrated bit" bolts. These require a special tool. The chain can stay on the sprocket, and the head can be lifted off after the sprocket is unbolted from the camshaft.
(This is explained, in all the Opel service manuals. If you haven't done this before, you really shouldn't remove the head from an Opel, without referring to proper instructions).
