Did you change your condensor? The symptoms of a bad condensor are intermittent bad spark. As it heats up, it messes up. Let it cool down and it will run fine for a while till it gets warm again.
The car could be vapor locking. See if you can move the fuel line around to eliminate any high spots in the fuel line.
