Results 1 to 7 of 7
Thread: Bad ground or is it normal?
    Opeler jak133 is on a distinguished road jak133's Avatar
    Mar 2008
    cedar rapids, iowa
    63
    Hey all, was putting taillights back on after paint and while checking them with key turned to on position (engine not running) pressed brake pedal and radio cut out but lights work. With engine running radio does not cut out, whats going on here?
    5,075
    sure sounds like a bad ground
    Mar 2008
    cedar rapids, iowa
    63
    Quote Originally Posted by baz View Post
    Thanks Baz, electrics are not my specialty. Where do I start ignition, brake system, or lights?
    2,001
    One other possibility. If you have a new radio it may have low voltage protection circuitry. Without the car running you may cause a low voltage condition when the brake lights come on, just a thought.
    Mar 2008
    cedar rapids, iowa
    63
    Quote Originally Posted by markandson View Post
    Never thought about that, it is new radio and everything seems to work fine.
    Portland, Oregon
    779
    Quote Originally Posted by jak133 View Post
    To test this theory you can hook up a battery charger (or jumper cables) to your battery and try again.
    Opel GTs are not GM products
    New/Old Owner 1973 GT JimVonBaden is on a distinguished road JimVonBaden's Avatar
    Dec 2009
    Vienna, VA
    419
    Old thread, but keep in mind that with new paint you need to make sure your grounds are making good contact. Turning on the ignition can provide an alternate ground, and make it look like the brake lights are working, but then with the parking lights on you have no brake lights again.
    Jim
