Page 1 of 3
1 2 3 LastLast
Results 1 to 20 of 57
Thread: smoke and sparks from alternator
    Opeler jayhawkjesse33 is on a distinguished road jayhawkjesse33's Avatar
    Jul 2006
    Terre Haute, Indiana
    134
    This past weekend, I replaced my old 1.9 with a 2.2. I was having a vacuum issue, and after fixing it tonight, I went to take the car for a spin to see if it worked. As I started the car, there was a slight delay with the radio coming on. Then I had a rough idle, so I gave it some gas and it got better. I put it in to gear and started to back out. I heard a noise coming from the engine bay, so I put the car back in park and when I looked up I saw white smoke coming out from under the hood. I turned the car off and opened it up to find a a lot of white smoke and a burnt rubber smell. After looking around and feeling around, I noticed that one of my plastic wire covers felt warm. So I removed it with a few others just for good measure. I couldn't find any damage at this point...so I reached in and turned the key, no power until I hit the ignition and then turned the motor over again to see if I could see anything, and sure enough, the wire coming from the alternator was sparking. It was about 4 or 5 inches off of the bolt connection...where the previous owner had spliced in a 18 or maybe 20 gauge wire from the original thick wire to the connection point on the alternator. I could see bare wire and the wire was coming out of the insulation and tape they had used. So I wanted to see what I was dealing with. I cut that wire off and spliced in a 10 gauge wire and a new connection to the alternator. Turned the key, but no power in the car. I hit the ignition again and looked in the engine bay, it started but wouldn't stay started. So I did it again and saw sparks coming out of the alternator. So needless to say, my alternator seems to be fried. I am gonna take it down to the shop tomorrow to see if it can be rebult. Otherwise its an overnight order from OGTS so I can get the car running to see if I've fixed my vacuum issue with the transmission and to get the car to its appointment at the exhaust shop on Thursday.
    I wouldn't mind replaced that red wire, especially since its probably fried as well, but when looking at the fuse panel there seems to be a lot of red wires and I'm not sure which one to replace. Any help on that one??
    2,675
    Quote Originally Posted by jayhawkjesse33 View Post
    It was about 4 or 5 inches off of the bolt connection...where the previous owner had spliced in a 18 or maybe 20 gauge wire from the original thick wire to the connection point on the alternator. Any help on that one??
    You may be referring to the fusible link. It is a lighter gauge wire that serves as a fuse. It is there to protect the rest of the circuit from overload.
    Jul 2006
    134
    If there was a fuse there, then it was the worlds smallest fuse. Because I unwrapped the tape from around that wire and the connection and its just 2 separate wires spliced together...and like I said, the one was substantially smaller gauge than what heads toward the fuse panel in the car...which I have no clue where the wire ends up at in there. there's about 8 or 9 different red wires...its nuts in there!
    Rice Cooker neuropel is on a distinguished road neuropel's Avatar
    May 2002
    Spring Church, PA
    1,765
    neuropel has made a donation to the forum!
    Just to clarify, the fusible link is a wire that is designed to act like a fuse to protect the rest of the electrical system. Go to page 11 of the document below for a good explanation:
    http://www.autoshop101.com/forms/hweb1.pdf
    Todd
    "In the end, it's not the years in your life that count. It's the life in your years."
    -Abraham Lincoln
    ________________
    1972 GT 2.4L
    1974 Manta GT/E 2.2L
    1973 Manta Rallye 2.5L
    2,675
    Quote Originally Posted by hrcollinsjr View Post
    You may be referring to the fusible link. It is a lighter gauge wire that serves as a fuse. It is there to protect the rest of the circuit from overload. Harold
    There isn't supposed to be a fuse there. If you have a wiring diagram check it out. If you'll do a search for fusible link you may get additional info.
    Jul 2006
    134
    Well, thanks for that post...I just learned something! Its very possible thats what it was though. Now if thats the case and it melted to prevent a problem with an overload situation...the question then becomes what caused the overload?!? I still say that its the alternator...I mean, it has sparks coming out of the back of it when I hit the ignition! Thats definitely not normal or good....
    the fusibel link like Harold suggested is just that, it is a smaller guage wire connecting the output of the altermnator to the power circuit of the vehicle when it encounters a massive short or surge the wire is designed to go up in smoke as opposed to the wiring harness. It sounds as if it did it's job and hopefully your car wiring was spared the overload.
    If everything seems to be going well you have obviously overlooked something.
    4,161
    Quote Originally Posted by Dennis Texas View Post
    Well, it sounds like it did its job, before it was terminated
    .... I cut that wire off and spliced in a 10 gauge wire and a new connection to the alternator. Turned the key, but no power in the car. I hit the ignition again and looked in the engine bay, it started but wouldn't stay started. So I did it again and saw sparks coming out of the alternator.
    Oh oh, that would be a BAD thing to do A fusible link can't "fuse" when it is replaced with a THICKER piece of wire!
    7,563
    Did you remember to re-install the ground wire from between the alternator case and the engine block? Just a thought, I've seen them get left off when an engine swap occurs.
    2,675
    By all means have your alternator tested. I'm wondering if the brushes are gone and that is what's causing the sparking.
    Jul 2006
    134
    So I took my alternator to a shop today and their initial reaction is that I had/have something wired wrong. I said that I was able to drive the car prior to this and that I didn't have anything wrong. But now I'm self-conscious about it...and if I maybe do/did have something wired wrong. From the battery, I just had the cable from the positive post to the solenoid. I also have 2 other connections on that bolt connection as well, but not sure what those are for. From the alternator, I just had the ground wire from the alternator to the engine block and the wire from the bolt closest to the engine block that heads in to the fuse panel.
    I am curious as to how the battery gets it charge back? That question has me wondering if I have something hooked up wrong. And I'm pretty sure that I burnt up another wire from the solenoid to the fuse panel...and thats simply based on a conversation with Dennis from OGTS, since I don't have any power to the interior when the key is in the 'ON' position. (I do have a push button start by the way). Any other thoughts or suggestions??
    Jul 2006
    134
    So I just got done checking out the wiring...and one of the wires from the starter is completely gone! It had a fuseable link in it as well, and it was totally burned out...so I put a new one in there and a new one for the red wire from the alternator. I also checked out the voltage regulator and on of the 3 wires that goes in to the alternator is broke in two near the connector and all 3 of the wires seem to be really old and crunchy. So I think I figured out the problem. I am headed to get a new voltage regulator as we speak. I don't have the alternator back yet, but I went ahead and turned the key ON and I have power to the interior and when I tried to start it, it actually fired up! But the AMP guage was in the negative...which I think would be normal since the alternator and voltage regulator aren't hooked up. Would this be fair to assume??
    Gauge shows the balance of current in the system by going negative it means your using more from your reserve (battery) then the system is supplying thats all sounds normal with no alternator to me.
    Opel Intern Redskinsjbs is on a distinguished road Redskinsjbs's Avatar
    Aug 2008
    Washington DC
    600
    1
    How much is the new regulator unit? I ask because for ~$40 in parts you can get a 105amp+ alternator that is a near bolt in (I am speaking of the CS-130 unit)
    J Swift Sincerely
    Flickr photos
    Videos
    UFO pel investigator Aardvaark is on a distinguished road Aardvaark's Avatar
    Aug 2007
    Des Moines, Iowa
    2,423
    Aardvaark has made a donation to the forum!
    Quote Originally Posted by Redskinsjbs View Post
    Jay. I was watching some of your VIMEO videos and was suddenly thwarted
    on #43 and 44 when the requirement to watch was changed from Flash 9.0
    to Flash 10.0. My 'puter can't be upgraded to 10.0. Do you have any control using VIMEO on which Flash release you can use? Just wondering if anything can be done. Thanks.
    -Mark
    '75 Manta
    Aug 2008
    Washington DC
    600
    1
    Quote Originally Posted by Aardvaark View Post
    There isn't anything that I can do about which flash version the Vimeo-ites use. However, I think that you can download the original file if you scroll to the bottom of the page and click the link on the right-hand side. That does require you to download the entire file and play it after it has finished, but it may be worth it!!
    J Swift Sincerely
    Flickr photos
    Videos
    Aug 2007
    Des Moines, Iowa
    2,423
    I'll try that and hope I've got space. Btw. Did you video your GM alternator install? That is what I'm most curious about if you did. I've read the threads others have posted, but a video is worth a thousand pictures.
    Thanks.
    -Mark
    '75 Manta
    Aug 2008
    Washington DC
    600
    1
    Thanks.
    So far I haven't put one together, but it is on the to-do list! I'll get to it ASAP
    J Swift Sincerely
    Flickr photos
    Videos
    Aug 2007
    Des Moines, Iowa
    2,423
    It worked downloading and then watching using other players.
    I didn't notice that option before.
    Thanks again.
    -Mark
    '75 Manta
    Jul 2006
    134
    So I got the alternator back today ad it had a bolt come loose on the inside of it. The voltage regulator I got, didn't match up to what i had, so I just used new wires from the alternator to the voltage regulator. With that being said, I have the 3 wires goin in to the voltage regulator, and one of the 3 (red wire) is spliced together with a blue wire with white stripes that goes to the fuse panel...what is that wire for?? Put everything back together and started it up...but the 'idiot light' is still on in the AMP meter...its showing a (-) draw...is it just because the battery was used when the alternator wasn't on? Or is something still messed up? I'd like to get it taken care of so I don't have the car die on my when I'm driving it to the trans shop tomorrow and the exhaust shop on Friday.
Page 1 of 3
1 2 3 LastLast
